Entry level home theater speakers - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 69Likes
post #31 of 136 Old 07-03-2019, 09:19 PM
Quoted: 78 Post(s)
Liked: 38
The denon 2400 looks like a great deal today for $240.
If you want a great center channel get the Emotiva C1 $212 for a renewed one. Do you have stands or placing on a shelf? Could use Emotiva B1 $200, If you dont have anything to put a book shelf speaker on can do T0 $340 or T1$424
2400/C1/B1= $652
2400/C1/T0 = $792
2400/C1/T1 = $876
If you go towers might be able to get away without a sub for a little atleast and spend the rest on projector and screen. Then save up for a sub. T1 play down to 40 hz and really they are good for most things other than bass heavy movies. I own these and have played around with them alot. T0 should be about the same they go down to about 50
I am mostly recommending the emotiva C1 since you want a great center channel. In your budget i have not seen another one that would work as well. And the other are options to match the center.
Gold87 is offline
post #32 of 136 Old 07-04-2019, 08:29 AM
gajCA's Avatar
Quoted: 9089 Post(s)
Liked: 6232
Originally Posted by Patrick Flaherty View Post
I am located a bit north of Milwaukee, WI
HiFi Heaven is less than two hours away from you and has many brands on hand for you to listen to including good discounts on floor models etc.
d-rail34 and Patrick Flaherty like this.
Geoff A. J., California
gajCA is offline
post #33 of 136 Old 07-04-2019, 10:36 AM - Thread Starter
Quoted: 98 Post(s)
My fiance is from Green Bay and we were never aware! We are actually heading through that area this weekend. Will definitely check out this place this weekend or some other time! Thanks!
gajCA and d-rail34 like this.
Patrick Flaherty is offline
post #34 of 136 Old 07-04-2019, 12:34 PM - Thread Starter
Quoted: 98 Post(s)
I think after reviewing everything I have been told I am going to start with NHT SuperOnes for L/C/R with the Denon 2400 receiver and the Dayton 1500 sub. I will eventually add SuperZeros for surround and at some point hopefully something for Atmos possibly these?
https://www.amazon.com/NHT-Atmos-Min...NB4X53XEJNA6R9
The Emotiva C1 sounds like a terrific center speaker, would this be an issue to use this as my center with the rest of the setup or should I keep it all NHT?
post #35 of 136 Old 07-04-2019, 12:41 PM
Quoted: 556 Post(s)
Liked: 292
I think after reviewing everything I have been told I am going to start with NHT SuperOnes for L/C/R with the Denon 2400 receiver and the Dayton 1500 sub. I will eventually add SuperZeros for surround and at some point hopefully something for Atmos. The Emotiva C1 sounds like a terrific center speaker, would this be an issue to use this as my center with the rest of the setup or should I keep it all NHT?
there are not any hard rules that say you must match...your ears are the ultimate judge.
Lp85253 likes this.
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #36 of 136 Old 07-04-2019, 01:56 PM
d-rail34's Avatar
Quoted: 448 Post(s)
Liked: 850
With you having acoustic ceiling tiles, upfiring modules aren't going to work for you. They'll just suck up every bit of sound vs. reflecting it back to you. Textured ceilings are also a problem with the upfiring modules.
If/when you decide to go Atmos, you could always make some kind of support brackets to use to mount in-ceiling speakers, or perhaps see if there aren't some available already for purchase. Plus, in-ceiling will give you the best results, so...WIN/WIN!
"Sticking feathers up your butt does not make you a chicken." - Tyler Durden
Living Room - Denon AVR-X2400H/MiniDSP 2X4HD/Hsu Research HB-1 Bookshelfs (4)/HC-1 Center/SVS PB12 Plus (1)/Samsung UN65H7150/Sony UBP-X800/PC Built by D-Rail/XBox One S
d-rail34 is offline
post #37 of 136 Old 07-04-2019, 02:10 PM
Quoted: 78 Post(s)
Liked: 38
Its normally best to try and keep the front 3 in the same speaker line. Surrounds not as much. But there is no rule on it and some still enjoy the mixed speakers.
Not really a price difference between the B1 and the superones though. Might as well just get the 3 from from emotiva if you want them to match.
d-rail34 likes this.
Gold87 is offline
post #38 of 136 Old 07-04-2019, 03:51 PM - Thread Starter
Quoted: 98 Post(s)
Are the emotivas better than the NHTs in your opinion? Or does NHT just not have good center options?
https://soundapproach.com/nht-n-sc2-...xoCZbgQAvD_BwE
post #39 of 136 Old 07-04-2019, 04:05 PM
Quoted: 78 Post(s)
Liked: 38
Not sure how the nth center sounds. But i do have super zeroes and emotiva e1 and kept the e1 in my 2.2 set up for the bedroom. Much clearer sound to me with the ribbon tweeter. The emotiva are also ported and has more midbass it sounded like to me.
The nht are nice speakers and sounded fine watching normal tv show but they felt lacking in action movies or music for my liking.
