Recommended Desktop PC Speakers - Passive or Active? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #31 of 49 Old 06-27-2019, 03:58 PM
motrek's Avatar
Quoted: 529 Post(s)
Liked: 196
Originally Posted by Dill3377 View Post
I appreciate the link man, thankfully I already have a SVS PB-2000 to match with it. So would just need an amp and yes it'd still put me over budget, but a little over won't hurt
I like the idea of using an AV receiver as an amp. In my area you can get good used receivers for $100 or less via Craigslist.
A receiver gives you a DAC, amp, digital crossover, subwoofer-out, and often Bluetooth in one device. Good luck finding all that in a small desktop integrated amp for anything less than like $400.
Downside of using an AV receiver is the physical space it takes up (maybe put it under your desk or on a shelf somewhere) and also the amount of power it might consume when idle (presumably you'd leave it turned on all the time).
Soulburner likes this.
motrek is offline
post #32 of 49 Old 06-27-2019, 04:34 PM - Thread Starter
Liked: 1
Originally Posted by Soulburner View Post
I would be curious to know how well the Mackie MR624 stack up to those. They are my desktop speakers, and I've heard their sound compared to the JBL 305, Kali LP6, and others. They sound better than those, and better than many speakers costing more. I'm not sure what happens when you get into the price ranges you're looking at, but I think they have the sound signature you're looking for. Would be a very interesting experiment to order a pair for comparison. I put the tweeters at -2, but I did the same with the Emotiva AirMotiv 6s.
Heard of Mackie, but not of these speakers. I will definitely try to find a pair locally to listen to.
Dill3377 is offline
post #33 of 49 Old 06-27-2019, 04:36 PM - Thread Starter
Liked: 1
I have thought about going this route, my only concern is those who say that the LS50 is super amp dependent, so I was kind of pushed away from this route. Size of the receiver doesn't bother me too much, I'll look locally for used if I can.
Dill3377 is offline
post #34 of 49 Old 06-27-2019, 04:57 PM
motrek's Avatar
Quoted: 529 Post(s)
Liked: 196
As long as we're talking about modern amps that are engineered correctly (basically anything from a reputable name-brand) I don't think there's any difference between amps except for how much power they can put out before distorting.
I'm pretty sure the people who claim to be able to hear differences between amps are the same people who think they can hear differences between speaker wires...
EDIT: BTW, I've used a receiver with my computer on occasion, but have always used analog-out from my computer. Of course you would want to use digital for a more long-term setup. That might mean buying a USB-to-Toslink adapter. I see Amazon has a few such adapters for sale for $20-$30...
motrek is offline
post #35 of 49 Old 06-27-2019, 05:36 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1963
A receiver is the most convenient way to get bass management if you can't do it via software somehow.
motrek likes this.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Polk LSiM 702 F/X (2) | Infinity RS152 (4) | Subs TBD (2)
PC: Micca OriGen G2 | Mackie MR624 (2)
Soulburner is offline
post #36 of 49 Old 06-27-2019, 11:59 PM - Thread Starter
Liked: 1
For sure, I mean I do have some stuff setup, my thing now is just actually spending money on an amp and finding the best speakers for me. What it really boils down to is whether Hi-Fi or a studio monitor is better at this moment in time. I think I'm leaning towards the A5X though..
Dill3377 is offline
post #37 of 49 Old 06-27-2019, 11:59 PM - Thread Starter
Liked: 1
Fair dues, I do have pretty poor bass management currently, just been lazy to fix :/
Dill3377 is offline
post #38 of 49 Old 06-28-2019, 05:52 PM
dswierenga's Avatar
Quoted: 136 Post(s)
Liked: 173
I like NHT speakers and there are a couple of good choices on Amazon.ca. The NHT C-3 is one of the best bookshelf speakers available for $470cdn each and for a two-way speaker, the NHT C-1 for $175cdn each. I have earlier versions of these speakers and can highly recommend them both.
Here is a review of the C-3:
https://hometheaterhifi.com/reviews/speaker/bookshelf/nht-c3-bookshelf-speaker-review/
I use the predecessor of the C-1 with a sub that is similar to yours and a receiver rated at about 150 watts per channel. This setup is used exclusively for music and is constantly impressive.
In my office I have a less powerful receiver fed by my computer. The speakers are the NHT Superzeros and a SVS sub. Again a terrific combination.
