KLH 7.2.4 Speaker System Review: Full Immersion - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #1 of 32 Old 08-08-2019, 06:57 PM - Thread Starter
Mark Henninger
imagic's Avatar
Quoted: 9176 Post(s)
Liked: 16188
Speakers and subs are the make-or-break components of home theater sound systems. It’s where “the rubber meets the road” and the challenge is to find the right speakers to get the most out of TV shows, movies, upmixed 2-channel music and multi-channel music. With its new speaker and subwoofer lineup, KLH Audio offers a compelling collection of high-performance speakers that both look and sound great. In this review we’ll take a look at a KLH 7.2.4 system that I used in an IMAX Enhanced home theater system.
Click here to read more...
Mark Henninger
Editor, AVS Forum
imagic is offline
post #2 of 32 Old 08-09-2019, 02:42 AM
Mashie Saldana's Avatar
Quoted: 1255 Post(s)
Liked: 1090
What is the point of giving out Top Choice awards if they are handed out to most tested systems?
So how is this system comparing to the other Top Choice system you posted 3 days ago?
Tower Cinema - 9.1.6 in a 12'x12' room
Input : Nvidia Shield TV, Panasonic DMP-UB400
Magic : Marantz SR7010, Marantz SR6010, 2x NAD T743
Output : Panasonic TX65EZ952B, SVS PB13 Ultra, Monitor Audio GSLCR 2xGS20 2xGS10 4xGSFX 6xBX1
Mashie Saldana is offline
post #3 of 32 Old 08-09-2019, 03:45 AM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 16188
This KLH system costs less overall and includes Atmos. The Kendall towers dig deeper and IMO (i.e. subjectively speaking) are as good sounding overall as the Premier 800F towers. But Paradigm does have a center channel that matches the towers better.
Paradigm X15 is a more powerful sub that digs deeper too but costs more.
It is sheer coincidence the reviews posted so close to each other.
The point... is that "Top Choice" is an enthusiastic recommendation. It's also something you can ignore, if you so choose.
Ideally all my reviews would be Top Choice products but they are not always. I'm not on a hunt for mediocre products that I am unenthusiastic about. Some other reviewer can go ahead and handle that gig (Scott Wilkinson is handing out 2-star reviews at techhive, for example). If I say yes to doing a review, I've already got a clue that the gear is decent because I check stuff out ahead of time (at a show, press event, whatever).
Specifically, if I get a "bad" product, I just send it back. Life's too short to review crap.
Anyhow I gave a "Top Choice" designation to highlight that I liked the system. And I gave it to both these reviewed speaker rigs because they are both great systems.
deafenears and Zzz..oltan! like this.
Mark Henninger
Editor, AVS Forum
imagic is offline
post #4 of 32 Old 08-09-2019, 05:19 AM
Liked: 1090
Thank you for the explanation.
It would be nice if you could publish the list of kit that didn't make the cut and why. Might help some people out there from making bad shopping decisions.
post #5 of 32 Old 08-09-2019, 06:29 AM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 16188
I'm not publishing a list, I'm not systematic about it. But I will share a couple examples.
First was the Fluance Signature Series towers. I was reluctant to review them because I was NOT familiar with them when the company asked if I wanted review samples. I measured them and something looked fishy. I also learned that Audioholics saw similar odd measurements. After notifying the company, the speakers were recalled and the crossover was redone and existing owners were given the opportunity to have their speakers "upgraded" to a working crossover.
Some months later, I said yes to reviewing the "fixed" versions.... however I still did not love the speakers after the crossover was fixed. https://www.avsforum.com/fluance-sig...eakers-review/
After that experience I vowed not to say "yes" to reviewing speakers I have not already auditioned.
Next up...
MarkAudio-SOTA. I had a pair of the SOTA Viotti bookshelf speakers to review. Another example where I made the mistake of saying yes to a review without a prior audition. The measurements were too uneven and on top of that the speakers did not seem to reveal anything more than far more affordable bookshelf speakers I also had on hand, and were quickly beaten in overall fidelity by the time I compared them to $500/pair bookshelf models. Considering the high cost, I found it disappointing. But boy, the wood veneer is shiny and the grill is fancy and there's black velvet and stuff!!! http://www.markaudio-sota.com/produc...series/viotti/
Subsequent auditions at high-end audio shows were disappointing and confirmed I would not have asked for a demo unit had I heard them first.
