Subwoofer upgrade - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-16-2019, 11:03 AM - Thread Starter
Liked: 0
Subwoofer upgrade
I have polk lsim704c center tsi500 mains tsi200 surrounds yamaharxv383 receiver and bic pl200ii sub, thinkin of adding a second pl200 with sub cable splitter, or should i just upgrade to a better sub in general?
Lto842214 is offline
post #2 of 2 Old 07-16-2019, 11:10 AM
gajCA's Avatar
Quoted: 8581 Post(s)
Liked: 5782
Please use a computer; this is what your post looks like:
Subwoofer upgrade
Do your front speakers justice and sell your BIC sub and get one of these or their bigger brothers.
PORTED SUBWOOFERS $600 AND BELOW, DELIVERED
NOTE:
*THE LARGER PORTED SUBS DELIVER AT LEAST 40% MORE SOUND PRESSURE LEVEL
THAN THE SAME BRAND'S SEALED VERSION WITH SAME SIZE WOOFER AND AMP
*IF LOOKING AT LARGER/MORE EXPENSIVE SUBWOOFERS ADD PSA TO THE LIST OF BRANDS
*IF YOU ARE NOT AN ACTION MOVIE FAN A SUBWOOFER WITH 22-30HZ EXTENSION WOULD BE FINE
*FOR MUSIC A 30HZ SUB IS A FINE CHOICE
*BEFORE BUYING MAKE A CARDBOARD CUTOUT OF THE SIZE OF THE SUB TO MAKE SURE IT IS NOT TOO LARGE FOR YOU
Specs are from the manufacturer unless noted otherwise.
Warranty
for AMP
2 years 350watts =15w16h17d= 40 lbs 10" [30hz] $399 RSL SPEEDWOOFER 10S, (extension from Sound & Vision review)
2 years 250watts =15w19h17d= 42 lbs 10" [25hz] $455 HSU VTF 1 MK3 (extension from Audioholics review)
5 years 300watts =15w19h20d= 46 lbs 10" [18hz] $499 SVS PB1000, (extension from Sound & Vision Review)
5 years 500watts =15w19h20d= 72 lbs 10" [20hz] $500 MONOPRICE MONOLITH THX 10"
3 years 300watts =16w22h21d= 69 lbs* 12" [19hz] $569 RHYTHMIK LV12F
2 years 350watts =15w21h22d= 62 lbs 12" [18hz] $607 HSU VTF2 MK5, (extension from Audioholics review)
* = shipping weight
Geoff A. J., California
gajCA is offline
Reply Speakers
