which floor standing speaker should i purchase - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By pase22
  • 1 Post By pase22
post #1 of 25 Old 08-16-2019, 06:42 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 0
I am a newbie in hifi level
I am considering which speaker should i purchase
OBERON 7
Q acoustic 3050i
Mostly, i hope to use it for playing music, watching drama and movie.
Calvin Ng is offline
post #2 of 25 Old 08-16-2019, 07:40 AM
djp2k7's Avatar
Quoted: 391 Post(s)
Liked: 315
OBERON 7
Q acoustic 3050i
I would expect the Dali's to be the better sounding speaker. Here's a review on the Oberon 5 and they make some comparisons to the 3050i.
https://www.whathifi.com/us/reviews/dali-oberon-5
ADS L710 / KEF Q150 / HIFIMAN HE400i / Martin Logan Dynamo 300
NAD 720Bee / Schiit Modi 3 / Yamaha CD-S300 / XBOX One X
djp2k7 is offline
post #3 of 25 Old 08-16-2019, 08:40 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 0
compare the price of Q Acoustics 3050 5.1 set and Dali Oberon 7 5.1 set
Dali Oberon 7 5.1 around £2,000
Q Acoustics 3050 5.1 around £1,100
i think my budget cant not afford Dali Oberon 7 5.1 now
post #4 of 25 Old 08-16-2019, 11:45 AM
gajCA's Avatar
Quoted: 9390 Post(s)
Liked: 6473
How much is a Concept 40 based set where you live?
If music is a big part of the equation that would be a worthy consideration unless out of budget.
With the setup mostly for TV the 3050 setup should be fine.
Geoff A. J., California
gajCA is offline
post #5 of 25 Old 08-16-2019, 01:50 PM
pase22's Avatar
Quoted: 3482 Post(s)
Liked: 2940
Start with Q acoustics Concept 40's, then add the Concept center and 3010 surrounds later. It will be a very nice sounding setup for both music and movies. Add in a BK electric Monolith sub and you're all set.
Kef LS50,Q200C, Q100, Kef Kube 10B (X2) , Denon AVR-X3400H, NAD 216 THX, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, SVS SB-2000, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #6 of 25 Old 08-16-2019, 06:16 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1872
Hmm,
But you can get these with money to spare for a subwoofer from Rythmik.
https://slickdeals.net/f/13262356-po...src=SiteSearch
The combination will be much better than speakers alone.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Polk LSiM 702 F/X (2) | Infinity RS152 (4) | Subs TBD (2)
PC: Micca OriGen G2 | Mackie MR624 (2)
Soulburner is offline
post #7 of 25 Old 08-16-2019, 06:58 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 0
i live in Hong Kong
post #8 of 25 Old 08-16-2019, 07:06 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 0
Thank you for all the suggestion, is it second hand Q acoustics 3050i would be another good option if my budget is limited,
the price become reasonable, i can use my spare money to buy center, Subwoofer together
post #9 of 25 Old 08-16-2019, 07:07 PM
Zorba922's Avatar
Quoted: 7480 Post(s)
Liked: 5706
Get the QA speakers separately from Amazon.co.uk since that package includes the totally useless QA housewife subwoofer, a weak center speaker, and undersized surrounds (3010).
On UK Amazon the 3050 are 449 quid a pair, 3020 are 258 for 2 pairs---use 1 pair for surrounds, the 3rd one for your center (vertical if possible, if not then on its side), and store or resell the 4th one. 449+258=707 which saves you about 400 quid vs the package...put the 400 quid into a decent subwoofer instead, like perhaps this:
http://www.bkelec.com/HiFi/Sub_Woofe...andFF_plus.htm
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #10 of 25 Old 08-16-2019, 07:07 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1872
i live in Hong Kong
Okay, that changes things.
post #11 of 25 Old 08-16-2019, 07:08 PM
Zorba922's Avatar
Liked: 5706
i live in Hong Kong
oops, then just see if you can get similar prices to what I posted above for individual QA speakers from Amazon UK.
I have no idea what decent subwoofers are available there, so can't help you there.
Zorba922 is offline
post #12 of 25 Old 08-16-2019, 07:12 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 0
Yes, subwoofers is a problem because no agency selling q acoustic subwoofers. i have to search which online shop can deliver to Hong Kong
post #13 of 25 Old 08-16-2019, 07:15 PM
Zorba922's Avatar
Liked: 5706
Looks like there is a distributor for SVS in Hong Kong: https://www.svsound.com/pages/international-dealers
Don't buy their speakers, but check how much their PB1000 costs over there.
Zorba922 is offline
post #14 of 25 Old 08-17-2019, 09:16 AM
gajCA's Avatar
Liked: 6473
No need to buy a Q Acoustic sub.
If you can get SVS that would be an improvement actually and if you are in a small apartment an SB1000 would be ideal.
gajCA is offline
post #15 of 25 Old 08-24-2019, 02:50 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 0
Sorry for the late reply
SVS Is too expensive to me, can you recommend some reasonable subwoofer that match my Q acoustic,
Thank you
post #16 of 25 Old 08-24-2019, 04:48 AM
pase22's Avatar
Liked: 2940
Thank you
If you want more impact for movies, A BK Monolith would be a good choice. If out of budget, a PB 12 or Double gem.
https://www.bkelec.com/HiFi/Sub_Woofers.htm
BufordTJustice likes this.
post #17 of 25 Old 08-24-2019, 08:36 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 0
how about Klipsch R-120SW?
post #18 of 25 Old 08-24-2019, 08:56 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 0
oh i haven't consider the space! is it the size of subwoofer is another consider factor?
post #19 of 25 Old 08-24-2019, 09:16 AM
pase22's Avatar
Liked: 2940
Room size is a huge factor. Also consider your expectations and desired output levels.
post #20 of 25 Old 08-27-2019, 03:27 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 0
i searched information that QED cable is suitable for Q acoustic,
here is the cables that it can purchase in my country.
https://www.price.com.hk/category.ph...0230&brand=QED
which one should i buy?
how about QED Ruby Anniversary EVO?
post #21 of 25 Old 08-27-2019, 06:01 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1872
They're all the same +/- a small portion of a percent; pick one that looks the nicest if it will be visible, or not if it will be hidden.
post #22 of 25 Old 08-27-2019, 02:54 PM
gajCA's Avatar
Liked: 6473
That would be a decent choice.
gajCA is offline
post #23 of 25 Old 10-13-2019, 10:58 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 0
Guys! finally i buy Q acoustic 3050i now!
i have to buy cable for it,
post #24 of 25 Old 10-13-2019, 11:08 AM
gajCA's Avatar
Liked: 6473
No need to spend a ton of money on it.
14 gauge copper wire is fine.
In the US that is about $22 for 50 feet.
https://www.monoprice.com/product?p_...hoCP0gQAvD_BwE
gajCA is offline
post #25 of 25 Old 10-14-2019, 07:22 PM
Quoted: 114 Post(s)
Liked: 69
I agree on switching out the sub, but I’m a big fan of the Oberons.
Main 7.1 HT: Dali Zensor (7s, Vokal, and 1s), Emotiva E2s, HSU ULS-15 MK2, Emotiva BasX preamp/amps (MC-700, A-300, A-500)
Kid’s 5.1 HT: Dali Oberon (5s, Vokal), RSL C34Es, HSU VTF-2 MK5, Denon X2400H
7-Zone CCA/Spotify WHA: Paradigm (E-80Rs x6, P-80SM), Def Tech AW6500s, Polk MC-80, Emotiva BasX amps (A-700, A-500), FiiO D3 DACs
Spectah is offline
Reply Speakers
