Not sure what to get, would appreciate help. - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By pase22
  • 1 Post By Refozo
  • 1 Post By bobknavs
  • 1 Post By gajCA
post #1 of 24 Old 08-19-2019, 12:32 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Hi all, I’m new to the audio game, and I want to get a nice sound system for my living room. I have some pictures attached but the room is 17ft long by 14ft wide with an open room behind it about 12ft behind living room(dining room)
Is that considered a big room as far as speakers are concerned? Or still small?
My plan is to mount the TV on the wall above the fireplace and mount a left and right on either side with a center below it and get two read speakers for 5.1 surround sound.
I was originally looking at the Bose Acousticmass mass 10 V with the Yamaha RX-V485BL receiver, but I want to know if that’s just a name brand id be buying or not? Is this receiver even good, and what type of speakers would be good for this size room? Any help would be appreciated.
ID:	2604824   Click image for larger version
Refozo is offline
post #2 of 24 Old 08-19-2019, 12:43 PM
pase22's Avatar
Quoted: 3292 Post(s)
Liked: 2736
Bose is way over priced! You can generally can a setup that will easily outperform them for less.
What is your budget?
Listening habits? moderate? loud?
system use? music? movies? how much of each?
Are you in the US?
Any WAF or aesthetic concerns?
Is mounting over the fireplace set in stone? Can you set up on the long wall?
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #3 of 24 Old 08-19-2019, 12:47 PM
Zorba922's Avatar
Quoted: 7090 Post(s)
Liked: 5396
Nothing wrong with the Yamaha receiver, it's the Bose that's overhyped, overpriced garbage.
Take 5 minutes to answer the previous poster's excellent starting-out questions, and you will get a slew of useful recs.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #4 of 24 Old 08-19-2019, 12:58 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Hey pace,
What is your budget? $1500 - $2000
Listening habits? Moderate
system use? music and movies
how much of each? Mostly movies
Are you in the US? Yes
Any WAF or aesthetic concerns? Not sure what WAF is.
Is mounting over the fireplace set in stone? Yes only because in the photo I have an office on opposite side of long wall (doors into the home office)
Can you set up on the long wall? No (see above)
Refozo is offline
post #5 of 24 Old 08-19-2019, 01:06 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Hey pace,
Sorry correction tv would be above fireplace but speakers could be on stands (to clarify)
Refozo is offline
post #6 of 24 Old 08-19-2019, 01:18 PM
pase22's Avatar
Liked: 2736
Hey pace,
The sub and center are your most critical pieces in an HT setup. You can just get an HSU hybrid 2 package and call it a day. Their rosewood speakers are actually much nicer than the website depicts. Alternatively, you can get 3 Chane A2.4'S or A1.5 + A2'4's with an HSU vtf-2 mk5.
http://www.hsuresearch.com/products/hybrid2mk5pkg.html
https://www.chanemusiccinema.com/A2.4
https://www.chanemusiccinema.com/A1.5
Lp85253 likes this.
post #7 of 24 Old 08-19-2019, 01:21 PM
bobknavs's Avatar
Quoted: 2250 Post(s)
Liked: 1606
(snip)
(snip)
Wife Acceptance Factor.
I don't know the size of the woofers in the Bose system, but the satellites are 3.3" wide, 3.3" deep, and 7.5" high. They must be 3" or smaller, which is too small.
I suggest the good (but not really popular) Hybrid 2 package from Hsu Research. http://www.hsuresearch.com/products/hybrid2mk5pkg.html The additional $152 over the similar Hybrid 1 package gets you a much more capable subwoofer.
The main drawback to dealing with Hsu is no free returns (for hardware that isn't defective). Other than that, they are a pleasant company to do business with, if you're in the US.
bobknavs is online now
post #8 of 24 Old 08-19-2019, 01:30 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
(snip)
(snip)
Lol she’s all for it so I’m good on that end.
Refozo is offline
post #9 of 24 Old 08-19-2019, 01:36 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Hey pace,
Pase, would the whole kits work well with the Yamaha I picked out or would a different receiver be better?