FWIW KLH is a counterpoint, I first heard 'em at CEDIA last year—in a private suite, with nobody else except the company owner and the head designer, and listened to my own music selection, and then made a specific decision to focus on its products in reviews this year, based on that positive experience.
But also... in some cases I'll say yes to speakers from a brand I'm already familiar with, without hearing them first. But that's not as common.
Mashie Saldana and OzHDHT like this.
Mark Henninger
Editor, AVS Forum
imagic is offline
post #6 of 32 Old 08-09-2019, 08:00 AM
buckchester's Avatar
Quoted: 84 Post(s)
Liked: 49
I believe a superior sounding speaker in the same price range would be the SVS Prime Tower. It has a more neutral frequency response.
https://www.soundstagenetwork.com/in...nts&Itemid=153
Based on these measurements, the KLH also appears to have a lot of distortion around the 3khz area. Not sure if this is audible or not.
buckchester is offline
post #7 of 32 Old 08-09-2019, 05:03 PM
Sean Spamilton's Avatar
Quoted: 447 Post(s)
Liked: 552
The reported 25hz +/- 3db as advertised seems problematic also, as according to the graphs as measured at the NRC it's down 13db at 30hz.
Denon X-4300 | Onkyo M-282 | Audio Technica AT-LP3 | HTPC |
Polk RTiA3 x 6 - RTiA6 x 1 - Polk Atrium 5 x 4 | PSA 15s | PSA XS30
Epson HC 2100 | 100" Elite Screen |
Sean Spamilton is offline
post #8 of 32 Old 08-09-2019, 05:23 PM
Quoted: 84 Post(s)
Liked: 49
I believe the sub bass frequencies in those measurements are actually inaccurate. So the speakers probably do play lower than they suggest.
post #9 of 32 Old 08-09-2019, 05:24 PM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 16188
In-room, post room correction (with room gain lending a hand) Kendall does just fine in the 20s...
The overall response does bear close resemblance to that NRC measurement in shape but they don't accurately describe the bass you get in practice.
Mark Henninger
Editor, AVS Forum
imagic is offline
post #10 of 32 Old 08-09-2019, 05:29 PM
Quoted: 447 Post(s)
Liked: 552
Originally Posted by imagic View Post
In-room, post room correction (with room gain lending a hand) it does just fine in the 20s...
That's fair, but when they posted the 25hz +/- 3db spec they didn't qualify it with 'when taking into account room gain and after a boost from room correction' ...
post #11 of 32 Old 08-09-2019, 05:35 PM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 16188
To be fair, I see no boosting there by Audyssey in the deep bass, just EQ cuts to compensate for that room gain.
Mark Henninger
Editor, AVS Forum
imagic is offline
post #12 of 32 Old 08-09-2019, 06:22 PM
Quoted: 84 Post(s)
Liked: 49
Are you applying Audyssey room correction to the entire frequency range? If so, have you tried taking gated measurements before and after Audyssey is applied? Because room correction above the room transition frequency, based on non-gated in-room measurements, will produce unpredictable results.
post #13 of 32 Old 08-09-2019, 06:29 PM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 16188
No I did not take gated measurements, but as a rule I don't apply room EQ above Schroeder, that's why I use the Audyssey app because I used to depend on Dirac Live for that. In the meantime I have moved to a new apartment and returned the speakers so no chance I'm busting out REW for follow-up measurements. But then again, I'm not doing technical reviews, which I presume you have ascertained at this point. I do appreciate the NRC charts when they are specific to the actual speaker I reviewed, as opposed to extrapolations.
I posted that chart to convey how overall these speakers do well in the deep bass range and I happened to notice how closely the measurements tracked the NRC chart.
Mark Henninger
Editor, AVS Forum
imagic is offline
post #14 of 32 Old 08-09-2019, 11:10 PM
tenthplanet's Avatar
Location: North of Mexico, South of Oregon, West of desert
Quoted: 2257 Post(s)
Liked: 3531
Neutral doesn't mean you'll like the sound, speakers are as much art as they are science. A good speaker designer does a lot of listening. Loudspeakers are voiced and the numbers won't tell you that.
