Best Bang For Your Buck Bookshelf Speakers - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #1 of 31 Old 08-07-2019, 12:59 PM - Thread Starter
Liked: 0
Hi. I'm looking for a recommendation for a pair of bookshelf speakers that's a good value. I'm getting back into home audio and would like to get a pair of bookshelf speakers & a reciever for somewhere in the neighborhood of $1,000-$1,500 total. It's going to be used pretty much exclusively for listening to music. What speaker(s) would you recommend looking at?
bfdeluxeab763 is offline
post #2 of 31 Old 08-07-2019, 01:23 PM
Zorba922's Avatar
Quoted: 7093 Post(s)
Liked: 5401
If not planning on adding a subwoofer, this would be a good bet:
https://www.amazon.com/Polk-Audio-LS...s%2C139&sr=8-2
If sure you'll be sticking to 2 channel instead of going multichannel later, I'd consider this:
https://www.outlawaudio.com/products/rr2160.html
Pete7874, djp2k7, Matt2026 and 3 others like this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #3 of 31 Old 08-07-2019, 01:47 PM
djp2k7's Avatar
Quoted: 350 Post(s)
Liked: 285
Zorba's suggestions are great. So many options. I also like the Marantz PM7005 or Yamaha A-S701 and the Wharfedale Reva 2 (all are on sale below).
https://www.musicdirect.com/integrat...integrated-amp
https://www.musicdirect.com/speakers...shelf-speakers
Lp85253 likes this.
djp2k7 is offline
post #4 of 31 Old 08-07-2019, 02:01 PM
gajCA's Avatar
Quoted: 8970 Post(s)
Liked: 6137
What kinds of music?
Geoff A. J., California
gajCA is offline
post #5 of 31 Old 08-07-2019, 02:05 PM - Thread Starter
Liked: 0
thanks for the recommendations zorba. so in the case of the outlaw receiver, what would you recommend to to connect to it if you wanted a wireless/bluetooth connection for streaming?
post #6 of 31 Old 08-07-2019, 02:06 PM - Thread Starter
Liked: 0
as far as what type of music, everything really. mostly rock, classic rock, blues, old r&b, jazz. nothing really ultra bass heavy like modern r&b, hip hop, or electronic though.
post #7 of 31 Old 08-07-2019, 02:07 PM
Quoted: 16 Post(s)
philadler is offline
post #8 of 31 Old 08-07-2019, 02:11 PM
TornadoTJ's Avatar
Quoted: 1949 Post(s)
Liked: 626
His opinions here for budget bookshelf speakers are spot on, even though I don't have any of them but the Daytons. I know the Elacs are very well respected. In my office, I use HSU bookshelf speakers, which are not expensive at all (relatively)
Another good one, although I did not finish it.
Ben23 likes this.
TornadoTJ is offline
post #9 of 31 Old 08-07-2019, 02:26 PM
zieglj01's Avatar
Quoted: 3039 Post(s)
Liked: 2950
I would look at these
Outlaw BLS2 speakers ... which can handle your music preference
http://www.outlawaudio.com/products/blsv2.html
Canton Chrono 513 ... and a real good price
https://www.accessories4less.com/mak...ck-pair/1.html
Who AM I
zieglj01 is online now
post #10 of 31 Old 08-07-2019, 02:26 PM
gajCA's Avatar
Liked: 6137
Free returns at Best Buy.
https://www.bestbuy.com/site/klipsch...E&gclsrc=aw.ds
$10 to return within 60 days.
https://www.crutchfield.com/p_745C33....html?tp=34948
gajCA is offline
post #11 of 31 Old 08-07-2019, 02:57 PM
Zorba922's Avatar
Liked: 5401
It's got a USB A input, so you could probably wire that to a smartphone or tablet for streaming.
If you want wireless/bluetooth there's also this NAD, though it's not quite as beefy:
https://www.audioadvisor.com/prodinfo.asp?number=NAC328
Zorba922 is offline
post #12 of 31 Old 08-07-2019, 03:18 PM
bear123's Avatar
Quoted: 2599 Post(s)
Liked: 4078
For speakers:
http://www.ascendacoustics.com/pages...SRM1/srm1.html
or
https://www.revelspeakers.com/produc...ck-USA-Current
Combined with http://www.rythmikaudio.com/L12.html
For drastically superior sound quality to any pair of speakers around the above total cost.
Then whatever amp or AVR you want to use that has the features you want.
Download REW and grab a Umik-1 mic if you are after good sound quality.
