Polk S15s sound better than S50s - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 359Likes
post #301 of 466 Old 09-11-2019, 08:36 AM
Quoted: 1738 Post(s)
Liked: 1339
Originally Posted by Vikram Iyengar View Post
I don't bring my center forward at all. Do you mean I'll have reflections if I bring my center forward?
HT in 5.1 is great and so is multi-channel music. The two 5" woofers of the s30 sound better than the single woofer of the s15 for music. That's the whole reason I was thinking of getting the s55 for front L/R.
No, by leaving your center far back on the table, you leave a whole surface for sound to reflect off. Generally I like to hear my speakers and not the surface of a table
Bring in forward whenever you are watching a movie or tv or listening to music and move it back when you aren’t. It should be a clear improvement.
Vikram Iyengar likes this.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #302 of 466 Old 09-11-2019, 09:25 AM
gajCA's Avatar
Quoted: 9082 Post(s)
Liked: 6224
You know, the S35 description says this: "Polk's Signature S35 was designed for maximum versatility, with horizontal or vertical placement options. It performs equally well as a left, right, or center channel speaker. "
That tells me the tweeter has equal vertical and horizontal dispersion, (same tweeter as in S30) so you could get two more S30s and use them vertically as left and right.
And, yes, pull the center forward so the front edge matches the edge of the cabinet for the reasons Russ mentioned.
Ryan Statz and Vikram Iyengar like this.
Geoff A. J., California
gajCA is offline
post #303 of 466 Old 09-11-2019, 09:38 AM
pase22's Avatar
Quoted: 3333 Post(s)
Liked: 2798
My room. How's that for WAF? No wires visible!
You really need to pull those away from the wall, even if it's just 5-6 inches. You'll also want to pull that center all the way forward.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #304 of 466 Old 09-11-2019, 10:12 AM - Thread Starter
Quoted: 268 Post(s)
Liked: 4
Ah thought exactly that last night but the s30 is 20" long and will wobble off the stands. The stands have no hardware to hold a speaker down.
I wonder if the s30 sounds good in multichannel because I have it at +3dB. Other speakers are set 0dB. (I set the center to +3dB hoping to get better/louder dialogue in HT)
Vikram Iyengar is offline
post #305 of 466 Old 09-11-2019, 10:35 AM
Liked: 1339
Got it, will do. I thought it would reinforce male voices if pushed back. So that's what's causing that high frequency noise in my music? Music has a background whoosh/swish noise added to it. Wonder if our beautiful and wide coffee table is causing that.
No, the whooshing is most likely port noise caused by the speakers being close to the wall or the power port design.
But it should bring down brightness and clear up the sound a bit.
post #306 of 466 Old 09-11-2019, 11:15 AM - Thread Starter
Quoted: 268 Post(s)
Liked: 4
Originally Posted by Russdawg1 View Post
No, the whooshing is most likely port noise caused by the speakers being close to the wall or the power port design. But it should bring down brightness and clear up the sound a bit.
Is there a type of foam I could stuff into the powerport?
post #307 of 466 Old 09-11-2019, 11:23 AM
Liked: 1339
That would likely cause more whooshing or if you managed to seal the port completely would make it a sealed speaker reducing bass substantially.
post #308 of 466 Old 09-11-2019, 11:33 AM
Ryan Statz's Avatar
Quoted: 434 Post(s)
Liked: 230
Don't do that. Simplest, cheapest solution would be to just move the speaker away from the wall a bit.
yanks1 and Vikram Iyengar like this.
Home Theatre: Onkyo TX-NR747 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R | Elac S10EQ Subwoofer
Ryan Statz is online now
post #309 of 466 Old 09-11-2019, 02:42 PM - Thread Starter
Quoted: 268 Post(s)
Liked: 4
Is it really the power port? I'm talking about high freq noise "sssssss" noise that makes female vocals or lead guitar unclear. I'm not talking about muddy bass.
post #310 of 466 Old 09-11-2019, 02:46 PM
Liked: 1339
Uh, a whooshing sound? From the tweeter?
From my experience a whoosh is a very audible movement of wind.
Ssssss is over exaggerated treble, sibilance to be exact. It means the speaker is overly bright/harsh.
post #311 of 466 Old 09-11-2019, 02:55 PM - Thread Starter
Quoted: 268 Post(s)
Liked: 4
My bad. I did not mean audible movement of wind. By whooshing, I meant "Ssssss" (exaggerated treble). Many reviewers said they found sibilance till 100 hrs or even 3 weeks of playing.
