Portable Speakers for Camping - AVS Forum | Home Theater Discussions And Reviews
 12Likes
  • 1 Post By MIX_MASTER_ICE
  • 1 Post By Banks1
  • 1 Post By b curry
  • 1 Post By adam2434
  • 1 Post By ggilman
  • 1 Post By Mamasboy
  • 1 Post By sigpig
  • 1 Post By Pete7874
post #1 of 26 Old 07-23-2019, 07:31 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
Looking for a good portable speaker for camping/backyard use. Currently looking at Demerbox and a Marshall Kilburn II.
Any recommendations on those or others?
I'll be using my iPhone (7+) with downloaded playlists through Tidal. Prefer the option to hardwire as opposed to bluetooth. Think I'd need a DAC/Amp as well?
thanks!
gg
ggilman is offline
post #2 of 26 Old 07-23-2019, 07:54 PM
MIX_MASTER_ICE's Avatar
Quoted: 2668 Post(s)
Liked: 2477
What is your budget and size requirements?
MIX_MASTER_ICE is offline
post #3 of 26 Old 07-23-2019, 08:12 PM
Quoted: 1738 Post(s)
Liked: 1338
If you aren’t against an hour or two of assembly, the AIY Kit “The Blast Box” on Parts Express for $250 is a fricken steal!
Bluetooth (with option to be hardwired with aux), 200 watts, 5 driver design (with dedicated subwoofer!), battery lasts very long.
Paint it black or leave it wood, it will be weather resistant being completely sealed.
Highly recommend it!
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #4 of 26 Old 07-23-2019, 08:13 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
Open to spending more if it’s worth it, but ideally < $500.
Size not as important, but the Demerbox & Marshall look about right to me.
ggilman is offline
post #5 of 26 Old 07-23-2019, 08:17 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
Originally Posted by Russdawg1 View Post
If you aren&#226;€&#x2122;&#xfe0f;t against an hour or two of assembly, the AIY Kit &#226;€œThe Blast Box&#226;€ on Parts Express for $250 is a fricken steal!
Sounds very cool! I’m not that savvy a maker, so I’m not sure it’s the right route for me, but I’ll check it out!
ggilman is offline
post #6 of 26 Old 07-23-2019, 09:08 PM
Liked: 2477
The Sony gtk-pg10 would be a great option. It's going for around $170 right now. I've come ever so close to buying one a few times and probably will get one eventually. It's a cool system tailor made for what you are looking for.
ggilman likes this.
post #7 of 26 Old 07-24-2019, 04:58 AM
Banks1's Avatar
Quoted: 63 Post(s)
Liked: 76
JBL Charge 4 is good.
ggilman likes this.
Banks1 is offline
post #8 of 26 Old 07-24-2019, 08:39 AM
Quoted: 555 Post(s)
Liked: 291
check out : https://ecoxgear.com/
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #9 of 26 Old 07-24-2019, 08:50 AM
b curry's Avatar
Quoted: 1025 Post(s)
Liked: 649
thanks!
gg
I would go with the Kilburn. I have a Marshal Stanmore and it's outstanding. The units are very well built and sound great.
ggilman likes this.
b curry is offline
post #10 of 26 Old 07-24-2019, 10:53 AM
adam2434's Avatar
Quoted: 330 Post(s)
Liked: 160
I know you said portable, but does it need to run on battery, or is AC ok?
Reason I ask is because I recently picked up a Riva Festival refurb for $150 at Monoprice.
It's not battery powered or weatherproof, but it is a versatile, good sounding speaker.
We used it last week at a vacation cottage (both inside and outside) and I was pleased with the sound quality. I took a smaller battery powered BT speaker when we went to the beach.
It can connect via wi-fi, BT, optical, or aux.
A cool feature I discovered is that its Away Mode (where it creates its own wi-fi network) allowed me to play music from the ~200 gb FLAC library on my phone using the Hi-Fi Cast app...streaming FLAC over wi-fi with no BT compression. I thought this was pretty cool, as it is a no-compromise way of streaming. Other times, we just used Spotify with BT, which also sounded good.
Anyway, since you're talking about Tidal and a separate DAC, I'm thinking that sound quality is a key factor for you, perhaps over portability and weather resistance. If so, the Riva Festival might be worth checking out, especially at the $150 refurb price.
ggilman likes this.
5.1 and 2.0 ch: Marantz AV7704/Emotiva DC-1/Rotel RB-1582 MKII/Audiosource Amp Three x 2/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage and Dayton IO655 on patio. 2.1 ch: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2. 2.0 ch: Outlaw 975/Outlaw M2200 x 2/Klipsch RF-7 III/Sony ES BDP/LG 65" LED. 2.0 ch: Klipsch Powergate/NHT SB3. Kitchen: Sonos Play5.
adam2434 is offline
post #11 of 26 Old 07-24-2019, 01:35 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
Thanks for the rec! I was leaning towards a Marshall. I trust the name, but curious if anyone had one. Thanks!
ggilman is offline
post #12 of 26 Old 07-24-2019, 02:59 PM
Liked: 2477
I wish you didn't create this thread. You just cost me some $$...lol. Got this baby unboxed and set up earlier today. Sounds good with solid bass. Uses the Sony Music center app where you can also use a custom 7 band eq or one of the presets. I give this a thumbs up for being a very solid system.
ggilman likes this.
post #13 of 26 Old 07-24-2019, 05:09 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
Sorry!
