Elac Vs. Polk - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By Pete7874
  • 1 Post By pase22
  • 1 Post By pase22
post #1 of 16 Old 06-25-2019, 11:40 AM - Thread Starter
robghosh's Avatar
Elac Vs. Polk
Good morning everyone. I'm in the market to upgrade my 20 year old Energy XL-25s. I'm running a Dennon AVR 1912 with a Polk sub and a Dayton Audio sub, along with an energy center, Fluance dipoles and Bic back channel.
I have a $500 budget and am considering two speakers: The Polk Signature Series S55 and the Elac Debut 2.0 F5.2. Does anyone have any advice as to which would be the better speaker for this setup? I plan on heading to Best Buy to listen to a them this weekend, but any input would be greatly appreciated. Also, if there are other speakers that I'm not aware of in that price range, I'd love to hear about it. Thank you all in advance!
robghosh is offline
post #2 of 16 Old 06-25-2019, 12:03 PM
Pete7874's Avatar
Quoted: 158 Post(s)
Liked: 97
Based on my experience, the Polk Signature line is a bit on the brighter side, at least compared to something like Elac Debut. Between the two, I'd lean toward the Elac, but that's just my personal preference.
You should definitely listen to them side by side.
christoofar likes this.
"The problem with quotes on the Internet is that you never know if they're real." - Abraham Lincoln
Pete7874 is online now
post #3 of 16 Old 06-25-2019, 01:01 PM
Pete7874's Avatar
Quoted: 158 Post(s)
Liked: 97
As far as other speakers in this price range worth considering, the Infinity Reference line is very well regarded. The R253 towers frequently go on sale for $200 a piece.
post #4 of 16 Old 06-25-2019, 01:08 PM
pase22's Avatar
Quoted: 3094 Post(s)
Liked: 2574
For music: Elac debut. For TV/HT: Polk S55. Going out to listen to them is the best way to determine which you like best.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #5 of 16 Old 06-25-2019, 01:11 PM - Thread Starter
robghosh's Avatar
Thanks Pase22! Interesting that you say that. I was talking with Crutchfield and they said the opposite... Elac for HT and Polk for music. Going to try to go listen to them tonight!
robghosh is offline
post #6 of 16 Old 06-25-2019, 01:12 PM
gajCA's Avatar
Quoted: 8589 Post(s)
Liked: 5788
Not sure either would be a definite upgrade while a $500 Monolith THX subwoofer definitely would.
Geoff A. J., California
gajCA is online now
post #7 of 16 Old 06-25-2019, 01:19 PM
pase22's Avatar
Liked: 2574
It depends on the type of sound you like. If you prefer a more mellow sound Elac may be preferred. If you like more treble energy, Polk may be the better option. Keep in mind that audio is very subjective and we all have our preferences. That's why we all have different speakers.
mr266 likes this.
pase22 is offline
post #8 of 16 Old 06-25-2019, 01:23 PM - Thread Starter
robghosh's Avatar
Totally understand! Love that there are so many options out there. That's why I narrowed it down to two.. didn't want to get too overwhelmed with choices. Thank you!
robghosh is offline
post #9 of 16 Old 06-25-2019, 01:43 PM
pase22's Avatar
Liked: 2574
If you went with bookshelf speakers, you have more options and could possibly get higher speakers within your budget or slightly above.
pase22 is offline
post #10 of 16 Old 06-25-2019, 05:43 PM
Quoted: 851 Post(s)
Liked: 262
Now that is a great thought. Listen to all speakers with low pass filter at 100 or 120 hz. You may find your current speakers are just as good in that frequency range. If that is what our hear, use the $500 you have to buy at sub. SVS nsd sb12 is often on sale for 399.
Frequencies below 120 hz. Determine 30 percent of our preference for music and most speakers lack them.
SouthernCA is offline
post #11 of 16 Old 06-25-2019, 06:02 PM
MIX_MASTER_ICE's Avatar
Quoted: 2593 Post(s)
Liked: 2418
Do you have some decent headphones you could use to try the Crutchfield Speakercompare system? It can give you a general idea of how speakers sound compared against each other. The Elac will be a little to the warmer side of neutral and the Polk will be a little to the brighter side of neutral. The Polk Signature line isn't bright, at least not to me. They are fairly neutral in most regards, but so have a slight rise in the treble upper range. Here is a good comparison that included the Polk S15 and at the end, you can see how it compared to the Elac B6, which was the first series and a bit warmer than the 2.0 series. https://www.avsforum.com/forum/89-sp...-speakers.html
Subs>RBH I-12e/I-12. HSU VTF-15H mk2. Monolith THX 12(x2)/THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL 270/235c/230/225c, Arena 130/125c. Jamo S807/S803. Infinity P363/163. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5 bs. Polk RTiA1/CsiA4. Other Audio>Sony MDR-Z7m2, WH-XB700, XB32, XB31. Sennheiser HD58X, HD4.50, PC37X. SIVGA SV004. HyperX Cloud PS4 HS. Plantronics RIG500 Pro HS. LG FH6,RK8,RK7,PK5. UE Boom3.
MIX_MASTER_ICE is offline
post #12 of 16 Old 06-25-2019, 06:07 PM - Thread Starter
robghosh's Avatar
I'll have to look into those Infinitys too! Thank you.
robghosh is offline
post #13 of 16 Old 06-25-2019, 06:08 PM - Thread Starter
robghosh's Avatar
Wow! No, I didn't know about that. I do have some pretty good headphones at work, so maybe I'll try that tomorrow when I go in. Great idea! Thank you.
robghosh is offline
post #14 of 16 Old 06-26-2019, 08:16 AM
gajCA's Avatar
Liked: 5788
Speakers haven't changed nearly as much as subwoofers in terms of price/value.
In fact I'd venture to say that the "expensive in their day" Energy speakers, which got their share of "sound great" reviews might be better than the level of towers he's looking at which are entry level.
I think entry level towers today might be better than they were in the past but the Energies he has were better than entry level when they came out.
gajCA is online now
post #15 of 16 Old 06-26-2019, 10:05 AM
_tk
Quoted: 441 Post(s)
Liked: 175
A lot of their "techs" don't really know what they are talking about. I've taken their advice before and let's just say that I'm glad they have a good return policy.
Not sure where you are at, but I'm selling a set of almost BNIB Elac F5.2's for far less than $500.
_tk is online now
post #16 of 16 Old 06-26-2019, 01:37 PM
Pete7874's Avatar
Quoted: 158 Post(s)
Liked: 97
Here is another option: Boston A360, two for $345 total:
https://www.accessories4less.com/mak...ck-each/1.html
However, I agree with others, in this price range, you're probably not going to notice much if any improvement over your current Energy towers.
Use that money toward a better subwoofer instead.
gajCA likes this.
Reply Speakers