"Espresso is like tequila, when in doubt apply more shots."
tenthplanet is offline
post #15 of 32 Old 08-09-2019, 11:41 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1851
Originally Posted by tenthplanet View Post
Neutral doesn't mean you'll like the sound, speakers as as much art as they are science. A good speaker designer does a lot of listening. Loudspeakers are voiced and the numbers won't tell you that.
Some people like colored sound. However, that preference is usually reduced after spending some time with uncolored speakers. Not always, but usually.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Polk LSiM 702 F/X (2) | Infinity RS152 (4) | Subs TBD (2)
PC: Micca OriGen G2 | Mackie MR624 (2)
Soulburner is offline
post #16 of 32 Old 08-10-2019, 12:53 PM
Quoted: 839 Post(s)
Liked: 679
Thread derailment in 5...4...3...2...1...
Soulburner and tenthplanet like this.
sigpig is offline
post #17 of 32 Old 08-10-2019, 02:18 PM
Liked: 3531
There is some truth to that, audiophiles have argued about this even before wide spread internet adoption.
post #18 of 32 Old 08-11-2019, 07:58 AM
RickD1225's Avatar
Quoted: 308 Post(s)
Liked: 1394
I sure hope the picture of the system is a stock photo. No way the center should be set back on the shelf like that.
Spoiler!
RickD1225 is online now
post #19 of 32 Old 08-11-2019, 11:49 AM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 16188
My photo, but yes a "stock" photo so to speak... I was setting the system up when I shot that image and the screen is actually resting on the center channel speaker because I had not yet fully secured it to the wall. I pulled the speaker forward when I ran room correction, after affixing the screen.
Mark Henninger
Editor, AVS Forum
imagic is offline
post #20 of 32 Old 08-12-2019, 08:11 PM
Tristan944's Avatar
Quoted: 77 Post(s)
I honestly didnt know KLH was still in business. If I remember correctly, 25 years ago KLH made very inexpensive speakers, something you'd buy at Walmart.
Sound: Anthem MRX-1120. Triad Silver speakers with Atmos and SVS PB-2000 subwoofers in 5.2.2. Sony UBP-X800. Roku Ultra. Amazon Fire TV. Micca Speck G2. ViewTV AT-263.
Picture: Epson 6040UB. Seymour Enlightor 4K 140 inch screen. Audioquest Forest HDMI.
Automation: Control4
Space: Dedicated theater room. Two Jerome's Challenger sofas.
Tristan944 is offline
post #21 of 32 Old 08-12-2019, 08:23 PM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 16188
Not really the same company, new owner and new products. More like a rebirth of the "old" KLH.
tenthplanet likes this.
Mark Henninger
Editor, AVS Forum
imagic is offline
post #22 of 32 Old 08-15-2019, 11:49 AM
BP1Fanatic's Avatar
Quoted: 256 Post(s)
Liked: 212
Thumbs up
Wow, I was considering those speakers until I saw your reviews of the Mackie c200's, Behringer B215XL's and Monoprice 15's. I ended up getting the Rockville SPG88's @ $92 a pair.
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is offline
post #23 of 32 Old 11-22-2019, 10:55 AM
Utopianemo's Avatar
Quoted: 251 Post(s)
Liked: 190
Mark, keep up the good work. How do you feel your move has/will change the way you do your reviews or the types of speakers and other gear you'll review?
Pioneer SC-95, 2x Crown XLS 1000 (LCR amps)
3x Epos Epic 2(LCR), 4x Emotiva UAW 6.2(Surrounds), 4x Aperion Intimus LC-I6(Atmos/DTS:X)
2x Dayton Ultimax 18" sealed(subs), Behringer Inuke 6000DSP(sub amp),
Vizio P-65C1 LED HDR
Oppo UDP-203 HD-Blu Ray Player, Oppo DV971H DVD Player, Roku Premiere+
Utopianemo is offline
post #24 of 32 Old 11-30-2019, 01:16 PM
BRAC's Avatar
Quoted: 705 Post(s)
Liked: 617
Mark, why the strong emphasis on IMAX Enhanced in your reviews??
Such a head scratcher is the existence of IMAX Enhanced, or lack there of.