I had heard it’s better to buy prices than a bundle as far as quality was concerned, but I assume they are all separate pieces since it’s not actually bundled with a receiver correct?
Also these speakers will last or are they a bit future proof? Sorry for my lack of knowledge but my biggest sound system I’ve ever owned was a Sony STR-KS370 which I’m sure hitting a pot with a wooden spoon would sound better lol
Refozo is offline
post #10 of 24 Old 08-19-2019, 01:51 PM
Quoted: 438 Post(s)
Liked: 379
The HSU bundle is a good choice. Good rep, good sound, and awesome subs.
Chane is also a good choice. Very well received here on AVS. Great reviews.
Both are pretty efficient speakers so your Yamaha will be fine.
Other sub manufacturers to look at in case you go with Chane are Rythmik, Monolith THX, PowerSoundAudio, and SVS.
cocrh is online now
post #11 of 24 Old 08-19-2019, 01:58 PM
RayGuy's Avatar
Quoted: 2794 Post(s)
Liked: 2562
Consider getting a MantleMount, so the TV can be nearer eye height. You might also consider mounting he center speaker under the TV, so it floats with the TV. This would put your TV at a good angle for viewing (TVs mounted high cause neck pain unless you are in a recliner). The floating center channel speaker would also benefit by being much closer to the tweeter level of the speakers on the floor (bookshelf speakers on stands or actual floorstanding speakers).
https://www.mantelmount.com/collecti...down-tv-mounts
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #12 of 24 Old 08-19-2019, 02:06 PM
Zorba922's Avatar
Liked: 5396
Hey pace,
Simplest and best sounding option would be to do 3 identical wall mounted compact bookshelves above your TV, tilted downwards towards your listening position, and 2 more identical as surrounds if possible. This would give you the most seamless and uniform sound field.
Because that is a not-small space, the best thing to do would be to invest in a robust sub (or two), just tuck it away in one of the corners.
Most economical but still well performing solution would be 5 x NHT SuperOnes ($500 from Amazon) and a Hsu VTF-3 ($900 shipped). Or 5 x Ascend 200SE for $722 shipped. RSL CG23/CG3 also worth looking into, these have free return shipping if you are risk averse.
Lots of great options in that ballpark.
Zorba922 is offline
post #13 of 24 Old 08-19-2019, 02:40 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Hey pace,
How much better is the hay vtf 3 vs 2?
Also I could do vtf 3 and two hsu bookshelf’s with a center and upgrade to the rear bookshelf’s later if vtf3 is that much better
spyboy likes this.
Refozo is offline
post #14 of 24 Old 08-19-2019, 02:55 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
As for the mantle mount, it wouldn’t help as we usually have quite a few people over and if it pulled down it would put part of the screen in the way of peoples heads but it could be good for when I just want to watch a nice movie on my own I guess. I’ll check them out.
Refozo is offline
post #15 of 24 Old 08-19-2019, 03:05 PM
bobknavs's Avatar
Liked: 1606
The VTF-3 Mk5 uses 15" drivers. It's sort of a downsized version of Hsu's flagship VTF-15H Mk2. I believe that the VTF-3 is supposed to be about as loud at 25 HZ and up.
The VTF-2 has a 12" driver. I have two VTF-3s. I might have gone for the VTF-3, but the initial constraint I used was depth. The VTF-3 is 24" deep, the VTF-3 is 25" deep, and the VTF-15H is 28.5" deep.
I see from reviews at audioholics.com that the VTF-3 is about 6dB or so above the VTF-2 at 40 Hz. That suggests that the VTF-3 would be equivalent to two VTF-2s (neglecting spatial uniformity).
post #16 of 24 Old 08-19-2019, 06:40 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Also I could do vtf 3 and two hsu bookshelf’️s with a center and upgrade to the rear bookshelf’️s later if vtf3 is that much better
So if I got the flagship sub, and two bookshelf’s with a center would that be a decent sound system for movies, till I can afford the two back bookshelf’s?
Also these can all be mounted on a wall and pointed downward right?