MIX_MASTER_ICE likes this.
ggilman is offline
post #14 of 26 Old 07-24-2019, 05:31 PM
Liked: 2477
Sorry!
No worries. The PG10 is a great little system, but in the "truly" portable systems I still give the advantage to the LG RK8 and like it better. I believe that is still available for under $300. Really slick boom-box that does about everything.
ggilman likes this.
Subs>RBH I-12e, I-12. HSU VTF-15H mk2. Monolith THX 12(x2), THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2,V6, XB900n,700,XB32,XB31. Sennheiser HD58X, HD4.50, PC37X. Philips SHP9500. SIVGA SV004. Status Audio HDTwo. HyperX Cloud PS4. TB Elite Atlas Aero. LG FH6,RK8,RK7,PK5. HK Onyx Studio4(x2).
post #15 of 26 Old 07-24-2019, 05:46 PM
Mamasboy's Avatar
Quoted: 192 Post(s)
Liked: 69
Costco always has a few large outdoor camping BT speakers that I eyeball everytime a walk the cart past them.
ggilman likes this.
I feel infinite
Mamasboy is offline
post #16 of 26 Old 07-24-2019, 06:14 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
That kit looks amazing. I'm tempted to grab it, but I'm not convinced it will go well. Love all the mods!
ggilman is offline
post #17 of 26 Old 07-25-2019, 06:07 AM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
Does anyone know of any portable speakers that will pair for stereo? If the Marshall's would I'd buy two right now.
ggilman is offline
post #18 of 26 Old 07-25-2019, 08:28 AM
Quoted: 833 Post(s)
Liked: 671
The UE "Boom" series of portable speakers can be paired through their phone app to produce stereo sound. They are quite affordable and have pretty good sound quality, especially for their size.
ggilman likes this.
sigpig is offline
post #19 of 26 Old 07-25-2019, 08:30 AM
Liked: 2477
Kilburn II does not have multi-speaker wireless connectivity. For connecting two or more speakers, the JBL speakers have the easiest and quickest set up for multiple speakers. I like the Sony speakers better than the JBL, XB32 over the Charge 4 for example, but it's more cumbersome to set it up compared to the simple one touch button on each JBL speaker.
ggilman likes this.
post #20 of 26 Old 07-25-2019, 10:34 AM
adam2434's Avatar
Quoted: 330 Post(s)
Liked: 160
That Sony sounds pretty good, you say?
Pretty balanced across highs, mids, and bass?
Decent bass punch?
adam2434 is offline
post #21 of 26 Old 07-25-2019, 04:03 PM
Liked: 2477
Originally Posted by adam2434 View Post
That Sony sounds pretty good, you say? Pretty balanced across highs, mids, and bass? Decent bass punch?-
Yeah, the PG10 is a very cool little system. Nice bass and overall solid sound quality. Sounds better with the table-top speakers folded out.
I have the Sony XB32 and XB31 and they have very solid bass for their size. I also have the Ultimate Ears Boom 3 and LG PK5 and those don't quite match up to the bass of the Sony speakers. The Sony XB41 is available and is a bit bigger and will play a bit louder, basically just being the bigger version of the same thing. The Sony has three different sound modes you can use and further adjust/tweak the sound with a custom EQ used in conjunction with those modes.
One thing to note is I don't think Sony, Ultimate Ears or JBL speakers allow you to connect two speakers together using the 3.5mm line in connection as your audio source. In fact, UE speakers don't even have a 3.5mm jack, at least not the latest models.
ggilman likes this.
post #22 of 26 Old 07-26-2019, 04:16 AM
adam2434's Avatar
Quoted: 330 Post(s)
Liked: 160
Cool, thanks. Might have to check one out.
adam2434 is offline
post #23 of 26 Old 07-26-2019, 06:18 AM
Red MC's Avatar
Quoted: 273 Post(s)
Liked: 219
Check out Minirigs (https://minirigs.co.uk/)
I went through the same selection process two months ago, looking for wireless portable speakers primarily for camping. I wanted something with good stereo sound, that was easy to pack, with enough battery life to last the whole trip, and it had to be at least somewhat rugged and weatherproof so it could survive being dropped in the dirt or left out in the rain. After a lot of searching, I ended up buying a pair of Minirig 3s + subwoofer:
They are compact, about 4" diameter and 3" high. They can be paired for stereo. They can play loud and they have good clean sound. Their sound quality and maximum loudness is a step up from any portable speaker I've heard in the same size range. They are splash proof and can survive a drop. And they have outstanding battery life.
