In Wall L-R + Either In Wall Center or Shelf Center - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By highmr
  • 1 Post By Zorba922
post #1 of 12 Old 07-23-2019, 07:06 PM - Thread Starter
eaud's Avatar
So in our basement we are looking at converting a closet into an in wall media rack, above which the TV will hang. My wife prefers in wall speakers for the left and right speakers.
As to the center.... because the center will be below the TV where the closet used to be, we could use either an in wall center or build a shelf and house a center speaker on the shelf.
Haven't decided on budget yet, but let's assume we spend $500-$700 on the center. Would we get best bang for buck by buying in wall or a center for a built-in shelf below the TV? I suppose the other issue is that the L-C-R should match, and don't know whether a lot of manufacturers sell in walls that acoustically matching centers that aren't in walls. Thanks!
eaud is online now
post #2 of 12 Old 07-23-2019, 07:29 PM
Quoted: 401 Post(s)
Liked: 344
Are on walls an option? HTD Versa's are very nice and can be customized to match decor.
https://www.htd.com/VERSA-HTS1
cocrh is offline
post #3 of 12 Old 07-23-2019, 07:40 PM
Zorba922's Avatar
Quoted: 7054 Post(s)
Liked: 5358
If you can do a built-in shelf below the TV, definitely the better option...go with a sealed cabinet or front-ported center speaker and you're all set. The L/R can be sealed or front ported bookshelf speakers.
For example:
https://www.nhthifi.com/products/165...enter-speakers
Free return shipping on this one:
https://rslspeakers.com/products/cg2...enter-channel/
If you want 3 identical fronts, very compact and easily wall mountable but playing much bigger than their size:
http://www.ascendacoustics.com/pages...00/htm200.html
In-walls are an option of absolute last resort---basically, if your spouse is holding a gun to your head.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #4 of 12 Old 07-23-2019, 08:23 PM - Thread Starter
eaud's Avatar
Thanks to both of you. Yes, on walls are an option. Because for the center we have the built-in shelf we can easily do below the TV, my wife definitely prefers to have the sides be in wall. But it isn't non-negotiable.
eaud is online now
post #5 of 12 Old 07-23-2019, 09:56 PM
Zorba922's Avatar
Liked: 5358
NHT unlike Ascend and RSL does make in-walls that you could use with their center:
https://www.nhthifi.com/products?cat...-wall-speakers
But if your wife can be coaxed into accepting on-walls for the L/R, the Ascend 200SE x 3 identical front stage would likely deliver the best price to performance ratio by far, leaving you with more money to put into a quality sub which any chosen setup would require no matter what.
Zorba922 is offline
post #6 of 12 Old 07-23-2019, 11:13 PM
zieglj01's Avatar
Quoted: 3001 Post(s)
Liked: 2905
You said your budget was 500 to 700 dollars for the center ... for $50 over and some higher-end signature sound, look at the Revel Concerta2 C25 ... but using another S16 as a center would be cheaper and work real good
https://www.crutchfield.com/p_265C25...oss-Black.html
For Left and Right on-wall -- the Concerta2 S16 .... sold each
https://www.crutchfield.com/p_265S16...oss-Black.html
Also sold in White
https://www.crutchfield.com/p_265C25...oss-White.html
Left and Right
https://www.crutchfield.com/p_265S16...oss-White.html
Lower-end in-wall
Revel 253 for Left, Center, and Right channels
https://www.crutchfield.com/p_265W253L/Revel-W253L.html
the W263
https://www.crutchfield.com/p_265W263/Revel-W263.html
Higher-end in-wall
Revel W553
https://www.crutchfield.com/p_265W55...vel-W553L.html
Revel W763
https://www.crutchfield.com/p_265W763/Revel-W763.html
Who AM I
zieglj01 is online now
post #7 of 12 Old 07-23-2019, 11:24 PM
highmr's Avatar
Quoted: 105 Post(s)
Liked: 66
For Revels, JBLs, and a few others, you can see Spinorama data here:
https://speakerdata2034.blogspot.com/
I have a center M16 and in wall W763s for similar reasons as the OP. (Note, I had space behind the speaker, so the position of the port is not a large issue.) Based on the Spinoramas, the M105 may have been a better choice than the M16 (with a subwoofer in play). Speakers designed as horizontal center speakers have a harder time, until you get to the really expensive ones (IE compare M105 and M16 to C25 and C205). If you have the vertical space for a vertical regular speaker in the center, you can get more bang for the buck. Still try to get the tweeter relatively close to the listener in the vertical direction, and angle it as needed to aim at the listener's ears. Also, don't hide the speaker deeply in a cabinet.
zieglj01 likes this.