On both s50 and s15, I found the highs too piercing. I bought the s10 used and it does not have piercing highs so I thought its broken in. (The s30 center had the sssss noise too but has much less of it now, maybe because we play it the most?)
post #312 of 466 Old 09-11-2019, 02:57 PM
Liked: 1339
Sibilance will never go away. It’s just how the speaker will perform. Only your ears get used to the sound. That is “break in”.
Lp85253 and Vikram Iyengar like this.
post #313 of 466 Old 09-12-2019, 07:39 AM - Thread Starter
Quoted: 268 Post(s)
Liked: 4
That's what pase22 said earlier and advised me to change the speakers. I desisted since (1) the return window on the s30 and s10 had passed, (2) s15 look really good and match the room and other speakers, (3) reviews are very good on s15. The return date for s15 is this Sat. I could (a) replace just the front L/R or (b) wait to see if s15 improves with break in and then replace in 2-3 years. The s10 and s30 have no sibilance.
For warm front L/R bookshelves with 5" woofers, would you suggest the Martin Logans, Q Acosutics, KEF ??
post #314 of 466 Old 09-12-2019, 07:44 AM
Liked: 1339
If you would like to keep the S15’s, some simple eq will fix it, a slight notch at 2-3khz will remove most sibilance.
I wouldn’t mix, I prefer to have all matching brands in a system, but the LX16’s would definitely be sibilance free, I think @gajCA can agree.
The Q Acoustics should be warm, not as warm as the Martin Logan’s, and the Kef will be sibilance free also, though not warm until you get to the higher R line. The Q line will be neutral, a little forward. I’d put them somewhere in between the Q Acoustics and Polk S15’s.
post #315 of 466 Old 09-12-2019, 08:24 AM
Ryan Statz's Avatar
Quoted: 434 Post(s)
Liked: 230
How to do this? The Sony STR-DN1080 has only two knobs (bass and treble). There appear to be no freq settings.
That would be in the settings menu of the AVR.
post #316 of 466 Old 09-12-2019, 08:31 AM
Liked: 1339
Ah then no worries.
You’d need an external EQ then like a MiniDSP.
I wouldn’t worry about it and just wait till you can upgrade.
post #317 of 466 Old 09-12-2019, 08:35 AM
Ryan Statz's Avatar
Quoted: 434 Post(s)
Liked: 230
Ah then no worries.
The AVR has an auto calibration function, so it should have an option for manual EQ.
post #318 of 466 Old 09-12-2019, 08:35 AM
Liked: 1339
Oh. No idea. Never used a Sony, lol!
post #319 of 466 Old 09-12-2019, 08:56 AM
Ryan Statz's Avatar
Quoted: 434 Post(s)
Liked: 230
Thanks but nope, only bass and treble in the settings menu related to frequency. The other EQ options in the settings menu are Flat, Engineered, None, Auto, Night, Dynamic, Compressed. All sound the same. There's one option Music but only works with external CD player not streaming.
I set bass to +3db and treble to -3 dB to try.
One idea I have is use Dolby Surround to upmix 2-channel to surround so that 80% comes out of the center speaker like HT.
How do you like the signs I posted for my wife now that I finally got the toe-in and distance between speakers right? :-)
"You can also select [Equalizer] in [Sound Effects] from the home menu. Additionally, you can adjust the equalizer from the [<EQ>] menu on the display panel by pressing AMP MENU."
https://helpguide.sony.net/ha/strdn1...001221277.html
unless I am mistaken, you should.
post #320 of 466 Old 09-12-2019, 09:05 AM - Thread Starter
Quoted: 268 Post(s)
Liked: 4
Wow really helpful! Gonna try tonight. (Can swear that everytime I selected Equalizer from any menu earlier, all I got was bass and treble settings.) The info in the website above is not in the printed manual I received with the AVR. Let me try today.
To confirm, set -3dB at 2-3 kHz?
Hate to be a naysayer but I just read your link again and they also say all you can change is C (bass) and D (treble). This is exactly what I see on every menu too. There is no Hz setting. But I'll try tonight.
post #321 of 466 Old 09-12-2019, 09:16 AM
Ryan Statz's Avatar
Quoted: 434 Post(s)
Liked: 230
Well, the "additionally" part might be more of a fine-tuning thing. I would be pretty surprised if it did not have any manual EQ adjustments.
