Revel Concerta vs Revel Performa3 (Convince Me) - AVS Forum | Home Theater Discussions And Reviews
 8Likes
  • 2 Post By madhuski
  • 1 Post By FlashGordon30
  • 1 Post By callas01
  • 1 Post By Molon_Labe
  • 1 Post By madhuski
  • 2 Post By KSpan
post #1 of 13 Old 06-18-2019, 01:26 PM - Thread Starter
Quoted: 26 Post(s)
Liked: 6
I'm going to buy a 3.0 system *LR and Center. I am leaning towards Concerta because they are a bit less expensive and ive heard them on crutchfields audio demo and they are a bit less full which im okay with as well. I actually like brighter speakers. So I am set to buy these unless someone here tells me to definitely save up for the performa line. Does anyone have any advice on these 2 models?
FlashGordon30 is offline
post #2 of 13 Old 06-18-2019, 03:06 PM
Quoted: 833 Post(s)
Liked: 260
You may ask this question in the Revel Owners thread. There are a lot of Revel experts and owners there, many also worked in designing Revel speakers.
SouthernCA is online now
post #3 of 13 Old 06-18-2019, 03:58 PM - Thread Starter
Quoted: 26 Post(s)
Liked: 6
ok thanks !
post #4 of 13 Old 06-18-2019, 05:22 PM
madhuski's Avatar
Quoted: 1286 Post(s)
Liked: 823
that’s an impossible question to answer really. It depends on what your comfortable
spending, and how far into diminishing returns you’re willing to go
Lp85253 and sigpig like this.
Selling in AVS Classifieds
FS: Trinnov Altitude 16
madhuski is online now
post #5 of 13 Old 06-18-2019, 05:51 PM - Thread Starter
Quoted: 26 Post(s)
Liked: 6
the most im willing to spend is as much as the performas3.
As far as diminishing and returns I dont know but if i saw a 5% upgrade in sound I would go with the performas. But.. if it was just stronger bass and louder I would just go with concertas. Im a clarity guy for home theater because I have trouble with dialog so the more clarity the better for me.
Lp85253 likes this.
post #6 of 13 Old 06-18-2019, 05:52 PM
Quoted: 1930 Post(s)
Liked: 1648
what he said...
YAMAHA TSR 5790.. front l/r emotiva b1's and /or kef q100's ..BIC v1220.....Emotiva basx10.... ascend cbm 170 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. wharfedale 10.1s... ascend cbm 170 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is offline
post #7 of 13 Old 06-18-2019, 06:02 PM
callas01's Avatar
Quoted: 1347 Post(s)
Liked: 897
I heard the 206 and F35s and really didn’t notice a big drop from the performas to the concertas. If I was buying Revel I think I’d go with the Concertas. Bass was fine with the concertas also.
FlashGordon30 likes this.
callas01 is online now
post #8 of 13 Old 06-18-2019, 06:09 PM
Molon_Labe's Avatar
Quoted: 3200 Post(s)
Liked: 3844
That has more to do with room acoustics and the type of room correction your running vs the speaker make and model. If you are running Audyssey full-range, i.e. without the app where you can limit the correction range, try turning Audyssey off and see if your dialog intelligibility improves. Audyssey full-range caused a lot of dialog issues in my room. Sometimes room correction can cause more damage than good. Regardless of the type, try turning it off and see if it helps.
AVP - Trinnov Alt16
Speakers - JBL M2 (3), JBL 708p (4), JBL 705i (4)
Subs - (2) Deep Sea Sound 24" & (2) Dual Stereo Integrity 18"
Video - Sony 55es
Screen - Seymour 127" A/T 16:9
Molon_Labe is offline
post #9 of 13 Old 06-18-2019, 06:44 PM
madhuski's Avatar
Liked: 823
In that case, maybe look at concerts L/R and a c208 center
post #10 of 13 Old 06-18-2019, 07:40 PM - Thread Starter
Quoted: 26 Post(s)
Liked: 6
i would like to hear that I'm just worried that the timbre matching would be kinda off with the L/R
post #11 of 13 Old 06-18-2019, 07:42 PM
madhuski's Avatar
Liked: 823
Revel voices their lines similarity so timbre match should be good.
(I used a voice2 with a f206 without any noticeable effects)
post #12 of 13 Old 06-18-2019, 07:46 PM
Quoted: 309 Post(s)
Liked: 218
Little to no chance you would notice an appreciable difference; the Revel 'neutral voicing' is present throughout all of their lines. I personally use my Revel M16s with an Emotiva C2 center and they sound fantastic together.
FlashGordon30 and Lp85253 like this.
KSpan is online now
post #13 of 13 Old 06-19-2019, 06:21 AM
Banks1's Avatar
Quoted: 49 Post(s)
Liked: 58
You have a p.m.
Banks1 is offline
Reply Speakers