Soulburner likes this.
bear123 is offline
post #13 of 31 Old 08-07-2019, 05:23 PM
callas01's Avatar
Quoted: 1398 Post(s)
Liked: 949
This is another option and would do all you need, built in amps and you can have a streamer also.
https://www.amazon.com/Dynaudio-Xeo-...71612995&psc=1
https://www.crutchfield.com/p_813NOD...-2i-Black.html
Dynaudio Contour 20, Focus 210C, DM 2/6, Hsu VTF3 MK5 HP, Oppo BDP-103, Naim Uniti Star, Marantz SR5010, 60" 4K Samsung LED LCD, XBOX ONE S
callas01 is offline
post #14 of 31 Old 08-07-2019, 05:30 PM
Bigbirney's Avatar
Quoted: 98 Post(s)
Liked: 87
ELAC Debut B6.2 and a Denon 3500 or Marantz 5013 from Accessories 4 less with money left over. Also look at the Canton Chrono 512 at A4L.
Basement HT 5.1.2 - Marantz 6012, Outlaw 5000 - ELAC Debut F5 Towers, C5 Center, B5 Bookshelves as surrounds - Monolith 15(RETURNED) - BenQ2050a 92" Silver Ticket
Upstairs Living Room, Music 3.1 - Anthem MRX520 - Pair of KEF Q300's, Single Q100 - SVS PB 1000 - Projekt Debut turntable - LG 55" B8 OLED
Bedroom 2.1 - Denon AVR740h - ELAC B4 Bookshelves - Klipsch R-10SW - TCL 49"
Bigbirney is offline
post #15 of 31 Old 08-07-2019, 08:58 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1568
You did not mention a sub, so my suggestion is going to be a little different.
You should have a couple of priorities:
1. Flat and smooth frequency response on and off-axis (as much as is reasonable)
2. Good bass extension, free of peaks and dips
To that, you will need room correction for the bass frequencies. I recommend an AVR that has Audyssey XT32. If your speakers are really good, use the Audyssey app to limit correction to about 400-500 Hz. This is going to help because you don't have a sub that can find a more optimal placement for bass. Denon 3400 would be a good choice.
The above speaker suggestions are really good.
Lp85253 likes this.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Emotiva E2 (2) | Rythmik Audio F12 (2)
Soulburner is offline
post #16 of 31 Old 08-07-2019, 10:24 PM
hodgjy's Avatar
Quoted: 45 Post(s)
Liked: 64
You can get a killer setup well below your budget.
For bookshelf speakers, consider the HSU HB-1 MK2. (2 for $320). If you want a little more lower growl, you can get a subwoofer of your choosing. A good one is less than $400, such as the entry-level HSU.
Then, that gives you around $300-800 for a receiver. No need to go over $300 as Yamaha is a good value for their price.
You can come out with a great system for $1000. I think your money is better spent (and heard) by purchasing better speakers at the expense of a more pricey receiver.
Lp85253 likes this.
hodgjy is offline
post #17 of 31 Old 08-07-2019, 10:25 PM
Zorba922's Avatar
Liked: 5401
Call me an old-school troglodyte perhaps, but I really don't think room correction is all that. Maybe if one's room is incredibly BAD acoustically. But any decent speakers, with some intelligent placement decisions, with a decent power source and music source, should be fine without any electronic fiddling-around. I am very happily listening to my BMRs in Pure Direct mode, subwoofer off, while typing this.
Zorba922 is offline
post #18 of 31 Old 08-07-2019, 10:29 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1568
All rooms have bass problems.
bear123 likes this.
post #19 of 31 Old 08-07-2019, 10:40 PM
hodgjy's Avatar
Quoted: 45 Post(s)
Liked: 64
This is true to a point. My room has some pretty bad problems, which were only solved by installing a subwoofer and reversing the phase. This had nothing to do with AVR room correction. But, overall, I am a fan of room correction but recognize it's not a magic wand or crutch.
hodgjy is offline
post #20 of 31 Old 08-07-2019, 11:22 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1568
Placement is always #1 .
Reason I think XT32 will be important here is that he isn't spec'ing the system to have a sub. Solving of bass issues will then be relegated to large amounts of absorption...which costs space and money (more than the AVR).
hodgjy likes this.
post #21 of 31 Old 08-08-2019, 02:22 AM
bear123's Avatar
Liked: 4078
Even if all the budget were spent on only speakers(which wouldn't work as op needs an amp/avr), a speaker/sub combo within budget would sound better.
MIX_MASTER_ICE likes this.
bear123 is offline
post #22 of 31 Old 08-08-2019, 06:01 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1568
I think these deserve a look.
https://www.buchardtaudio.com/shop/s300-white
Lp85253 likes this.
post #23 of 31 Old 08-08-2019, 06:52 AM
Elihawk's Avatar
Quoted: 1918 Post(s)
Liked: 2060
Originally Posted by philadler View Post
Just FYI...Dennis Murphy has closed shop at Philharmonic audio and retired...
Lp85253 likes this.