No idea regarding -3dB at 2-3kHz, that's an answer someone else can maybe address.
post #322 of 466 Old 09-12-2019, 10:46 AM
gajCA's Avatar
Liked: 6224
I think the OP just needs a better AVR as his next step to be honest; one with better EQ and option for Manual EQ with equalizer.
gajCA is offline
post #323 of 466 Old 09-12-2019, 11:57 AM
gajCA's Avatar
Liked: 6224
Are you serious? I just got the Sony 3 months ago because CNET and some other sites rated it best of 2019 midlevel AVRs.
Well, it seems it won't do what you want to do now which is EQ out some sibilance so it seems quite limited for your needs.
But if it is that new, hang on to it of course.
Denon has numerous ways to address that issue in most of their receivers including something called Cinema EQ.
Cinema EQ and THX Re-equalization® share a common goal as they’re both designed to remove excessive high frequency information from movie soundtracks optimized for theatrical presentation.
Re-equalization, part of THX’s collection of technologies, is a specially-contoured "shelving filter" that gently adjusts the extreme high frequency range of the front channels, to compensate for the fact that many film soundtracks mixed for theatrical conditions sound very bright when played in a home environment. Whenever you select THX processing for a Dolby Pro Logic or Dolby Digital source, THX re-equalization circuitry is automatically activated and contours the sound for proper reproduction in the typical home theater room.
Denon’s "Cinema EQ," actually developed as a "stand alone" solution to overly-bright soundtracks before THX put its bundled technologies together, approaches the excessive high frequency problem from a different perspective. The "Cinema EQ" circuit has a progressively greater effect on frequencies further away from the "corner frequency," which is the point where the filter begins to operate.
gajCA is offline
post #324 of 466 Old 09-12-2019, 12:01 PM
Liked: 1339
I stopped paying attention to CNET because they give everything a good rating similar to Stereophile (But stereophile reviews items 10-100x more expensive hah).
But I don’t think I’ve ever seen Sony come up as a top suggestion here at AVS or Audioholics, so there’s that.
But as @gajCA said, hang on to it as it’s pretty new, but if it’s returnable, it’s worth around $600 new(?) which can get you a nice Denon X3500H which has pre-outs, Audessey XT32 EQ, Manual EQ, and a bunch of other stuff, along with what GajCA mentioned.
post #325 of 466 Old 09-12-2019, 12:25 PM
Ryan Statz's Avatar
Quoted: 434 Post(s)
Liked: 230
Unless Elac really ****s the bed on me, and doesn't do anything to remedy the issue of their app not working on iOS13, my next HT upgrade will be the AVR - but only to something that has the next HDMI/HDCP standards. I have an Onkyo now, but will more than likely move over to Denon.
post #326 of 466 Old 09-12-2019, 12:31 PM
Liked: 1339
Onkyo owner here too
post #327 of 466 Old 09-12-2019, 12:39 PM
Ryan Statz's Avatar
Quoted: 434 Post(s)
Liked: 230
Could the issue be your phone? Sonos app doesn't work on my 2017 Android phone but works perfectly on my wife's 2018 Android phone. Both phones are entry level Samsung.
It's known that the sub control app doesn't function on iOS13. It boots, but you get a blank screen.
post #328 of 466 Old 09-12-2019, 12:40 PM
gajCA's Avatar
Liked: 6224
First I'll try Ryan's tips to find manual EQ on my Sony. If it doesn't work, I'll try to sell the Sony on Craigslist and come back here to get recommendations on a cheaper Denon that has sibilance reduction options(*). I bought the $599 Sony on sale at $429. A 5.1 Denon AVR will work since I'm not planning atmos anymore.
The sibilance is indeed irritating especially since all my music seems to have freqs in that area (e.g., Freebird by Skynyrd).
(*)Will wait 3 months first to see if break in happens at all.
Could be the source.
gajCA is offline
post #329 of 466 Old 09-12-2019, 01:00 PM
Ryan Statz's Avatar
Quoted: 434 Post(s)
Liked: 230
There's a very good chance that I am simply misreading what the manual says. It would be very strange if it had no manual EQ settings apart from ones that have pre-set, internal adjustments.
Even if you're not planning Atmos, a 7.2ch AVR wouldn't be a bad idea - at least you'd have the flexibility to do Atmos if you changed your mind later on.
post #330 of 466 Old 09-12-2019, 01:02 PM
Ryan Statz's Avatar
Quoted: 434 Post(s)
Liked: 230
You're killing me, gajCA.
He could be right, though. Some speakers uncover a lot of things in an audio recording that warmer speakers wouldn't reveal.
Reply Speakers