Panasonic TCP65VT60, Denon AVR-x6200w
Oppo UDP-203, Dish Hopper
NHT C4 front speakers, NHT C LCR center spkr
NHT Classic 3 surrounds
Velodyne Optimum 12 & DLS-5000R subs
dswierenga is offline
post #39 of 49 Old 06-29-2019, 12:00 AM - Thread Starter
Liked: 1
Haven't heard of NHT before, how would you describe their sound? I don't think I'll find them anywhere locally to listen to :/
Dill3377 is offline
post #40 of 49 Old 06-29-2019, 08:32 AM
dswierenga's Avatar
Quoted: 136 Post(s)
Liked: 173
The thing I look for first in a speaker is accuracy. I would not choose a speaker that adds or subtracts from the intended sound. So frequency response that is within +/- 3 db is the gold standard. You can see from the report on the NHT C-3 that those speakers are within +/- 1.5 db over much of the range. I would characterize the sound as neutral which is exactly what I look for. The listening window chart shows a slight rise in response above 20khz and below 110 hz.
There is a lengthy thread on this forum called How to Choose a Loudspeaker -- What the Science Shows which makes this point with a lot of scientific data to back it up.
The NHT speakers are sealed acoustic suspension designs (as opposed to ported) which many prefer for music (although this is sharply debated).
There are also several reviews on-line of the NHT Classic Three and one or two of the NHT Absolute Zero which are the predecessors of the C-3 and C-1. The only significant difference is that the later versions have a redesigned cabinet.
The C-3 and C-1 are beautifully finished with a black lacquer. You wont be disappointed with either the looks or the sound.
Dill3377 likes this.
post #41 of 49 Old 06-29-2019, 09:40 AM - Thread Starter
Liked: 1
Will do some searching when I have a bit of free time today. Appreciate your opinion of it though, neutral sounds good to me!
Dill3377 is offline
post #42 of 49 Old 06-29-2019, 09:53 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1963
I've seen others say the Super series is not neutral, but I haven't seen comments about their higher lines.
post #43 of 49 Old 06-30-2019, 01:29 AM
motrek's Avatar
Quoted: 529 Post(s)
Liked: 196
Thanks for posting the link to that thread. I'm interested in that stuff and the thread passed me by. I don't see any spin-o-rama plots of NHT speakers in that thread though? I admit I didn't read all 100 pages of comments but if you could post a link, that'd be cool.
motrek is offline
post #44 of 49 Old 06-30-2019, 01:39 PM
Quoted: 898 Post(s)
Liked: 732
https://www.soundstagenetwork.com/me...classic_three/
motrek likes this.
sigpig is offline
post #45 of 49 Old 06-30-2019, 06:21 PM
dswierenga's Avatar
Quoted: 136 Post(s)
Liked: 173
The "How to Choose a Loudspeaker" thread doesn't do spinoramas. Rather it's a discussion on measurements that lead to a satisfying speaker choice. The main idea is that speakers that listeners like mostly come from the set of speakers that have a flat frequency response curve.
post #46 of 49 Old 06-30-2019, 06:31 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1963
I'm not sure about your first sentence - the premise of the discussion is that this data is collected via spinorama measurements, which gives you the listening window, sound power, and directivity index.
post #47 of 49 Old 06-30-2019, 06:34 PM
dswierenga's Avatar
Quoted: 136 Post(s)
Liked: 173
Just saying you wont find spinoramas in that thread except maybe in passing. The main theme is that spinorama data can be used to narrow the selection process.
post #48 of 49 Old 06-30-2019, 06:35 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1963
There is plenty of discussion in between, but there are spinorama measurements for quite a few speakers posted there.
post #49 of 49 Old 07-01-2019, 09:21 AM
motrek's Avatar
Quoted: 529 Post(s)
Liked: 196
Check out the first post of the thread. The thread is literally entirely about spin-o-ramas, which they've standardized as ANSI/CEA-2034-A.
Flat on-axis frequency response is only one thing you need to look at when choosing a speaker. Ideally you will be able to see the speaker's entire spin-o-rama plot. It's a shame that we often can't, though. Not even Harman publishes spin-o-rama plots online for all of their speakers, even though they're the ones promoting the standard.
motrek is offline
Reply Speakers
