Another “Re-Veneer” project.....dedicated to the speaker line...that started my audio - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #1 of 79 Old 06-30-2019, 08:12 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
I just purchased a used pair of Lynnfield 300l(s) on EBay. I plan to give the speakers a modern “update”.
In the early nineties...Boston Acoustics were the speaker line that kicked off my audio addiction.
I was in high school when these speakers were introduced. But I ended up with the lower level pair (VR-20s). I talked my parents into forking over $550.00 for them (much less than the $2k Lynnfield 300ls). I always wanted a pair of the coveted “Lynnfield” speakers. And 25 years later—-here we go.
Unfortunately I love *some* of the design....and the rest of it is horribly outdated. Hence the reason for this thread.....
I’m going to re-veneer these speakers and let them shine again.
Here we go.....
Jglass4788 is online now
post #2 of 79 Old 06-30-2019, 08:20 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
post #3 of 79 Old 06-30-2019, 08:22 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
Zebrawood veneer purchased for this project
pjp likes this.
post #4 of 79 Old 06-30-2019, 08:26 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
After reviewing many designs, I’ve decided on something very similar to this speaker(minus the black stripe).
Most zebrawood speakers will run the grain “vertical”. I love the horizontal look.
pjp likes this.
post #5 of 79 Old 06-30-2019, 08:33 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
Here are the other speakers I’ve reviewed ...any feedback?
post #6 of 79 Old 07-01-2019, 12:56 PM
gajCA's Avatar
Quoted: 8809 Post(s)
Liked: 5990
Very cool; looking forward to following your progress.
They should look great.
What does the grill look like or are you planning to run without a grill?
Geoff A. J., California
gajCA is offline
post #7 of 79 Old 07-01-2019, 07:50 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
The grills are awful looking I’ll probably just delete them(or magnetize them so the grill holes don’t show)
post #8 of 79 Old 07-14-2019, 06:37 AM
Superman07's Avatar
Quoted: 149 Post(s)
Liked: 44
Subscribed! Can’t wait to see how these turn out after your B&W refresh.
Superman07 is online now
post #9 of 79 Old 07-14-2019, 05:49 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
Started pulling the “guts” out.
Really hate when they glue things in (port)
post #10 of 79 Old 07-14-2019, 06:18 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
And now the fun starts....I plan to sand down flat(sand the “grain” out).
post #11 of 79 Old 07-14-2019, 06:21 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
post #12 of 79 Old 07-14-2019, 06:23 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
As I continue to sand....I’m thinking—-I should just sand down a little finer. And through some clear coat on it
post #13 of 79 Old 07-20-2019, 06:18 PM
Superman07's Avatar
Quoted: 149 Post(s)
Liked: 44
So it was oak veneered and painted black? I always assumed black “wood” was some sort of molded plastic product.
post #14 of 79 Old 07-21-2019, 12:59 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
That is correct oak veneer over MDF(pretty much always the case in cabinet construction)
post #15 of 79 Old 07-21-2019, 01:02 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
I’m “blocking out” the speaker (trying to make it perfectly flat.
I’m amazed how “off” these speakers can be.
The B&w 805s that I refinished—had high/low spots pretty much everywhere.
My goal is to finish them “better” than the factory.
post #16 of 79 Old 07-21-2019, 01:03 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
post #17 of 79 Old 08-08-2019, 09:46 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
Perfectly....”flat”...
post #18 of 79 Old 08-09-2019, 05:26 AM
Elihawk's Avatar
Quoted: 1905 Post(s)
Liked: 2035
Excellent work, Jd...so that is the original veneer? I am amazed you were able to get the paint off and the veneer looks that good!
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #19 of 79 Old 08-09-2019, 07:27 AM - Thread Starter
Jglass4788's Avatar
Liked: 115
Thanks, yes original veneer which of course was covered by matte black paint.
It looks so good, I almost feel guilty covering it up!
If it weren’t for the grill holes, I would just throw some clear coat over it.
But “onward and upward”
Got my veneer- ready to go!
pjp likes this.
post #20 of 79 Old 08-09-2019, 08:25 AM
pjp
pjp's Avatar
Quoted: 551 Post(s)
Liked: 372
If not for the larger grain circles in the middle, the speaker sides almost have a zebrawood grain already! I think if you experimented with some stains, maybe something with a bit of red in it, before clear-coating it, the existing finish could look amazing.
Nonetheless, looking forward to seeing how the Zebrawood turns out. I agree with you that the horizontal grain example looks a lot more interesting and a lot cooler than the traditional vertical grain.
pjp is offline
post #21 of 79 Old 08-09-2019, 08:18 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
Here are the “cleaned up” pics...
post #22 of 79 Old 08-09-2019, 08:19 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
Ready to fill the speaker grill holes.
post #23 of 79 Old 08-09-2019, 08:32 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
post #24 of 79 Old 08-11-2019, 11:15 AM - Thread Starter
Jglass4788's Avatar
Liked: 115
Sanded down the filler with 80 grit. Pretty much ready for the veneer.
post #25 of 79 Old 08-11-2019, 11:28 AM
gajCA's Avatar
Liked: 5990
Still enjoying your project.
Jglass4788 likes this.
gajCA is offline
post #26 of 79 Old 08-11-2019, 02:07 PM
RayGuy's Avatar
Quoted: 2729 Post(s)
Liked: 2498
About time! I've had more than enough "foreplay"!
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #27 of 79 Old 08-11-2019, 03:06 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
Test fitting the veneer...
post #28 of 79 Old 08-11-2019, 03:13 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
The front and sides will be “wrapped”...so the top has to be cut off.
post #29 of 79 Old 08-11-2019, 07:38 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
Lp85253 likes this.
post #30 of 79 Old 08-11-2019, 07:40 PM - Thread Starter
Jglass4788's Avatar
Liked: 115
I moved the operation out in my garage.
Reason- the contact cement is very potent stuff!
Reply Speakers
