New build advice - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #31 of 51 Old 08-02-2019, 04:55 AM
Zorba922's Avatar
Quoted: 7093 Post(s)
Liked: 5401
Originally Posted by jorisdriesen View Post
As it looks now (plans have changed) I will be doing my HT in the attic. Much smaller space, width is about 12'6". Crosssection: https://imgur.com/a/ETlfBEj
I don't know how this impacts the sub selection, but would you still adivise 2x PB-2000 over 1x PB-4000 in this room ?
I'd start with one PB2000, add a second if needed. Attic = empty space under floor = huge bass suck-out.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #32 of 51 Old 08-02-2019, 05:07 AM - Thread Starter
Quoted: 53 Post(s)
Ahh crap, didn't realize that...
Will definitely need more than 1x PB-2000 most probably. So better 2x PB-2000 than 1x PB-4000 ? PB-4000 looks so nice, which alone is worth the price difference to me but ofc if most agree that 2x PB-2000 will give a better overall performance, then I will go with 2x PB-2000.
jorisdriesen is offline
post #33 of 51 Old 08-02-2019, 06:17 AM
Quoted: 327 Post(s)
Liked: 217
Not to through things off track, but a single PB 4000 is $1900 new. Two PB 2000 about $1600.
For $1800 you could be looking at two VTF-15H MK2 from Hsu.
These are comparable in performance to the PB 4000, but you'll get the benefit of duals on top. No compromising this way.
5.1: Power - Denon 4308ci, Fronts - Def Tech BP9040's, Center - Def Tech CLR 2000, Surrounds - Def Tech PM1000's, Sub's - Rythmik E15HP x2, Display - Panasonic TC-55AS530U, TT - Rega Planar 2 w/ Dynavector 10x5
derekmoore is offline
post #34 of 51 Old 08-02-2019, 06:49 AM
Zorba922's Avatar
Liked: 5401
Originally Posted by derekmoore View Post
For $1800 you could be looking at two VTF-15H MK2 from Hsu. These are comparable in performance to the PB 4000, but you'll get the benefit of duals on top. No compromising this way.
OP is in Europe, Hsu not available there.
Zorba922 is offline
post #35 of 51 Old 08-02-2019, 06:52 AM
Zorba922's Avatar
Liked: 5401
Ahh crap, didn't realize that... Will definitely need more than 1x PB-2000 most probably. So better 2x PB-2000 than 1x PB-4000 ? PB-4000 looks so nice, which alone is worth the price difference to me but ofc if most agree that 2x PB-2000 will give a better overall performance, then I will go with 2x PB-2000.
Of course, the PB4000 like all of SVS's top-end subs is sold mainly on looks and electronic bells and whistles...the PB1000 and 2000 are more functional, utilitarian devices. I would start with a single PB2000, very easy to add a second later unless your dealer is offering you a great dual sub discount.
gajCA likes this.
Zorba922 is offline
post #36 of 51 Old 08-02-2019, 07:45 AM
Quoted: 327 Post(s)
Liked: 217
Dang. I missed that he's in the EU. I know options are more limited there for sub's.
post #37 of 51 Old 08-02-2019, 07:46 AM - Thread Starter
Quoted: 53 Post(s)
Didn't consider this because as mentioned above, I read several times that these are not available in Europe. PB-4000 is $2900 here by the way, and two PB-2000 $2000.
post #38 of 51 Old 08-02-2019, 07:51 AM
Quoted: 327 Post(s)
Liked: 217
^ wow. Super pricey.
With the cost factored in, I'd go with dual PB2000. You could always add a third if needed for the same price as one pb4000.
post #39 of 51 Old 08-02-2019, 08:07 AM - Thread Starter
Quoted: 53 Post(s)
Yeh I think i'll do that. Just wanted to have it re-confirmed that dual PB-2000 is still the way to go, over 1x PB-4000.
post #40 of 51 Old 08-02-2019, 08:51 AM - Thread Starter
Quoted: 53 Post(s)
For the Atmos speakers, I'm considering now these Klipsch: https://www.klipsch.com/products/cs-16c-ii
Can't find any review on those, but would the 35 Watt power be enough for Atmos speakers ?
post #41 of 51 Old 08-02-2019, 11:45 AM
gajCA's Avatar
Quoted: 8974 Post(s)
Liked: 6139
Should work just fine: Power Handling 40W RMS / 160W Peak
jorisdriesen likes this.