Samsung 82” Q90R * LG 55” C8 * Denon X4500H * 5.2.4 Atmos * Xbox One X * PS4 Pro
BRAC is offline
post #25 of 32 Old 12-02-2019, 10:42 AM
bluewizard's Avatar
Quoted: 2330 Post(s)
Liked: 1544
I followed a link to the KLH at World Wide Stereo where the specs are shown twice, once for black and once for Walnut. Here they are -
Walnut -
https://www.worldwidestereo.com/prod...air?sku=171407
  • 2x 6.5" woven Kevlar bass drivers
  • 1x 5.25" woven Kevlar mid/bass driver
  • Dual 5-way binding posts
  • Sensitivity: 96dB
  • Frequency response:25Hz - 23kHz +/-3dB
Black -
https://www.worldwidestereo.com/prod...olor=Black+Oak
  • 1" anodized aluminum tweeter
  • 3/4" MDF construction
  • Frequency response: 33Hz - 23kHz
  • Sensitivity: 96dB
I wonder if there isn't some confusion between the -3db Response and the -6db Response. At 33hz at -3db, that is still pretty good for 2x6.5", and 25hz at -6db is also very good for 2x6.5". My speakers are rated at 28hz at -6db and they have 2x8" bass drivers.
25hz at -3db seems very optimistic and unlikely. But 33hz seems realistic and a bit above average for bass depth.
Though if this is In-Room vs Anechoic, then there would be bass boost in the In-Room Response. Still even 33hz Anechoic (I assume) is still pretty good for a speaker with 2x6.5" bass drivers.
Steve/bluewizard
bluewizard is offline
post #26 of 32 Old 12-03-2019, 05:06 AM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 16188
Just doing my job.
Mark Henninger
Editor, AVS Forum
imagic is offline
post #27 of 32 Old 12-03-2019, 05:16 AM
lizrussspike's Avatar
Quoted: 1289 Post(s)
Liked: 1943
Different from the KLH speakers I had in the 90's, that's for sure.
lizrussspike is offline
post #28 of 32 Old 12-05-2019, 07:30 AM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 16188
Walnut -
  • Sensitivity: 96dB
Black -
  • Sensitivity: 96dB
Steve/bluewizard
My understanding is KLH does not post anechoic frequency response specs. Please refer to this is a statement from Steve Howell, the CTO at KLH... it's about the Albany bookshelf in particular but addresses the posted specs more generally as well:
"We are not defying any laws of physics and the specs in a room loaded environment are correct. We do not post Anechoic specs because people don’t listen to speakers in Chambers. We know there is the reverse argument for this outlook but we choose to post real world use specs. There are always people who are going to say not possible when something new comes along. KLH is not excluded from that. We can recreate the measurements and the doubters are still going to doubt. That is OK, because speakers are very subjective, and our sound is not going to please everyone. But the vast majority that have actually sat and listened to the Albany’s have been amazed by what we have achieved with a small box. Having been the guy that tuned them and measured the results. I know what they do I have listened and measured in both environments and the results are in the listening. We are not defying any Laws of physics, but rather have used those laws to our advantage." - Steve Howell, CTO KLH
Mark Henninger
Editor, AVS Forum
imagic is offline
post #29 of 32 Old 12-05-2019, 02:06 PM
bluewizard's Avatar
Liked: 1544
My understanding is KLH does not post anechoic frequency response specs. ...
It is also a good way of inflating the frequency response. I'm not that concerned that the frequency response is In-Room, more that we are not seeing consistent specs for this speaker.
All that said, the Frequency Response does look pretty good for 2x6.5" speakers.
Steve/bluewizard
post #30 of 32 Old 12-07-2019, 12:09 PM
Quoted: 36 Post(s)
Liked: 30
[I]"We are not defying any laws of physics and the specs in a room loaded environment are correct. We do not post Anechoic specs because people don’t listen to speakers in Chambers. [I]
To be honest, this sounds like a typical BS response from a vendor who does not perform anechoic tests. If I were to hazard a guess, they are not posting the expected in room high frequency response; otherwise, that 23 Khz (-3db?) in room response would indicate that these speakers are incredibly bright (i.e. huge spike in the high frequencies, since high frequencies are generally muted in NA style [i.e. furniture, sofas, and rugs/carpets] rooms).
Merlin GS is offline
Reply Speakers
klh , klh kendall
