Suggestions for small surrounds to compliment front Sony Core speakers (CS5 and CS8) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-15-2019, 01:34 PM - Thread Starter
syvmn's Avatar
Quoted: 26 Post(s)
I'm setting up a small "theater" in my bedroom. I'll be using the Benq3550, looking at a Denon AVR-X1400H receiver and 5 channel surround probably without a subwoofer for the near future (2 kids under 2yo). I might also throw a set of speakers on the ceiling for Atmos 5.0.2.
I found a steal on the front 3 Sony Core speakers and am looking for suggestions for complimentary speakers of smaller size that could serve as surrounds.
I've always stuck with speakers of the same model series but this time I just don't have room for another set of CS5's.
Suggestions?
syvmn is offline
post #2 of 11 Old 07-15-2019, 02:50 PM
zeuspaul's Avatar
Quoted: 224 Post(s)
Liked: 278
What are your size constraints? I am looking at Cambridge Audio Minx Min 22 to add as surrounds due to their small size. I am waiting to find a deal before I pull the trigger.
HT: PSA MTM-210T front, MTM-210C center, PSA MTM-210T surrounds, PSA MT-110 rears, Atmos / Canton, Ascend CBM-170SE, PSA V1800 , PSA V1801, Marantz SR7009 AVR & Emotiva A-100 stereo amp, Panasonic 65ST60 Plasma, Oppo BDP 93, Sony S1700, Music video: JBL L890, L880, LC2, SVS pc13-Ultra, Yamaha RX-V385, ASUS 31.5" IPS monitor, Sony S1700, Multichannel stereo: PSA MT-110, Bose 901, PSA S1510DF, Denon X1400H, Marantz SR6005
zeuspaul is offline
post #3 of 11 Old 07-15-2019, 03:17 PM
t0md0's Avatar
Quoted: 103 Post(s)
Suggestions?
You might want to look into the JBL B15/Arena 120. Both are the same speaker FYI. I was recommended this from another member and found a set for around $100 at the time for the B15s. The have a shallow footprint. Great for mounting due to the brackets if that's your cup of tea. I've hooked them up as a stereo set up and tbh, they didn't sound bad with a sub. The Core's definitely sounded better, but being that these are being used for surrounds, it was perfectly fine.
I too have your same front sound stage with the CS5 and CS8. All 5 are paired with a JBL 550p sub and a Denon AVR-S740H receiver. Set up is used in my living room. So far, I'm loving it.
t0md0 is offline
post #4 of 11 Old 07-15-2019, 04:50 PM
zieglj01's Avatar
Quoted: 3006 Post(s)
Liked: 2910
Dayton MK402X
https://www.parts-express.com/dayton...-pair--300-465
Who AM I
zieglj01 is offline
post #5 of 11 Old 07-15-2019, 09:41 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1478
Those are $200/pair now and are still a good recommendation, but not as smoking as before.
A few intriguing surround options to search:
PSB Alpha P3
RSL Outsider II
Ascend HTM-200 SE
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Emotiva E2 (2) | Rythmik Audio F12 (2)
Soulburner is online now
post #6 of 11 Old 07-16-2019, 03:02 AM
deafenears's Avatar
Quoted: 14 Post(s)
If you can hold out, @Jon Lane 's been working on the A4.4/A4.5s.
deafenears is offline
post #7 of 11 Old 07-16-2019, 06:14 AM
Transmaniacon's Avatar
Quoted: 1788 Post(s)
Liked: 1627
NHT SuperZero 2.1, $120/pair and sealed so you have more placement flexibility. Great detail and provide a surprisingly big sound stage.
5.1: Samsung PN60F5300 | Sony BDP-S1700 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
2.0: Oppo DV-980H | Apple Airport Express | Topping D30 | Parasound HCA-1500a | Chane A1.4
Transmaniacon is offline
post #8 of 11 Old 07-16-2019, 07:39 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1478
I think those would be okay in a mild system, but too light on bass to mate up with a typical subwoofer crossover. The SuperOnes would be a better blend, but then they get quite a bit larger and too big for on-wall use IMO. Not a big deal if using stands, though. Still smaller than most bookshelves.
Both the SuperOne and the PSB P3 are around $200/pair.
For about the same price as the PSB's, I'd take the PSB's, due to the flatter response, better bass, and slimmer profile. From the measurements I've seen, the NHT will have a little bit of a recessed midrange, whereas the PSB will be flatter through the midrange. I think you want the better midrange for surround effects, especially.
NHT: https://www.stereophile.com/content/...r-measurements
PSB: https://www.soundstagenetwork.com/in...nts&Itemid=153
post #9 of 11 Old 07-16-2019, 07:56 AM
Liked: 1627
I think you’d be okay with some smaller speakers like the NHT SZ for surround duty, they are only playing ambient sound effects, but you’re right they aren’t good for much below 110Hz.
The P3 would certainly work well and the price and size is right, with a higher crossover you shouldn’t need as much space for the port.
post #10 of 11 Old 07-16-2019, 08:33 AM
Quoted: 489 Post(s)
Liked: 260
A4L has new Def Tech ProMonitor 400 3.5" Compact Bookshelf Speaker Black for 33/each...
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #11 of 11 Old 07-16-2019, 10:05 AM
gajCA's Avatar
Quoted: 8809 Post(s)
Liked: 5990
Suggestions?
Why not get a modest sub instead that is very low profile and the bottom firing woofer can't be easily accessed.
Can even be mounted against a wall if you wish.
https://www.monoprice.com/product?p_id=35847
The Cores really need some bass support.
If you got the smaller version you could get some surround speakers too.
https://www.monoprice.com/product?p_...hoCNT0QAvD_BwE
https://www.parts-express.com/restoc...ir--88-300-455
Geoff A. J., California
gajCA is offline
Reply Speakers