Gold87 is offline
post #40 of 136 Old 07-04-2019, 04:14 PM
pase22's Avatar
Quoted: 3335 Post(s)
Liked: 2802
if you go up the NHT line to the C series the center is comparable to the C1, but is also twice the price. NHT are sealed so will have a more limited frequency response, but would be ideal if mounting flush to the wall. Emotiva are quite good for the price, but are harder to drive due to lower impedance. All things being equal, it's hard to say which is better as that would come down to personal preference. Both are well praised and I don't think you could go wrong with either one.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #41 of 136 Old 07-04-2019, 04:20 PM
Matthew Pool's Avatar
Quoted: 146 Post(s)
Liked: 41
This HT build video might interest you.
Don't forget, getting into audio is/can be a long and very satisfying journey. It's really really good if you can develop patience and a plan to do this over a period of many months or more so you can get better quality components! You have a GREAT room for audio so hopefully you can fill it withe good stuff. And I'm for planning to match your front three speakers. Don't be afraid to start at 2.0 plus AVR even though I know it's tough! I'm only at 2.2 and surround sound down-mixed to 2.2 is wickedly good. You can achieve the same with a little more research into good speakers. :-)
KEF R3 L/R | Dual Rythmik F12SE | 2.2 | Yamaha RX-A2080
Matthew Pool is offline
post #42 of 136 Old 07-04-2019, 04:45 PM - Thread Starter
Quoted: 98 Post(s)
https://www.youtube.com/watch?v=U-tfoHeA-tY
Patience is hard for me ha. I really want to start with 3.1 either the NHT or Emotiva setup with a Dayton Audio 1500 sub. I have had surround once in my life and it was a cheap yamaha in the box system for like $300... and I THOUGHT that was awesome (since I was coming from tv speakers). I have since been on TV speakers again for the last near decade probably so tbh any and every speaker setup here will most likely blow me away. I want to start with a 3.1 on a budget and then just keep adding and upgrading from there, but I need something other than pathetic tv audio speakers right now.
post #43 of 136 Old 07-04-2019, 05:13 PM
Quoted: 146 Post(s)
Liked: 41
Understood. I like the Emotiva and Denon 2400H option. I used a Denon AVR in my system and it was great. Although I've never heard Emotiva speakers personally they get a ton of great reviews. And from a previous post it sounds like you'd be able to match the front three within your budget. :-)
post #44 of 136 Old 07-04-2019, 05:42 PM
Rysa4's Avatar
Quoted: 39 Post(s)
Liked: 118
Ascend Acoustics left/right and Center - 600 ( CBM 170 Se pair and a sierra - 1 center)
Dayton Audio 10 inch entry level sub - 120
One used Denon receiver - Denon AVR -391 5.1 receiver -80
Done
Matthew Pool likes this.
Rysa4 is offline
post #45 of 136 Old 07-04-2019, 05:50 PM
Quoted: 146 Post(s)
Liked: 41
Done
I didn't want to add more confusion to OP's decision but I almost mentioned Ascend as an option to strongly consider... But I'd keep the Denon 2400 AVR if possible because it's a really good for that price.
post #46 of 136 Old 07-04-2019, 05:57 PM
pase22's Avatar
Liked: 2802
An Emotiva 3.1 setup will be miles ahead of any budget HTIB. In fact even a 2.1 would do better. If you have trouble with being patient and want 5.1 right away, go down to your local pawn shop or look on Craigslist and get some used speakers for $20-30 to use as surrounds. Worse case order some Dayton B452's for $30.
https://www.parts-express.com/dayton...-pair--300-452
pase22 is offline
post #47 of 136 Old 07-04-2019, 07:14 PM - Thread Starter
Quoted: 98 Post(s)
I am going to start with the build I mentioned earlier. Can anyone beat these prices for me? These are the prices I am finding.
Emotiva Airmotiv B1 speakers - $194 factory renewed (pair)
Emotiva Airmotiv C1 - $211 factory renewed
Dayton Audio 1500 sub - $199
Denon x2400 - $299
Thanks everyone for the help, I truly appreciate it so much. I will be working on getting these set up as well as the PJ and screen after I order this weekend. *Update* I was also able to get my fiance to go for the different room setup so I will be able to get a bigger screen
Last thing, I assume I need some speaker plugs and wiring of some sort, eh? Probably some sort of surge protector as well, or any other items you may think I need for home theater? Anyone want to provide their two cents worth on those items?
post #48 of 136 Old 07-04-2019, 07:16 PM
Rysa4's Avatar
Quoted: 39 Post(s)
Liked: 118
Ya I agree. AScend Acoustics has a B stock sale about this time of year as well, so could shave off some bucks that way and still get the same sound quality. Also I meant the CBM-340 center not the Sierra -1 center which is more expensive. I have a pair of CBM170s and they do pretty well for me and have demoed the Sierras and 340 before as well. so pretty confident in at least a good recommendation. Not knocking the Emotivas though at all. I have never owned that line and have heard them but only in a "non-critical" listening environment for sure. :-)
Rysa4 is offline
post #49 of 136 Old 07-04-2019, 07:16 PM
zieglj01's Avatar
Quoted: 3113 Post(s)
Liked: 3035
Enjoy the adventure
Who AM I
zieglj01 is offline
post #50 of 136 Old 07-04-2019, 07:23 PM
Quoted: 78 Post(s)
Liked: 38
Denon x2400 - $299
Emotiva does give a military discount for active and veterans. Will save a little. The sub seems normal price could wait for a sale. Seems the sale is over on the 2400 for 240. Other than trying to find used those prices might be the best you will find.
