where can i find someone that can open my walls - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By bear123
  • 1 Post By Zorba922
  • 1 Post By mmiles
post #1 of 14 Old 07-23-2019, 10:36 PM - Thread Starter
Quoted: 44 Post(s)
Liked: 0
where can i find someone that can run additional rca/hdmi/cat6 speaker cables inside my walls to a closet?
Tony Wong is offline
post #2 of 14 Old 07-24-2019, 02:02 AM
bear123's Avatar
Quoted: 2658 Post(s)
Liked: 4152
bear123 is offline
post #3 of 14 Old 07-24-2019, 02:13 AM
Seilerbird's Avatar
Quoted: 207 Post(s)
Liked: 217
You need an electrician. You can usually find a local one on Craigslist.
LG OLED55C6P
Sony STRDH770, Sony UBP-X800, Sony PS3 160
2 - Polk TSi300, 1 - Polk CS10, 4 - Polk T15, 1 - Polk PSW125
Seilerbird is offline
post #4 of 14 Old 07-24-2019, 11:06 AM - Thread Starter
Quoted: 44 Post(s)
Liked: 0
but this would involve cutting walls, running cables through joists etc.... closing holes
post #5 of 14 Old 07-24-2019, 11:06 AM - Thread Starter
Quoted: 44 Post(s)
Liked: 0
cables
post #6 of 14 Old 07-24-2019, 01:18 PM
Seilerbird's Avatar
Quoted: 207 Post(s)
Liked: 217
A good electrician will have no problem doing that. I have ran lots of wires into preexisting walls. It is not rocket science.
LG OLED55C6P
post #7 of 14 Old 07-24-2019, 02:53 PM
Zorba922's Avatar
Quoted: 7172 Post(s)
Liked: 5474
yep, and this is why I always recommend just using wall-mounted compact bookshelves instead...screw WAF and OCD aesthetics because these will sound much better (unlike in-walls/ceilings they are a snap to swap out if unhappy), cost much less, and you don't have to leave the speakers behind when you move.
doni01 likes this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #8 of 14 Old 07-27-2019, 11:22 AM
Fitero's Avatar
Quoted: 32 Post(s)
Liked: 30
In my experience, typical line-voltage electricians can do any retro-fit wiring project that you need, but this is not what they do best. They don't have the tools and patience to retrofit wiring in a house without relying upon cutting holes in sheet-rock.
The real experts in this are low-voltage, custom installation people. You would be surprised where wiring can be fished without cutting holes in the sheet-rock.
Make a call to a local home-theater shop. They will have people or know people who can do this type of work for you.
Fitero is offline
post #9 of 14 Old 07-28-2019, 10:16 AM
mmiles's Avatar
Quoted: 1006 Post(s)
Liked: 516
Still got to get a wire to the said wall mounted bookshelf speaker.
Mike Miles
[email protected]
mmiles is online now
post #10 of 14 Old 07-28-2019, 10:35 AM
RayGuy's Avatar
Quoted: 2866 Post(s)
Liked: 2632
True, but the wire can be hidden by using flat wire or a paintable wire raceway.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #11 of 14 Old 07-28-2019, 10:37 AM
Zorba922's Avatar
Liked: 5474
True, but this is all you need:
https://www.amazon.com/Cable-Conceal...dp/B01JKO8724/
Zorba922 is offline
post #12 of 14 Old 07-28-2019, 10:49 AM
mmiles's Avatar
Liked: 516
Using channel is for a rental property or your garage...
The beauty is not seeing anything exposed.
In my previous business I use to cringe at the wiring jobs (data) my competition got away with just to reduce labor cost.
To each there own I’d say.
Mr. Guy how are you sir?
Zorba where have you been?
Mike Miles
[email protected]
post #13 of 14 Old 07-28-2019, 02:32 PM
Zorba922's Avatar
Liked: 5474
https://www.avsforum.com/forum/89-sp...l#post58277364
Zorba922 is offline
post #14 of 14 Old 07-28-2019, 02:58 PM
mmiles's Avatar
Liked: 516
My wife bribes me but not with speakers
Zorba922 likes this.
Mike Miles
[email protected]
Reply Speakers
