Help with speakers - AVS Forum | Home Theater Discussions And Reviews
 23Likes
post #1 of 41 Old 08-09-2019, 06:26 PM - Thread Starter
Quoted: 29 Post(s)
Liked: 0
Help with speakers
I have a dedicated home theatre room that is about 32' x 14' and I was hoping to get some ideas for speakers for a 7.1.4 system. My budget is about $4000 which does not include the 4 surround speakers which I will buy later. So I'm looking for 2 front speakers, amplifier, centre speaker, subwoofer, and 4 overhead atmos speakers. I have a benq 2050a projector with a 150 inch silverticket screen.
My AV guy has given me 2 options which I can list here: (canadian prices)
Option 1:
Amplifier: Onkyo TX-NR585 - $600
2 (Left + Right) Polk Audio S50 - 700
Center Channel: Polk Audio S35 - 400
Surround: Four 7" round in-ceiling Polk 70-RT - 1200
Sub-Woofers: 1 x Polk Audio HTS10 - 350
TOTAL: 3250
Option 2: ( a bit pricier)
Amplifier: Denon AVR3500h - $800
Front Speakers: 2x KEF Q550 Towers - 1100
Surround Speakers: KEF in-ceiling rectangular - 1380
Center Channel: KEF Q650 - 650
Sub-Woofers: KEF KUBE10 - 600
TOTAL: 4530
Do these packages look good? Or are there speakers out there that are better value compared to these? The one issue I do have is the space for the front speakers. I have about 8.25" between the screen and the side wall, so I know that rules out a bunch of speakers. Is this enough space for a good quality speaker or am I better off switching to an acoustic transparent screen?
rio72 is offline
post #2 of 41 Old 08-09-2019, 06:50 PM
Zorba922's Avatar
Quoted: 7069 Post(s)
Liked: 5375
Definitely do the AT screen, that way you can put speakers that might not be very pretty but can play very loudly/clearly while not costing nearly as much. For example, 3 of these across your front would normally be ugly as sin but they'll blow your socks off compared to any of the stuff your installer's recommended:
https://www.amazon.ca/800-Watt-Speak...ateway&sr=8-21
If that's too radical for you, look into the NHT speakers sold here at very good prices:
https://www.amazon.ca/s?k=nht&ref=nb_sb_noss_2
Both of the packages your installer gave you are of very poor value.
General rule of thumb is, pay an installer to INSTALL ONLY. Any equipment you buy from an installer is bound to be hideously overpriced, i.e. giving him his cut.
And if you do free standing speakers behind an AT screen, zero need for an installer anyway. Try to use on-wall and wall mounted compact bookshelves for all surrounds and Atmos speakers too.
Lastly, avoid buying subs made by speakers-first companies...like the installer's recs, they are invariably overpriced and underperforming.
In Canada, this is your best bet for an HT sub:
https://www.electronicsforless.ca/sv...ofer-3884.html
spyboy, smcmillan2 and rio72 like this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #3 of 41 Old 08-09-2019, 06:58 PM
smcmillan2's Avatar
Quoted: 855 Post(s)
Liked: 762
Zorba already pointed you to some good options. I will only say that for HT, you want the best center and subwoofer(s) you can afford (neither of the options you listed qualify there IMO).
Might consider DIY if you are so inclined.
rio72 likes this.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #4 of 41 Old 08-09-2019, 07:38 PM
MIX_MASTER_ICE's Avatar
Quoted: 2639 Post(s)
Liked: 2453
In your situation I would be snatching up the Polk LSiM series speakers that are currently on sale. The LSiM 705 towers are $400/each after rebate, which I think may be the lowest ever. You'll be hard pressed to get more for less than these Polk tower, center and surround speakers.
https://slickdeals.net/f/13262356-po...src=SiteSearch
For a sub you have over 3500 ft^3 with 8' ceilings. I would look at the HSU VTF-15H mk2, which is on sale now for $1022/shipped.
http://hsuresearch.com/products/vtf-15hmk2.html
EDIT: Just caught that you look to be in Canada, so this may not apply.