Living room: Samsung PN60F8500, Sony X800M2, Roku Premiere+, Revel W763, Revel M16, Hsu HB-1 MK2, RSL C34E, Rhythmik D15SE, Denon X4200W; Zone 2: Speaker selector, Yamaha RX-V495 (1999); Bedroom: Panasonic P50U54, Oppo BDP-80, Chromecast Audio, Advent Legacy III (1994), Denon 2310ci; Cabin: Roku 3, NHT Super Zero (1996), Hsu VTF-2 MK4, Denon 1712
highmr is offline
post #8 of 12 Old 07-24-2019, 12:04 AM
fbov's Avatar
Quoted: 281 Post(s)
Liked: 166
You want to use all in-wall speakers.
- you get a 6dB boost at low frequencies, reducing stress on the woofer
- frequency response is much smoother.
http://www.htguide.com/forum/showthr...peaker-Designs
Scroll down a little until you find the charts from Floyd Toole's book.
- the first pair show why you want an in-wall speaker that's designed as an in-wall speaker. It won't have the LF hump.
- the rest of the charts show why you never want to put box speakers on a wall, then on a shelf, then in a cubby.
Can't speak for brands; I build my own.
HAve fun,
Frank
fbov is offline
post #9 of 12 Old 07-24-2019, 12:34 AM
soundadvice's Avatar
Liked: 0
You definitely want identical speakers across the front (and back for that matter). Triad is the only company that manufactures the same speaker in multiple mounting formats. You can get their bronze LCR (which is dead center of your price range) in both in-wall and in-room versions, as well as on-wall and in-ceiling, which might or might not come in handy for Atmos.
soundadvice is offline
post #10 of 12 Old 07-24-2019, 05:48 AM
Dawn Gordon's Avatar
Quoted: 383 Post(s)
Liked: 241
Great example. Plus Triad will also paint match the speakers or grills to the color on your wall.
________________________________________
[email protected]
Dawn Gordon is offline
post #11 of 12 Old 07-24-2019, 08:41 AM
Quoted: 485 Post(s)
Liked: 254
check out axiom audio. they have in walls with integrated back boxes. - lots of models to chose from, although several are way above your budget. they also make "in cabinet" versions.
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is online now
post #12 of 12 Old 07-24-2019, 09:57 AM
Zorba922's Avatar
Liked: 5358
This is what 3 identical on-wall speakers looks like...the ones in the picture are quite big (Jamo D600) so imagine the much, much smaller Ascend 200SE or RSL CG34 instead. Will save you the considerable expense and hassle of drilling into the walls, running cables through the walls, and leaving the speakers behind when you move, too. Not to mention that in-walls are a huge pain in the @ss to return in case you find that the ones you've gone through all that hassle and expense for actually aren't your cup of tea.
Take with a truckload of salt all the ivory-tower talk about "ideal" requirements of having identical speakers all around, expensive in-walls with well-designed backboxes (most in-walls don't have back-boxes, the one which do can indeed sound very decent but will cost you a pretty penny compared to similar performance from an on-wall or standmount speaker)...this hobby (or rather this INDUSTRY) encourages OCD "requirements" and fixation on academic specs, but life in the real world is a different matter.
People do affordable on-wall speakers, use different manufacturer rear surrounds, and otherwise disregard all the ivory-tower gibberish all the time and the sky has never fallen nor have their eardrums exploded.
Name:	On-wall 3 identical LCR.jpg
fbov likes this.
Zorba922 is offline
Reply Speakers
