Home Theater Speaker Questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-11-2019, 10:46 AM - Thread Starter
Liked: 0
Hey guys - could use some help and recommendations for a speaker setup that would work best for the area I'm trying to setup a home theater in - it will really just be used for movies, and sometimes live sports. It's an upstairs bonus room that measures 17x28'. It was pre-wired for in-ceiling speakers (7.1 pre-wire), but honestly it's pretty open/easy for me to re-run anything so don't want to be restricted/hung up by that! I'm a huge fan of Klipsch so would love to stay within their products, and ideally would be spending under $3k just on the speakers, but it can be a rough budget - I do have a Klipsch sub already (RW-12D) and a Sony receiver (STRDN1080) that I'd like to use, but if one/both need to be replaced, so be it.
What I'm struggling with is the storage cabinet we have wall mounted on the front wall (picture attached) - it offsets the screen to the right, but it also doesn't give me great space for floor standing speakers, unless I just set them forward in front of the cabinet. Really open to any ideas/suggestions, and really appreciate any help!
Alex Zagrodnik is offline
post #2 of 3 Old 07-11-2019, 12:51 PM
trilkb's Avatar
Quoted: 646 Post(s)
Liked: 324
TV or Projector?
If projector I would DIY a acoustic transparent screen using Seymour AV fabric. Then I would do inwalls for LCR. I helped my dad do his and we went with elac debut inwalls for LCR and it sounds great. Klipsch makes inwalls too.
If TV I would still try inwalls for LCR. Possibly bookshelf speakers but you need them out away from the wall and not on that cabinet where it will reflect sound.
- 6 BA CR6 array center channel, QSC AD-S82 L/R, 4 jbl 8330a surr , 8 jbl 12" subs w/Inuke 6000. JVC rs420, Denon x4000, Sony x800 -
trilkb is offline
post #3 of 3 Old 07-11-2019, 01:08 PM
craig john's Avatar
Quoted: 1172 Post(s)
Liked: 1439
Can it be removed?
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
Reply Speakers
