Definitive Technology BP9080 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By tuner1129
  • 1 Post By Russdawg1
post #1 of 5 Old Yesterday, 08:28 PM - Thread Starter
mantaraydesign's Avatar
Quoted: 266 Post(s)
Liked: 45
Quick questions about the LFE INPUT (OPTIONAL) connection on the back of each speaker. If you don't use the LFE INPUT (OPTIONAL), does the subwoofer still work for a 2 channel music listening? Or the powered subwoofer will not work unless you use the LFE INPUT (OPTIONAL) connection on the back of the speaker?
I am trying to figure out if I can use these speakers without the powered subwoofer. Just use them as full-range speakers with the subwoofer but no powered subwoofer connection.
Thanks for any advice!
mantaraydesign is offline
post #2 of 5 Old Yesterday, 08:46 PM
tuner1129's Avatar
Quoted: 185 Post(s)
Liked: 180
That's a great question, I have the older 8060. I know I have tried them and they do work without the LFE connected. But not sure if the new ones have that aswell. But I am curious now to put my receiver in full range on those without LFE.
Sent from my SM-G975U using Tapatalk
mantaraydesign likes this.
tuner1129 is offline
post #3 of 5 Old Yesterday, 09:12 PM
Quoted: 1482 Post(s)
Liked: 1067
They are meant to work without the LFE in, so feel free to use them for 2.0 listening.
Leave it at 8 ohms and call it a day :)
Russdawg1 is offline
post #4 of 5 Old Yesterday, 09:34 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 45
Or you can do a Pure Direct mode from your receiver.
post #5 of 5 Old Yesterday, 09:38 PM
tuner1129's Avatar
Quoted: 185 Post(s)
Liked: 180
I will try this tomorrow and test. Never thought of doing this, I am always missing mid bass and hopefully the subs take that task as these 4" cannot do.
Reply Speakers
