AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Speakers (https://www.avsforum.com/forum/89-speakers/)
-   -   Dual Centers (https://www.avsforum.com/forum/89-speakers/3074298-dual-centers.html)
vizag 06-19-2019 03:11 PM
Dual Centers
Has anybody had dual centers?
If so, where did you place the second one and what's your experience?
Also, why did you do that?
William 06-19-2019 03:41 PM
Generally a bad idea. Comb filtering and phasing are usually problems.
vzphoneman 06-19-2019 05:12 PM
I have seem them on a large projector/screen setup (100" plus I would guess) with one just above and one just below and it sounded nice. It seemed work well with such a large screen as the sound seemed to be coming from the center of the screen.
Russdawg1 06-19-2019 05:30 PM
Dual center = Left and Right channels
Lol.
smithsabom 06-19-2019 07:18 PM
1 Attachment(s)
for your consideration: see pic
Johnny14o 06-19-2019 08:30 PM
Proximity to each other influences the comb filtering. I'm running 2 JBL LC2 centers behind my 106" screen. 1 is below the screen, the other is 2/3 the way up the screen. They are also angled slightly away from each other.
I gave it a hard listen before and after doing this setup. I did not notice any comb filtering. What I did notice was a much wider sound field than running a single center channel.
Another way of accomplishing the wider sound field would be to use a single tower identical (or similar) to the left and right for the center.
Sent from my SM-G965U using Tapatalk
vizag 06-19-2019 08:33 PM
So do you like it and recommend it?
Johnny14o 06-19-2019 08:41 PM
1 Attachment(s)
I personally like it.
I have a second row of seats and this has a center directed at each row.
I'm not encouraging this and I don't know what would happen if you had 2 different center channel speakers. Mine are identical.
That being said, I have recently got the hookup on a single JBL L880, and plan to swap out the 2 LC2 (pictured) for the single L880 tower and see how I like it.
One of the best things about having a home theater is being able to experiment with things/ways that give YOU the best experience.Attachment 2582206
https://uploads.tapatalk-cdn.com/201...10d412202c.jpg
vizag 06-21-2019 02:25 PM
If I get dual centers, they will definitely be identical.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
