14x17 home theater build questions - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 2 Post By sdurani
  • 2 Post By TommyDeVito
  • 1 Post By WOKNROX
  • 1 Post By burton14e7
post #1 of 21 Old 07-10-2019, 10:02 AM - Thread Starter
rochoa21's Avatar
Hi
Currently waiting for my new home to be build I will be having a loft area that I will be using for my home theater. It’s 14x17 I want to build a 5.2.2 system, it will be pre wired for speakers. I have been looking at the svs primer speakers and also the see that klipsch speakers are popular. I want to make sure I get speakers that will fill the room. Atmos speakers will be in ceiling.
My theater setup will be for movies mainly. I have a budget of $2500 for just speakers. If I have to get one sub at a time that can work. Mainly want a svs sub.
Any advice will be great.
rochoa21 is offline
post #2 of 21 Old 07-10-2019, 10:43 AM
sdurani's Avatar
Quoted: 6981 Post(s)
Liked: 5965
How many rows of seating?
Run wires for 9 speakers in the base layer: L/C/R on the front wall, a pair of Sides in-line or slightly forward of the seating, a pair of Rears spread out on the back wall, a pair of Wides mid-way between the Fronts & Sides. You don't have to install all those speakers but, since wire is cheap, at least run wires to all those locations while the walls are open.
For the height layer, run wires for 6 speakers: one pair slightly forward of the seating, the other pairs a few feet forward & rearward of the seating. Even if you start with only 2 overhead speakers, at least the wiring will be there when you want to upgrade (and you will) to 4 overheads.
Transmaniacon and smithsabom like this.
Sanjay
sdurani is offline
post #3 of 21 Old 07-10-2019, 10:51 AM
TommyDeVito's Avatar
Quoted: 137 Post(s)
Liked: 125
I'd run wiring for 7.2.4, even if you aren't going to buy all of them now or install all of them now.
solarrdadd and burton14e7 like this.
HT 7.1.4: Sony X940E, Marantz SR8012, LR: JBL Studio 580's, C: JBL Studio 520c, Surrounds and Rears: JBL Studio 530's, ATMOS: JBL Studio 210's, Sub: HSU VTF-3 mk5
MB 5.1: Sony 55" X950G, Denon X3500H, LR/Surrounds: JBL Studio 270’s, C: JBL Studio 235c, Sub: HSU VTF-2 mk5
Living Room/Office 5.1: Sony 49" 900E's, HTNT5's with wireless rear channels
TommyDeVito is offline
post #4 of 21 Old 07-10-2019, 10:53 AM
Quoted: 1482 Post(s)
Liked: 1067
Klipsch RP is a great choice for theater. Efficient and dynamic. Their in ceilings are also inexpensive.
Are you set on an SVS sub?
Leave it at 8 ohms and call it a day :)
Russdawg1 is offline
post #5 of 21 Old 07-10-2019, 11:18 AM
Quoted: 77 Post(s)
Liked: 38
Do you want towers or bookshelf? Any restrictions like they have to pass the wife factor or size? How to you plan to mount the surrounds? Is it a flat ceiling your doing atmos speakers in?
Might be best to atleast give a rough drawling of the room and placement of tv, furniture, doorways and anything that would be in the way of placing speakers.
Sub size is depended on the cf of the room and any connecting rooms. If you dont mind waiting and moving it maybe twice the monolith 12 is on sale at amazon for $640 that will work for most rooms. It is large and weighs 100 pounds so keep that in mind. If your set on svs only they have sales a few times a year in the outlet and some subs are brand new and can get a good deal on one. Still has a full warranty.
I also dont seen a mention of an avr you plan to use.
As others have said i would at a minimum run wiring for a 7.2.4 setup. It will be alot cheaper do do while walls are open then later down the road.
Your budget of 2500 for speakers can get you a nice set up just dont want to recommend things that wont even fit in your space.
Gold87 is offline
post #6 of 21 Old 07-10-2019, 11:54 AM
chadsmith013's Avatar
Quoted: 2116 Post(s)
Liked: 2146
im in an upstairs loft too..mine is about 13 X 16...i went DIY on all of my speakers...system is amazing..