Soulburner and rio72 like this.
Subs>RBH I-12e, I-12. HSU VTF-15H mk2. Monolith THX 12(x2)/THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c, Arena 130/125c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2, XB900n, MDR-V6, XB700, XB32, XB31, XB22. Sennheiser HD58X, HD4.50, PC37X. SIVGA SV004. HyperX Cloud PS4. TB Stealth300. LG FH6, RK8, RK7, PK5, PH4. HK Onyx Studio4(x2).
MIX_MASTER_ICE is online now
post #5 of 41 Old 08-09-2019, 08:36 PM
RayGuy's Avatar
Quoted: 2729 Post(s)
Liked: 2498
If you don't go with the acoustically transparent screen, a 150 inch screen will be too wide and won't provide sufficient space between the outside of the speaker and the wall (assumes the screen is on the 14' wall). If the screen is 2.40:1, it's even worse. How are you setting up the room? Multiple rows, risers? Be sure to leave enough room at the back so you are not right up against the back wall, which will eliminate the 7.x.x solution. Also, be sure that the seated ear in any row is not at 1/2 or 3/4 room length (after wall installation).
Is there anything more fun than a new HT? Well, maybe inaugurating it while watching Body Heat ....
rio72, spyboy and MIX_MASTER_ICE like this.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #6 of 41 Old 08-09-2019, 11:04 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1476
3x JBL 580 towers across the front behind the screen: $1050 https://www.jbl.com/loudspeakers/STUDIO+580BK-Z.html
In-Ceilings (Atmos): $500 https://rslspeakers.com/c34e-ceiling-speaker/
You say you will buy surrounds later.
The KEF system is good; it's just more expensive than the JBL and I doubt if it's better.
Don't get either of those subs. Look at getting 2 of these with your savings: $1700 http://www.hsuresearch.com/products/vtf-15hmk2.html
Edit on the subs: just noticed Canada. Get to a Paradigm dealer for a Defiance X15 subwoofer, or order a PSA V1510 or V1811 as they ship to Canada.
This will kill both option 1 and 2.
Under $4k.
MIX_MASTER_ICE, rio72 and spyboy like this.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Emotiva E2 (2) | Rythmik Audio F12 (2)
Soulburner is online now
post #7 of 41 Old 08-10-2019, 02:11 AM
pase22's Avatar
Quoted: 3220 Post(s)
Liked: 2672
Option 1:
TOTAL: 3250
TOTAL: 4530
Your base layer (5.1) is most critical since most of the sound will be coming from there. It is important to get the base layer right before expanding to atmos and whatnot. Your in ceiling channels should not be costing you $1200-1500, that's insane. The Kef package is a good option, but shop around for cheaper surrounds.
MIX_MASTER_ICE and spyboy like this.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #8 of 41 Old 08-10-2019, 12:24 PM
gajCA's Avatar
Quoted: 8809 Post(s)
Liked: 5990
Option 1:
You would need to get the Denon 4500 + stereo amp or the Denon 6500 to do 7.1.4.
Or the Onkyo TX-RZ3100.
All twice the price of those you listed.
Geoff A. J., California
gajCA is offline
post #9 of 41 Old 08-10-2019, 02:19 PM
bobknavs's Avatar
Quoted: 2218 Post(s)
Liked: 1577
(snip)
Option 1:
TOTAL: 3250
TOTAL: 4530
Just to reiterate what GajCA posted, both of those receivers are 7 channel only. They cannot process signals for 5.1.4, much less 7.1.4.
The least expensive option would be a 9 channel AVR that processes 11 channels, like a Denon AVR-X3600H (2019 model), AVR-X4500H (2018 model, not to be replaced this year), Onkyo TX-RX830, and others. An external 2 channel amp would be required to run a 7.2.4 Atmos system. One-box 11 channel AVRs, like the Denon AVR-X6500H, are more expensive.