Refozo is offline
post #17 of 24 Old 08-19-2019, 07:17 PM
Zorba922's Avatar
Liked: 5396
The rear surrounds typically do a measly 5-10% of the output during HT/TV, so that is definitely an area where you can wait until more funds are available. Many people deliberately go with rears from an entirely different make or model line if budget demands and they don't want to wait.
Zorba922 is offline
post #18 of 24 Old 08-19-2019, 08:25 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Bobknavs, you were talking about the higher dB and higher Hz for the sub is that what makes a good sub? Do I just look for high dB and Hz or is it really more than that? And would those same specs work when looking at bookshelf speakers and center speakers?
Is there a general spec I’m looking for to determine if a speaker is better than another?
Also do certain speakers pair better with certain name brand receivers?
Sorry if these questions are dumb, I’m just trying to figure this out...
Refozo is offline
post #19 of 24 Old 08-19-2019, 09:05 PM
bobknavs's Avatar
Liked: 1606
The Hsu HB-1 and HC-1 have no provision for mounting built in. I'm using a pair of these: https://www.amazon.com/VideoSecu-Cla.../dp/B000X9O8SI but they only tilt down 10°. It wouldn't work at all with the HC-1, which is 23" wide. (Max width is 11".)
You can get greater flexibility of you're prepared to drive screws into the speakers.
The better approach would be to mount the front 3 so that their tweeters are near ear height, and the speakers are in their normal orientations.
post #20 of 24 Old 08-19-2019, 09:16 PM
bobknavs's Avatar
Liked: 1606
I'm not prepared to write an essay, largely because I don't know enough.
I believe that speakers don't "pair" with certain receivers (or brands). Some receivers might go into thermal protection if used with 4 ohm speakers played loudly for long periods. The Hsus are 6 ohm speakers, which should be OK with most AVRs.
One consideration with receivers is the room equalization software included. Denon and Marantz are the only ones that still include Audyssey. In the Denon line, the AVR-X3400H and its descendants are the lowest-end models that have Audyssey XT32, plus SubEq (equalizes 2 subs semi-independently). There may be better software, like Dirac, which tends to be found in more expensive AVRs. (The cheapest that I know of that bundles Dirac is the NAD T 758 V3. It has some limitations, like few HDMI ports, but it comes with Dirac.) Room equalization can be controversial; some people prefer to not use it at all.
Soulburner likes this.
post #21 of 24 Old 08-20-2019, 10:28 AM
gajCA's Avatar
Quoted: 8964 Post(s)
Liked: 6132
While the HSUs are a good suggestion they are quite large and it seems the best location for it would be on the actual mantelpiece so getting a smaller center with dual 5.25" main drivers would allow the TV to be a bit lower.
What city are you located in just in case there is a nearby quality vendor or speaker manufacturer near you.
Geoff A. J., California
gajCA is offline
post #22 of 24 Old 08-20-2019, 01:14 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
So if I got the flagship sub, and two bookshelf’️s with a center would that be a decent sound system for movies, till I can afford the two back bookshelf’️s?
Currently in Clovis CA area.
Refozo is offline
post #23 of 24 Old 08-20-2019, 01:51 PM
gajCA's Avatar
Liked: 6132
Well if you are ever near Benicia that is where NHT is located.
NHT would actually be a great choice for speakers.
Amazon sells cheaper than NHT direct and the C3 are first rate speakers of the highest order.
A steal for a 3 way at $268 each. Sealed so easier to place and easier to blend with a subwoofer, (but not an NHT subwoofer, there are better choices).
The 3 way center is a great price too at just $301.
https://www.amazon.com/NHT-Center-Ch...tronics&sr=1-4
https://www.amazon.com/NHT-Center-Ch...cs&sr=1-4&th=1
If you wanted to save a little money you could get these for the left and right but I'd stick with the 3 way center.
Or these.
https://www.amazon.com/NHT-SuperOne-...PWX0NYE9X7ZNA9
Lp85253 likes this.
gajCA is offline
post #24 of 24 Old 08-20-2019, 02:04 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Or these.
Cool I’ll check out the centers. I could get a wall mount that sticks out a bit to clear the brick so I could hang the center under the tv itself. But I’ll have to measure that.
Refozo is offline
Reply Speakers