Chad
Receiver : Pioneer Elite SC-95
Front Speakers: 3 DIYSG 1099's
Surround Speakers:2 DIYSG Volt 10's Atmos: 2 DIYSG Volt 6's
Subwoofers: Dual LaVoce SAN214.50 21's in Cyclops enclosures w/Inuke 6000 DSP
Nearfield: 2 Dayton HO 15's w/Inuke 6000DSP
chadsmith013 is offline
post #7 of 21 Old 07-10-2019, 11:54 AM
WOKNROX's Avatar
Quoted: 322 Post(s)
Liked: 228
Do yourself a huge favor and have your electrician installed a dedicated line to this room with 30amp 10/2 wire for all your electronics.
smithsabom likes this.
Theater:14'x20'x10' room, 100amp service, JVC RS620, ST 120" AT screen, Carada Masquerade Masking, OPPO-203 & Panny ub820, Anthem AVM60, Simaudio Moon Titan 7&5 channel amplifiers, Infinity Fans, L&R Polk SDA SRStl Fully built, CC 2 Polk RTA15tl in Custom cabinets, SS, BS DT BPXV, 4 Atmos DT SM 450's, Subs, Rythmik FV25HP front 2 HSU VTF-MK5-HP back, 2 Rows of 3 Seatcraft Excalibur Lx Seats and more.
WOKNROX is online now
post #8 of 21 Old 07-10-2019, 04:15 PM - Thread Starter
rochoa21's Avatar
Im not set on SVS speakers, I will see if its not too late to add the 2nd set of upper speaker wiring. I will only be running one row of seating. In regards to speaker size no restriction, plus she wants this system to be on point. Ceiling is flat. In regards to the surrounds im not sure if wall mount or use a base. I think wall mount will look cleaner. Ill post a layout. Our room will just have a couch for seating, and some sort of AV cabinet underneath the tv.
rochoa21 is offline
post #9 of 21 Old 07-10-2019, 04:20 PM - Thread Starter
rochoa21's Avatar
This is the layout
rochoa21 is offline
post #10 of 21 Old 07-10-2019, 04:57 PM
Quoted: 77 Post(s)
Liked: 38
Any speakers you have had before that you liked? Or heard any you like?
I can recommend speakers i like. Emotiva T1/C1/B1, micca 8c atmos speakers would put you under 1k, for subs you could get 2 monolith 12 of amazon for $1280. Would leave some left over for some rear speaker stands for the b1. I would not wall mount b1 as they have a rear port, need about 12” of clearance.
Gold87 is offline
post #11 of 21 Old 07-10-2019, 05:09 PM
pase22's Avatar
Quoted: 3094 Post(s)
Liked: 2574
Those who have done atmos mostly report that 4 overhead speakers is much better that just 2 so maybe a good idea to run wire. SVS are good subs, but there are better value/performance options unless you're outside the US.
What to get speaker wise depends on the layout and desired output levels. If you're putting the speakers behind an AT screen, 3 identical towers behind the screen would be a good option. If putting speakers flanking the display, it would depends on available space. There are a few different ways you can go depending on how you plan the screen/display.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #12 of 21 Old 07-10-2019, 06:11 PM - Thread Starter
rochoa21's Avatar
I had infinity alpha speakers before but other than that I have not heard other speakers.
rochoa21 is offline
post #13 of 21 Old 07-11-2019, 02:57 AM
Quoted: 77 Post(s)
Liked: 38
You can always go listen to some at best buy or if you dont mind buy a couple sets of bookshelf's and listen to them at home. Most places have 30 trails.
Amazon has free returns, emotiva, svs, RSL, best buy, sure there are others that are free.
crunchfeild also does returns bit its cost $10 a pair of book shelfs
Gold87 is offline
post #14 of 21 Old 07-11-2019, 09:39 AM
gajCA's Avatar
Quoted: 8593 Post(s)
Liked: 5791
To do 4 Atmos in ceiling speakers your couch would have to be pulled out a few feet from the wall which may not be feasible so you may be "stuck" with 5.1.2.
Good news is that a 5.1.2 receiver is much cheaper than a 5.1.4 receiver which frees up money for a better sub.
PSB makes great speakers designed using well respected Dr. Floyd Toole's measuring tools and the Imagine series would be within your budget. $10/box returns for stand mount speakers within 60 days at Crutchfield.