The AVRs are consistent with a 5.1 system, which is all that you list the speakers for. They could go to 5.2.2 Atmos or 7.2 (non-Atmos).
gajCA likes this.
bobknavs is online now
post #10 of 41 Old 08-10-2019, 08:43 PM
Quoted: 489 Post(s)
Liked: 260
being in canada, you might ant to check out axiom audio. you might do pretty well on b-stock or refurbs. Solid customer support.
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #11 of 41 Old 08-10-2019, 09:50 PM - Thread Starter
Quoted: 29 Post(s)
Liked: 0
Hmm I've only been looking at towers but those Behringers look interesting. They are a good price, but am I sacrificing any sound quality? And I'm assuming that I wouldn't need a centre speaker if I went with 3 of them right?
rio72 is offline
post #12 of 41 Old 08-10-2019, 09:53 PM - Thread Starter
Quoted: 29 Post(s)
Liked: 0
Unfortunately shipping to Canada is $600, and I can't find a place to buy those in Canada
Looks like AT screen is my best bet. There will only be one row. Probably just a basic sectional couch.
rio72 is offline
post #13 of 41 Old 08-10-2019, 09:56 PM - Thread Starter
Quoted: 29 Post(s)
Liked: 0
Under $4k.
I can't seem to find the JBLs in any canadian retailer. The atmos speakers look solid though and I will consider those, as well as the sub.
rio72 is offline
post #14 of 41 Old 08-10-2019, 10:00 PM - Thread Starter
Quoted: 29 Post(s)
Liked: 0
So would you say the kef towers are a decent option?
rio72 is offline
post #15 of 41 Old 08-10-2019, 10:09 PM - Thread Starter
Quoted: 29 Post(s)
Liked: 0
I wonder why my installer recommended those receivers then. Especially since he told me I had a 7.1.4 set up
The Denon x6500h is $3000 so I think a 9 channel AVR with an external 2 channel amp is probably better for me. Is there any downside to this though? Compared to getting an 11 channel AVR.
rio72 is offline
post #16 of 41 Old 08-10-2019, 10:58 PM
bobknavs's Avatar
Liked: 1577
I hope that it was a communication problem.
What do you intend for the additional 2 base speakers, and the 4 Atmos speakers? They aren't in the quotes.
The main downside to using something like a Denon 4500 with an external stereo amp is, well, two boxes. If your external amp has a 12V trigger, its operation would be transparent (it would come on wit the AVR). Some amps also can power on in the presence of a signal, like most powered subs. That would be an acceptable alternative to the trigger.
post #17 of 41 Old 08-10-2019, 11:20 PM
pase22's Avatar
Liked: 2672
Why so many channels? A nice 5.1.4 would sound just as good and would save you a lot of money that can be put towards a 2nd sub. You'll need dual subs in a room that size.
CaptinCrunch likes this.
post #18 of 41 Old 08-11-2019, 09:14 AM
gajCA's Avatar
Liked: 5990
I'd settle for 5.1.4 as you have only one main couch.
$1600 at Amazon Canada for a Denon 4400.
The Polks would work fine as would the Polk in ceilings; 4 for Atmos.
SVS for a sub.
gajCA is offline
post #19 of 41 Old 08-11-2019, 09:34 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1476
^ prefer HSU or Rythmik for their tighter, more articulate sound compared to SVS, though it looks like options are limited.
Also, really surprised to hear the JBLs are hard to find there. I think next option is to try to get those Polk 705s at the sale prices.
post #20 of 41 Old 08-11-2019, 10:19 AM
Quoted: 812 Post(s)
Liked: 667
SVS can be bought and delivered in Canada. The import/customs/taxes/delivery fees/currency exchange will AT LEAST double the price of Rhythmic and HSU offerings.
sigpig is offline
post #21 of 41 Old 08-11-2019, 10:23 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1476
Right, which is why I mentioned the Defiance X15. And don't pay MSRP since you can talk with a dealer.