Gold87 is offline
post #51 of 136 Old 07-04-2019, 07:29 PM
Rysa4's Avatar
Quoted: 39 Post(s)
Liked: 118
Denon x2400 - $299
Used denon x2400 for $59 on ebay some seller with 100% positive feedback too. Just an FYI.
Rysa4 is offline
post #52 of 136 Old 07-04-2019, 07:34 PM
Rysa4's Avatar
Quoted: 39 Post(s)
Liked: 118
hey just happened to venture over to the greentoe site and saw that x2400H. Hit the greenzone with a $285 bid ( new no sales tax free ship)
Just cuz you asked!
Good luck!
Rysa4 is offline
post #53 of 136 Old 07-04-2019, 08:00 PM - Thread Starter
Quoted: 98 Post(s)
Ebay worries me, although the 100% feedback is really solid. Link?
post #54 of 136 Old 07-04-2019, 08:01 PM
Quoted: 146 Post(s)
Liked: 41
Denon x2400 - $299
I think you'll be very happy and impressed with that setup. A basic surge protector/power strip. Any 16 AWG oxygen free pure stranded copper will do: I have this but in 12 AWG. 16 AWG is fine:
https://www.monoprice.com/product?p_...xoCKqMQAvD_BwE
Just neatly and firmly secure it without connectors unless you want them.
Also any HDMI cables (make sure they are 4K certified) for video between ther AVR, 4K player, and TV.
https://www.monoprice.com/search/index?keyword=4k+HDMI
post #55 of 136 Old 07-04-2019, 08:02 PM - Thread Starter
Quoted: 98 Post(s)
What is the ohms in a speaker? I remember someone said 4 ohms requires more power than 8 ohms. Will there be any issues with me running with the Denon x2400?
post #56 of 136 Old 07-04-2019, 08:10 PM
Rysa4's Avatar
Quoted: 39 Post(s)
Liked: 118
maybe. maybe not. Some gorry details. Bottom line for me -- if I am not using a beefy amp, I don't go with true 4 ohm speakers. That is just me.
Rysa4 is offline
post #57 of 136 Old 07-04-2019, 08:13 PM
Rysa4's Avatar
Quoted: 39 Post(s)
Liked: 118
I understand. It can be a crapshoot although I have bought electronics off there occasionally and haven't been burned once.
( not sure I can post an ebay link without breaking forum rules)
Do you see my greentoe post? I sure bet there with new products and authorized resellers only ( like bestbuy etc) You can save a few bucks and get a new one.
Rysa4 is offline
post #58 of 136 Old 07-04-2019, 08:18 PM
Quoted: 146 Post(s)
Liked: 41
The C1 is rated at 4 ohms, per Emotiva site specs listed. The B1's are 8 ohms. Maybe Emotiva / Emotiva C1 owners can respond but normally we'd like to see all 8 ohm speakers. That Denon 2400 AVR is rated well at 95W into 8 ohms, 2 channels driven. The C1 recommended amp range is 75W-350W so the 2400 could be on the low side of that when driving all 3 speakers.
post #59 of 136 Old 07-04-2019, 08:20 PM
Rysa4's Avatar
Quoted: 39 Post(s)
Liked: 118
surge protection -
so this is a whole discussion -- for your rig, just be sure you get an actual surge protector and not just a power strip. Doesn't need to be expensive at all -- just make sure it is actually a surge protector -- they have some extra electronics/hardware inside the strip that makes it more than a glorified power outlet. Hope this helps. Again - does NOT need to be big bucks for basic better than nothin probably will be fine protection.
Rysa4 is offline
post #60 of 136 Old 07-04-2019, 08:28 PM
Rysa4's Avatar
Quoted: 39 Post(s)
Liked: 118
Agree on asking folks who actually have the C1. But based on those specs the center channel could be a problem with that amp especially when moving up a bit on volume. That Denon, based on specs only, won't allow that center to perform up to its capability and the aymmetry with the left and right channels will need to be handled by a channel volume adjustment on the denon ( easy to do). That center might crackle a bit or buzz or just not offer enough volume. I actually have short circuited/overloaded a couple of basic receivers with 4 ohm speakers, but that was many years ago.
I am going to stay away from other speaker brand recs for now. Don't want to muddy the waters.
Lp85253 and Matthew Pool like this.
Rysa4 is offline
Reply Speakers
