High-angle tilt speaker mount - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-11-2019, 07:31 PM - Thread Starter
Dalz's Avatar
Question High-angle tilt speaker mount
I'm looking to mount some HSU HB1 Mk2 speakers about 12' high, directly behind a couch. This poses some problems because there are no mounting screw holes on these speakers and I need to angle them down a good 45 degrees or more. Has anyone had any success with a similar setup? The speakers are about 14lbs.
I've seen some commercial mounts that would work, but they are way too big. Everything I've found so far that is a more reasonable size, either doesn't tilt more than about 10 degrees or would struggle to hold the weight.
Thanks for any suggestions!
Dalz is offline
post #2 of 4 Old 07-13-2019, 11:09 AM - Thread Starter
Dalz's Avatar
bump
Dalz is offline
post #3 of 4 Old 07-13-2019, 02:01 PM
RayGuy's Avatar
Quoted: 2608 Post(s)
Liked: 2360
Regular speaker mount, then add one of these:
https://www.amazon.com/45-degree-ang...+angle+bracket
.. or make your own from 1/2 galvanized plumbing pipe, flanges for each end, 45 degree elbow, two short lengths of pipe, and a can of spray paint.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #4 of 4 Old 07-14-2019, 11:33 PM - Thread Starter
Dalz's Avatar
Ah, thanks for the idea. I hadn't considered that!
Dalz is offline
Reply Speakers