SVS is good, too.
post #22 of 41 Old 08-11-2019, 10:49 AM
gajCA's Avatar
Liked: 5990
SVS is good, too.
Good point, Paradigm Defiance subs are a good option as well in Canada.
gajCA is offline
post #23 of 41 Old 08-11-2019, 10:52 AM
Zorba922's Avatar
Liked: 5375
Yes, you'd use the 3rd one as a vertical center...all 3 would have tweeters vertically aligned. Having 3 identical front speakers like that is actually the ideal configuration, much better than having a horizontal center.
For HT you mainly need detail and dynamics, which by all accounts those Behringers deliver in spades...best of all they do not require any sort of beefy amps to sound their best.
Also, the Behringers would allow you to devote more money to your subs---I'd get a pair of the SVS PB1000.
Zorba922 is offline
post #24 of 41 Old 08-11-2019, 02:10 PM
RayGuy's Avatar
Liked: 2498
I'd go with a receiver that is 11 channels, but only 9 powered. Then, if after you install the 5.x.4, you feel there is something missing, you can accommodate those rear surrounds with an inexpensive two channel amp. The price difference between the 11/9 and 9/9 is not that great, but the difference between 11/11 and 11/9 is.
rio72 likes this.
post #25 of 41 Old 08-12-2019, 12:25 PM - Thread Starter
Quoted: 29 Post(s)
Liked: 0
Yeah that's probably a good idea. I'd like to upgrade to 7.1.4 in the future but I'm not opposed to 5.1.4 for now.
SVS for a sub.
5.1.4 for now it is. The denon 4400 is 1600 and the denon 4500 is 1500. Any big differences between the two?
The SVS subs look good too. Hard to find good subs in canada and the shipping from USA makes them pretty expensive. I can get 2 svs pb1000 for $1279.
rio72 is offline
post #26 of 41 Old 08-12-2019, 12:28 PM
gajCA's Avatar
Liked: 5990
Get the 4500 as it is the newer version.
rio72 likes this.
gajCA is offline
post #27 of 41 Old 08-12-2019, 12:28 PM - Thread Starter
Quoted: 29 Post(s)
Liked: 0
SVS is good, too.
Checked a few shops and the defiance x15 is 1900 here. Instead I can get 2 svs pb-1000's for $1279.
rio72 is offline
post #28 of 41 Old 08-12-2019, 12:30 PM - Thread Starter
Quoted: 29 Post(s)
Liked: 0
Leaning towards these for my front speakers for now. If the sound is similar to towers, it's definitely worth it for the cost savings.
rio72 is offline
post #29 of 41 Old 08-12-2019, 12:34 PM
bobknavs's Avatar
Liked: 1577
The 4500 is a 2018 model, but will not be replaced this year. The 4400 is from 2017, and should not be more expensive than the 4500. Differences: https://www.avsforum.com/forum/90-re...l#post56087556 There may be additional differences; I don't recall whether the 4400 supports DTS Virtual X. I believe that the 4500 will (firmware update). It's of limited value, though.
If you could get an AVR-X3600H for less than a 4500, it'd be worth a look. It's a 2019 model, with specs similar to a 4500. (The 3600 is very different from the 2018 AVR-X3500H.) If they were the same price, I'd buy the 4500, but the US list on the 3600 is considerably less. (They may be about the same on the street, though.)
rio72 likes this.
post #30 of 41 Old 08-12-2019, 12:49 PM
gajCA's Avatar
Liked: 5990
I'd forgotten that the 3600 is virtually identical now in every regard to the 4500 other than a meaningless 20 watts.
Here in the US the 3600 is $500 cheaper at the moment.
Could be true in Canada.
Wonder what the 4600 when it is released will have up its sleeve?
gajCA is offline
Reply Speakers