Order a pair to see if you like the sound with little financial risk if you do not.
https://www.crutchfield.com/S-DVMGWc...magine-XB.html
RSL also makes very nice speakers with free returns if you prefer and they, in general, seem to have been better received on AVS than the SVS Prime series.
HTD also has free returns and their level three series is very nicely priced and the Klipsch RP series with free returns at Best Buy are also well worth a listen as the newest RP line has been lauded for being not only great sounding but measuring well too.
Geoff A. J., California
gajCA is offline
post #15 of 21 Old 07-11-2019, 01:30 PM
burton14e7's Avatar
Quoted: 54 Post(s)
I was in the same boat two years ago. I had them pre-wire 7.2.4 even though I'm only using 5.1 right now. My only regret is not having dedicate circuits ran to the two sub locations. I'm using SVS's old version of the prime towers and surrounds, I think they were called STS and SSS's or something with a PB13 ultra. It sounds amazing!
WOKNROX likes this.
burton14e7 is offline
post #16 of 21 Old 07-11-2019, 02:08 PM
WOKNROX's Avatar
Quoted: 322 Post(s)
Liked: 228
It's a real shame that electrical power is so often overlooked.
I have come to the conclusion that people just don't believe it make a difference....but it really does.
post #17 of 21 Old 07-14-2019, 03:17 PM - Thread Starter
rochoa21's Avatar
Thanks Ill take a look.
rochoa21 is offline
post #18 of 21 Old 07-19-2019, 04:47 PM
WLDock's Avatar
Quoted: 133 Post(s)
Liked: 171
Emotiva Factory Renewed
Airmotiv T2 Main Pair - $679.15 https://emotiva.com/collections/loud...rmotiv-t2-pair
Airmotiv C2 Center - $359.10 https://emotiva.com/collections/loud...ed-airmotiv-c2
Airmotiv E1 Rear - $242.10 https://emotiva.com/collections/loud...rmotiv-e1-pair
Monoprice Amber Ceiling - $129.99 https://www.monoprice.com/product?c_...ab01690a240612
HSU VTF-2 MK5 Dual subs - $1165 http://www.hsuresearch.com/products/vtf-2mk5.html
$2,577 Total
or
5 x Polk Audio LSiM703 Mains, center, surround - $1495 https://www.adorama.com/g/polkaudio-...hredirect=true
Polk Audio MC80 ceiling - $156 pair https://www.amazon.com/Polk-Audio-Pe...gateway&sr=8-7
$2816
or
5 x CHANE A2.4 mains, center, rear - $1395 https://www.chanemusiccinema.com/A2.4
Radia PD-8CI Planar ceiling - $179 pair https://bgradiadesign.com/product/pd...speakers-pair/
Monolith 12 Dual subs - $1279.98 https://www.amazon.com/Monolith-Inch...IKX0DER&sr=8-2
$2854
Its hard to stay under $2500 going with dual 12" subs unless you find really good deals on speakers, used, or just lower MSRP priced speakers to begin with.
HDTV - Sharp AQUOS LC-70LE600U 70" | AVR- Anthem MRX 300 | Media Player - Fire TV Box 2nd Gen | Blu-Ray/Media/Gaming - PS3-320GB / Xbox One
Speakers - Main - Boston Acoustics Lynnfield VR965 | Center - Boston Acoustics Lynnfield VR920 | Rear - Artison Portrait LRS
| Sub - DIY Stereo Integrity HT 15 | Sub Amp - O Audio BASH 500
WLDock is offline
post #19 of 21 Old 07-19-2019, 06:54 PM - Thread Starter
rochoa21's Avatar
$2,577 Total
or
$2816
or
$2854
Thanks for all the information I’ll take a look. If I start off with a 5.1.2 then later get the 2nd sub that would work for me.
rochoa21 is offline
post #20 of 21 Old 07-19-2019, 07:27 PM
Zorba922's Avatar
Quoted: 6934 Post(s)
Liked: 5221
That is a very good thing, if you want to get the best bang for your buck: SVS has stellar customer service but price to performance ratio is weak compared to other internet-direct companies. Emotiva and Chane would be my first recs for speakers, Hsu or Monolith for subs.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #21 of 21 Old 07-19-2019, 08:06 PM - Thread Starter
rochoa21's Avatar
Copy
rochoa21 is offline
Reply Speakers