Geoff A. J., California
gajCA is offline
post #42 of 51 Old 08-06-2019, 09:27 AM - Thread Starter
Quoted: 53 Post(s)
Next question for my followers: the side walls (roof) in the attic are ofc under 45° instead of perfectly vertical. Would you just build in the atmos speakers into the drywall and let them fire under 45° or would you build some sort of box to have the speakers fire perfectly downwards ?
post #43 of 51 Old 08-06-2019, 12:30 PM
gajCA's Avatar
Liked: 6139
An in ceiling speaker like this where the tweeter and mid woofers are angled might be a better choice.
https://rslspeakers.com/products/c34...iling-speaker/
Or a pendant speaker.
https://www.crutchfield.com/S-eidq9g...hoC2ewQAvD_BwE
gajCA is offline
post #44 of 51 Old 08-08-2019, 12:28 PM - Thread Starter
Quoted: 53 Post(s)
Pendant speakers are a no-go bc of how they look.
Will search for some pivoting in-ceiling speakers that are affordable, can't pay $300 each now like the Klipsch CDT-5800-C II from Youthman.
post #45 of 51 Old 08-16-2019, 03:15 PM - Thread Starter
Quoted: 53 Post(s)
I'm thinking of positioning the surrounds just behind the wall, with the front side sticking through, to save some walking space in the theater room. Do you think that this will affect the sound quality bc the backside isn't really in the room anymore ?
post #46 of 51 Old 08-18-2019, 10:36 PM - Thread Starter
Quoted: 53 Post(s)
Guys,
since I'm going with an AT screen now, I'm reading that using an identical tower as center speaker would acoustically be better than the center speaker model. Would you agree ? If so, I will replace the RP-504C in my list with a 3rd RP-6000F tower.
Would you also say that the RP-6000F's are sufficiently strong for this room size, or would you opt for the RP-8000F ? 8000F looks better (aspect ratio), but is a quite a bit more expensive here.
**edit** will also go with 4x Micca M-8C as in-ceiling Atmos speakers.
post #47 of 51 Old 08-19-2019, 09:53 AM
gajCA's Avatar
Liked: 6139
Guys,
Yes, a third RP6000F would be ideal and as you are sitting less than 14 feet away there is very little chance that going to the larger towers would make any difference in terms of capability with subs in the mix.
gajCA is offline
post #48 of 51 Old 08-19-2019, 10:08 AM - Thread Starter
Quoted: 53 Post(s)
That's a very complete answer, thanks !
gajCA likes this.
post #49 of 51 Old 08-19-2019, 10:20 AM - Thread Starter
Quoted: 53 Post(s)
Any opinion on the surrounds being placed "behind" the wall with their front sticking through ? Will this cancel the effect of the back outlet port in the speaker ?
post #50 of 51 Old 08-19-2019, 10:25 AM
gajCA's Avatar
Liked: 6139
It is unusual but using subs crossed over at 80-100hz the back port doesn't actually come into effect like it would when running full range with no sub.
Another plus for the RP6000F, at least for me, compared to the RP80000F is the tweeter height.
The tweeters are about 38" high and 41" high resectively and unless you have an unusually tall couch 38" might be closer to your seated ear height.
gajCA is offline
post #51 of 51 Old 08-19-2019, 11:08 AM - Thread Starter
Quoted: 53 Post(s)
It just keeps raining questions here
For the in-ceiling speakers: as you can see I'm in the attic with non-horizontal ceiling (skew?). Dolby recommends to have the height speakers in-line with the fronts. In my case that means that the "height" speakers are only just above listening position. So I need to bring them more inside to be able to put them higher. Do you know of a guideline about where to place them ? The higher I go, the more inside they will be, so there must be a sweet spot somewhere.
Reply Speakers
