Help me chose speakers + all my speaker related questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-06-2019, 02:04 PM - Thread Starter
Quoted: 44 Post(s)
Liked: 0
Specifications
Model Number D86
Part Number SCD80600
Tweeter Dome Silk DPSD
Tweeter Diameter 3/4" (20mm)
Midrange Dome Glass
Midrange Diameter 4" (102mm)
Woofer Cone Fiberglass
Woofer Diameter 8" (203mm)
Frequency Response 34Hz-20kHz
Impedance 8 ohm
Recommended Amplifier Power 50 watts - 175 watts
Sensitivity 90dB +/- 3dB
Depth 7 3/8" (187mm)
Diameter 10" (254mm)
Cutout Diameter 8 3/4" (222mm)
Specifications
Model Number D88
Part Number SCD80800
Midrange Dome Kevlar
Woofer Cone Kevlar
Frequency Response 30Hz-20kHz
Impedance 8 ohm
Recommended Amplifier Power 50 watts - 200 watts
Tony Wong is offline
post #2 of 4 Old 08-06-2019, 02:23 PM
Pete7874's Avatar
Quoted: 254 Post(s)
Liked: 153
what difference between these 2?
About 4 Hz in frequency response.
"The problem with quotes on the Internet is that you never know if they're real." - Abraham Lincoln
Samsung UN55B7100  Denon AVR-S740H  Chane A2.4  Dayton MK402X  Premier Acoustic PA120  Roku Premiere Plus  Squeezebox Classic  CCA
Pete7874 is offline
post #3 of 4 Old 08-06-2019, 03:02 PM - Thread Starter
Quoted: 44 Post(s)
Liked: 0
what does that mean? will i notice a difference?
post #4 of 4 Old 08-06-2019, 04:13 PM
Pete7874's Avatar
Quoted: 254 Post(s)
Liked: 153
Not if you have them crossed over to the sub.
Pete7874 is offline
Reply Speakers