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #24 of 31 Old 08-08-2019, 07:09 AM
HarleyRider's Avatar
Quoted: 147 Post(s)
Liked: 99
Not sure if anyone else has suggested these yet. MartinLogan LX16's. The older version of the Motion 15. Available new from Crutchfield at a pretty considerable discount. I have a pair that I use for surround and think they put out a lot of sound from a small package.
https://www.crutchfield.com/p_839MLX...ano-Black.html
And similar in design and a few dollars less, the B1 from Emotiva.
https://emotiva.com/collections/loud...ts/airmotiv-b1
gajCA and Lp85253 like this.
Pre/Pro: Anthem AVR 60 | 5.2.4 Config: MartinLogan ElectroMotion ESL X FL/FR, ESL C Center, Motion LX16 Surrounds, Motion 4i Atmos | Subs: Velodyne DD-15, Martin Logan Dynamo 1100x | Amplification: Emotiva XPA-3 Gen 1 FL/C/FR, Emotiva A-700 Surrounds and Atmos
Dedicated ARC Genesis Thread
HarleyRider is offline
post #25 of 31 Old 08-08-2019, 08:41 AM
Stephen Hopkins's Avatar
Quoted: 427 Post(s)
Liked: 199
A few others have mentioned the Canton offerings from AC4L, and I also mentioned them in your Receiver thread, so I'll pile on here as well. To me, the Chrono 502.2 is the absolute budget choice and the Chrono SL 536 is just amazing for the price. I've heard the SL 536 side-by-side with the more expensive Vento 836 and felt the Chrono was basically as good for ~1/3 less money... there are some tweeter tech improvements in the Vento that may have improved clarity a bit but I think most of the price difference is honestly upcharge for the curved cabinets.
I'm a big fan of large bookshelfs and think it's a shame there aren't many left in the market these days... the SL 536 is everything I'd be looking for in a 2ch speaker, even for occasional light HT use (neutral sound, low-end extension, reasonable efficiency, well-engineered, great build/fit/finish). Either of the Chronos with your integrated amp of choice would be a very solid choice right at the bottom end of your budget or well below it... but there are so many great options that it's tough to go wrong with your budget and the guidance you're receiving here.
zieglj01 and Lp85253 like this.
BenQ TK800 | Silver Ticket 106" 16:9 1.0 Grey | Marantz SR6011 | B&W P6 | B&W CDMC SE | Sonance .5 THX SUR | MCM In-Ceiling Atmos | Ascendant Avalanche 12" in 6 ft^3 @ 18Hz w/ BASH 500w Plate Amp | Sony X800 | NVidia Shield TV Pro | XBox One 500gb | Nintendo Switch | Harmony Smart Control | SmartThings Hub | Google Home | AT&T Fiber 300 | YouTube TV | Netflix | HBO Now | Spotify
Stephen Hopkins is offline
post #26 of 31 Old 08-08-2019, 11:46 AM
Quoted: 16 Post(s)
I was not aware, thank you. Probably not helpful to recommend products you can't buy lol
Lp85253 likes this.
post #27 of 31 Old 08-08-2019, 02:21 PM
NoFuzz's Avatar
Liked: 32
I've recently auditioned several speakers in a broad price range: Sonus Faber, b&w, but for around €700 or less I am very very happy with my Dynaudio emit M20s.
Neutral but not boring, detail but no fatiguing treble and a tight bass. Though I play with a subwoofer (SVS) for the sub 50Hz , all driven by NAD T758v3.
NAD T758v3 | F:Dynaudio EMIT M20 C:Dynaudio Audience 122C S:Dynaudio Audience 62 B:T+A Triton TR1 TF:Dynaudio Audience 42W TR:JBL Pro
Oppo BDP-93 | Sony VPL-HW50ES 3D | FireTV | Mede8er X5003D | 2x Behringer A500 | Cadillac Sedan Deville 1973
NoFuzz is offline
post #28 of 31 Old 08-08-2019, 02:32 PM
RayGuy's Avatar
Quoted: 2807 Post(s)
Liked: 2572
For strictly two channel, this is a ridiculous deal at it's current price:
https://www.amazon.com/Cambridge-Aud...SIN=B078H7ZP8T
Get a few more watts and a phono amp with the upgrade:
https://www.amazon.com/Cambridge-Aud...SIN=B00803GSBO
If going for a future HT, then look at the Marantz slim line (with Pure Direct for 2-channel listening):
https://www.accessories4less.com/mak...-w/heos/1.html
As to speakers ... listening sessions to narrow down the list.
18Hurts and gajCA like this.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #29 of 31 Old 08-08-2019, 02:42 PM
brian6751's Avatar
Quoted: 1702 Post(s)
Liked: 1699
Definitely
FOR SALE:
Lots of stuff. Check the Audio Gear Classifieds
brian6751 is offline
post #30 of 31 Old 08-08-2019, 02:50 PM
Zorba922's Avatar
Liked: 5401
Gobsmackingly good!!!
That's basically T-amp price range!
If my Trends Audio wasn't still going strong I'd jump on that myself.
zieglj01 likes this.
Zorba922 is offline
Reply Speakers
beginner , bookshelf speaker , value for money