There is an optional subwoofer that's about 4" diameter and 9" long which is nice for outdoor use where other small portable speakers tend to sound weak in the bass. You can use a single sub with a single speaker (1.1), a single sub with a stereo pair (2.1), or two subs with two speakers (2.2) if you really need to max out the volume.
They come in zippered protective sleeves with wire pockets for easy packing. Inputs are Bluetooth and a headphone jack. There is a phone app which offers an equalizer and subwoofer level control.
I'm super happy with how they turned out. They may be my favorite piece of camping kit, up there with my Cobb BBQ. I love the versatility. I can set them on a picnic table across from me about 4' apart and enjoy a nice near field stereo setup while I'm working on dinner prep. Or place them on the ground about 10-15' apart on the other side of the camp fire so the family can enjoy a stereo listening experience while basking in the fire. Or put them on opposite sides of the camp site, facing in, configured in mono, and have sound everywhere as you're setting up or breaking camp. A single Minirig 3 can fit into the pocket of most of my athletic shorts, or a cargo pocket, so I'd throw one in there when taking my kids to a playground, or for a walk down to the lake shore so we can listen to a little music while the sun sets.
There is also a smaller Minirig Mini, which is more comfortably pocketable, and better for backpacking. But it has a lot less battery life and not much bass unless you add a sub.
There are two downsides. The first is cost:
£269.95 for a pair of the Minirig 3
£389.95 for a pair of the Minirig 3 + subwoofer
The second is that the treble response is directional, especially the top octave. If I point them directly at me, they sound bright on axis and I want to reduce the treble using the EQ. If I place them on their back facing up, and then listen from the side, the top octave is rolled off and I want to increase it using the EQ. The treble balance is most neutral when listening about 45 degrees off-axis, which leads me to believe that Minirig tried to find a compromise between what's best for different orientations.
I discovered the Minirigs from an Austrian YouTuber named Oluv. He has reviewed tons of portable speakers and records them in binaural sound. You should definitely check out his channel:
https://www.youtube.com/channel/UC7D...jBd5ZtLQU3Z1dQ
He also has a site where you can A/B compare his recordings of different portable speakers:
http://switcher.oluvsgadgets.net/
He has posted a number of videos with the Minirigs. Here are two. In the first one, he compares a Minirig 3 2.1 setup vs. the very good Aiwa EXOS-9 boom box. The second features Minirig Minis.
HT: Dynaudio C2, Contour S CX, 2x BM14S, Aperion surrounds, Simaudio Titan, Marantz AV8801, Oppo 103, Linn Majik DS, and a Pioneer Kuro
Stereo: Dynaudio Focus 160, Simaudio W-5 LE or Luxman M-600A, Linn Akurate DSM, 2x Rythmik F12G
Other interests: motorcycling, skiing, being active
Red MC is offline
post #24 of 26 Old 07-26-2019, 07:00 AM
Pete7874's Avatar
Quoted: 293 Post(s)
Liked: 176
JBL Xtreme can be paired for stereo and is a pretty good sounding speaker for outdoors, and not gigantic. Currently on sale for about $160 each:
https://www.harmanaudio.com/sale/XTR...urrent#start=1
EDIT: Oops, looks like they're backordered from the link above. Amazon has them in stock for a bit more.
ggilman likes this.
"The problem with quotes on the Internet is that you never know if they're real." - Abraham Lincoln
Samsung UN55B7100  Denon AVR-S740H  Chane A2.4  Dayton MK402X  Premier Acoustic PA120  Roku Premiere Plus  Squeezebox Classic  CCA
Pete7874 is online now
post #25 of 26 Old 07-27-2019, 06:28 PM - Thread Starter
Quoted: 13 Post(s)
Liked: 1
https://www.youtube.com/watch?v=3NRl5ME2_AU
https://www.youtube.com/watch?v=IIvd97fQCqI
Thanks for the suggestion! I'll check them out. You sure you don't work for the company?
ggilman is offline
post #26 of 26 Old 07-29-2019, 01:30 PM
Red MC's Avatar
Quoted: 273 Post(s)
Liked: 219
LOL. Yeah, I'm enthusiastic. I've made some good choices in camping gear and some wrong ones. The Minirigs were definitely a good one.
FWIW, my original first choice was the Denon Envaya DSB-250. The Denon sounds really good for its size, and it's small enough to carry in one hand. I probably would have bought two of them, but even a single one gives you some sense of stereo separation. I didn't buy it because I read a lot of reports of early battery failures and trouble with stereo pairing.
Another decent choice is the JBL Xtreme 2. It's got a noticeable bass thump when used indoors, but outside it should do well. A pair of them would be good for stereo, albeit bulky to pack and carry two of them.
Red MC is offline
Reply Speakers
