Speakers for Atmos, can't mount in ceiling - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By bobknavs
post #1 of 12 Old 06-18-2019, 11:52 PM - Thread Starter
garage_logician's Avatar
My current speakers are:
Paradigm Studio 100 v2
Paradigm Studio ADP 20 v.2
Paradigm Studio CC-350
SVS 20-39PC-Plus
I am looking to add speakers for Atmos, I think I need two forward up firing speakers and two rear upward firing speakers. I have the Yamaha RX-A3080 if it makes any difference. Any recommendations?
-g
garage_logician is offline
post #2 of 12 Old 06-19-2019, 01:01 AM
markmon1's Avatar
Quoted: 4627 Post(s)
Liked: 2933
SVS 20-39PC-Plus
-g
I'd say dont bother. It's not worth it if you cant put something in or on the ceiling. Can you do on-ceiling speakers or even shelf mounted high up to ceiling wall mounted speakers? There are lots of small speakers that can be mounted to the ceiling externally. B&W m1 style.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #3 of 12 Old 06-19-2019, 08:31 AM
gajCA's Avatar
Quoted: 8558 Post(s)
Liked: 5759
SVS 20-39PC-Plus
-g
Have to agree with what has been said.
If you can't do something like this, could mount on ceiling or at the ceiling/wall junction, I would stick to 5.1.
https://www.accessories4less.com/mak...te-pair/1.html
Geoff A. J., California
gajCA is online now
post #4 of 12 Old 06-19-2019, 09:00 AM
sdurani's Avatar
Quoted: 6957 Post(s)
Liked: 5934
Upfiring modules will work (there is an entire AVS thread about them) but they won't be as effective as speakers physically placed above you. IF you can't do ceiling, can you mount speakers high up on the front & back walls?
Sanjay
sdurani is offline
post #5 of 12 Old 06-19-2019, 09:15 AM
DT4
Quoted: 64 Post(s)
Liked: 39
If you can't do in ceiling speakers, Front Height / Rear Height would be a good option. Your receiver supports this configuration for both Dolby Atmos & DTS:X (p.26 in the manual).
From what I have read, reflective / up-firing Atmos modules are the least prefered option.
5.4.4 - Subs: SVS PB16-Ultra x 4 | AVR: Denon AVR-X4200W | Ext Amp: Emotiva BasX A-150 | L&R: Polk RTiA7 | F&R Heights: Polk RTiA3 | SL&SR: Polk RTiA7 | C: Polk CSiA6 | Display: Sharp LC-70UH30U | UHD Source: Sony UBP-UX80
DT4 is offline
post #6 of 12 Old 06-19-2019, 11:58 AM - Thread Starter
I can mount them up on the wall, the problem with a ceiling mount is that it is vaulted (not the greatest for a home theater). I can mount them at the ceiling/wall junction both front and back. How are front height and rear height speakers different than Atmos speakers? How many high speakers do I need for Atmos? 2? 4? 6?
TIA for all your help.
-g
post #7 of 12 Old 06-19-2019, 12:21 PM
bobknavs's Avatar
Quoted: 2127 Post(s)
Liked: 1502
-g
I suggest that you download and read this: https://www.dolby.com/us/en/technolo...guidelines.pdf
Notation: 5.1.4 means 5 base speakers, 1 subwoofer, 4 Atmos speakers.
If you have a vaulted ceiling, Dolby enabled (ceiling bounce) speakers are not recommended. The normal use is with a flat ceiling, ideally 7.5 to 12 feet (2.3 to 3.66m) high, and acoustically reflective. If you chose to use them anyway, no Dolby police would show up at your door, but the effects may be much worse than optimal.
Given the vaulted ceiling, my first choice would be mounting them as high as possible on the side walls, pointed down towards the listening position. SVS Prime Elevation speakers are designed for that (among other things), but you can also use regular speakers with separate tilt mounts. I believe that some AVRs have provision for side Atmos speakers. My Denon AVR-X4300H (2016 model) does not; I'm using the overhead setting, which isn't optimal.
The next choice would be speakers high on the front and rear walls.
4 Atmos speakers is the recommended number. If you wanted to use 6, I believe that the supported setup with the fewest channels is 7.1.6. (7 base speakers, 6 Atmos.) That'd require 13 amplifier channels. A Denon AVR-X8500H would support that, for a price. Your 3080 has 9 amplifiers, so it could do 5.1.4. It processes 11 channels, so you could add an external amp and do 7.1.4. (I'm pretty sure that 5.1.6 is not an allowed configuration.)
garage_logician likes this.
bobknavs is offline
post #8 of 12 Old 06-19-2019, 02:26 PM
gajCA's Avatar
Liked: 5759
-g
There are three "flavors" of Atmos on the consumer market when looking at AVRs.
5.x.2 (entry level) 5.x.4 (sweet spot for most) 5.x.6 (the AVRs are so expensive very few folks have this iteration).
For a vaulted ceiling I'd take a hard look at Pendant Speakers.
https://www.crutchfield.com/p_855C65...ndant_speakers
gajCA is online now
post #9 of 12 Old 06-21-2019, 10:38 AM
bobknavs's Avatar
Liked: 1502
Did you mean 7.x.6? (If 5.x.6 was allowed with an 11 channel receiver, it wouldn't be prohibitively expensive.)
bobknavs is offline
post #10 of 12 Old 06-21-2019, 10:47 AM
gajCA's Avatar
Liked: 5759
Yes you are correct, I was thinking of the $4000 Denon 8500 which will supports a range of Atmos configurations, including 9.2.4 and 7.2.6
gajCA is online now
post #11 of 12 Old 06-25-2019, 04:15 PM - Thread Starter
Thank you, lots of good info. I really like the SVS elevation speakers. Now I just need to order and install them.
Sent from my iPad using Tapatalk Pro
post #12 of 12 Old 06-25-2019, 04:16 PM - Thread Starter
Thank you everyone, I appreciate the help and information.
Reply Speakers
