Dialogue too quiet, music/noise too loud - AVS Forum | Home Theater Discussions And Reviews
 9Likes
  • 1 Post By smithsabom
  • 1 Post By Russdawg1
  • 3 Post By naujoks
  • 1 Post By m0j0
  • 2 Post By Dave in Green
  • 1 Post By confinoj
post #1 of 23 Old 08-20-2019, 05:20 AM - Thread Starter
Quoted: 14 Post(s)
Liked: 3
I have a 5.1 setup, Klipsch speakers, Denon X1300W AVR.
I measured in the room with Audyssey.
Now when the dialogue is at a pleasant level, the noises & music are way too loud.
If I set the volume so that noises and music are pleasant, the dialogue is way too quiet.
What and where can I make changes to bring both sides on to the same level?
naujoks is offline
post #2 of 23 Old 08-20-2019, 05:42 AM
Quoted: 556 Post(s)
Liked: 292
there is a "dialog adjust" setting in the audio menu... you can bump it up there.
naujoks likes this.
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #3 of 23 Old 08-20-2019, 07:26 AM - Thread Starter
Quoted: 14 Post(s)
Liked: 3
Awesome, thank you, I'll check it out!
naujoks is offline
post #4 of 23 Old 08-20-2019, 07:27 AM
gooch02000's Avatar
Quoted: 134 Post(s)
Liked: 70
Also, if you haven't acoustically treated your room, look into that.
gooch02000 is offline
post #5 of 23 Old 08-20-2019, 08:20 AM
Quoted: 1738 Post(s)
Liked: 1339
Turn the center trim up a few dB, and the whole receiver volume down a few ticks. 90% of content dialogue goes through the center if I remember correctly.
Lp85253 likes this.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #6 of 23 Old 08-20-2019, 09:43 AM
RayGuy's Avatar
Quoted: 2852 Post(s)
Liked: 2620
If the center channel speaker is not well placed, you will have trouble hearing dialog. Be sure it is in an open space, at the front of whatever furniture it is sitting on and angled so that the sound is directed to your seated ear height.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #7 of 23 Old 08-20-2019, 10:18 AM
pase22's Avatar
Quoted: 3335 Post(s)
Liked: 2802
How is your center placed? In a cabinet cubbyhole? on top of the cabinet? above the TV?
Which Klipsch center and speakers?
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #8 of 23 Old 08-20-2019, 10:23 AM
Pete7874's Avatar
Quoted: 297 Post(s)
Liked: 180
You can try turning on "Dynamic Volume" and setting it to "Light" if you haven't already. I find it greatly helps to bring up center channel volume in relation to the rest, especially at lower volume listening levels.
"The problem with quotes on the Internet is that you never know if they're real." - Abraham Lincoln
Samsung UN55B7100  Denon AVR-S740H  Chane A2.4  Dayton MK402X  Premier Acoustic PA120  Roku Premiere Plus  Squeezebox Classic  CCA
Pete7874 is online now
post #9 of 23 Old 08-20-2019, 10:26 AM
Rgb
Rgb's Avatar
Quoted: 657 Post(s)
Liked: 860
I usually balance my 5.1 setups dead nuts ~80dbA +/- 0.5 via SPL meter and/or Audessey plus manual SPL check, then bump up the front center 3-6db depending on room, seating and speaker characteristics, but usually no less than 3db or more than 6dbA
Rgb is offline
post #10 of 23 Old 08-20-2019, 11:10 AM - Thread Starter
Quoted: 14 Post(s)
Liked: 3
The "dialogue adjust" did the trick, I put it up by 6.5dB, and now everything is balanced.
Thanks everybody!
m0j0, shivaji and rbfastback like this.
naujoks is offline
post #11 of 23 Old 09-17-2019, 05:09 PM
rbfastback's Avatar
Quoted: 66 Post(s)
Liked: 29
does anyone know if the dialogue adjuster has the same drawbacks that the sub level adjuster has?
(NOT talking about the TEST TONE trim adjustments)
where when you turn the SUB LVL adjustment on, it resets your trim to "0" and then adds from there..
i wouldn’t want to use the dialogue adjuster if it did.
obviously it’s not a big a deal with the speakers as it is with the sub but i’d just like to know
rbfastback is online now
post #12 of 23 Old 09-17-2019, 05:48 PM
m0j0's Avatar
Quoted: 584 Post(s)
Liked: 559
I think the dialog adjuster works the same as increasing the trim on the center channel, but I could be wrong.
m0j0 is offline
post #13 of 23 Old 09-17-2019, 07:42 PM
rbfastback's Avatar
Quoted: 66 Post(s)
Liked: 29
i’d hope that at the very least it isolates the voice only and only boosts that aside from everything (like me just turning up the trim level..
post #14 of 23 Old 09-18-2019, 04:21 AM
m0j0's Avatar
Quoted: 584 Post(s)
Liked: 559
https://www.avsforum.com/forum/90-re...ting-avrs.html
rbfastback likes this.
m0j0 is offline
post #15 of 23 Old 09-18-2019, 07:29 AM
Bill-99's Avatar
Quoted: 853 Post(s)
Liked: 532
Dialog clarity comes up all the time, it seems. The points about center channel placement and acoustic treatment are good, as are the tips on dynamic volume and trim level adjustments.
Some additional thoughts:
- Be alert to any obstructions like chairs, tables, ottomans between the center channel and where you sit. Try moving them to see if it helps.
- The Dolby web site offers guidance on where all speakers should be located, and that can be important. For example, if the L/R channels too close to the center, they can overwhelm the center channel dialog.
- Center channel quality is crucial. If dialog isn't easy to hear and understand when other speakers are idle, well, that's not good. Start with checking the configuration settings, position, etc. But at the end of the day, it could mean the center you have isn't good enough for your needs.
- Source audio quality is all over the map. The best I've heard are some 4k blu rays which can sound great. Other times, not so much. The same is true for other disks, streamed content, cable / sat, and over-the-air broadcast TV. There's even variability in dialog clarity for different shows on the same TV channel, or the same show on two different TV channels. Ugh. This is a pretty common issue without a lot of great options.
- There is also the general problem of hearing loss that many people struggle with that complicates dialog clarity issues. (No specific advice here, just something to consider.)
When approaching this problem, IME many small incremental changes can have a huge impact though it can be time consuming. It took months to do all of this in my system. In the end, it was a worthwhile investment of time.
Just one more upgrade and things will be perfect.
Bill-99 is online now
post #16 of 23 Old 09-18-2019, 08:30 AM
Dave in Green's Avatar
Quoted: 3787 Post(s)
Liked: 3001
Another factor is personal preference. Some viewers are more focused on sound effects than dialog. And in the case of some movies you aren't missing all that much if you have a hard time hearing the dialog.
Fuzzy_Feet and Bill-99 like this.
Dave in Green is offline
post #17 of 23 Old 09-18-2019, 09:52 AM
confinoj's Avatar
Quoted: 1245 Post(s)
Liked: 1064
Good advice here. One more factor to add that I more recently discovered. If you have dynamic EQ enabled it boosts surrounds quite a bit and this can interfere with center channel intelligibility. Lowering surround levels if you otherwise like dynamic eq can help. I knew about the surround boost but never really realized it's affect on dialogue.
Bill-99 likes this.
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | Tivo Roamio OTA | Nvidia Shield | ATV 4K | Oppo UDP-203 | Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2
confinoj is offline
post #18 of 23 Old 09-19-2019, 07:43 AM
rbfastback's Avatar
Quoted: 66 Post(s)
Liked: 29
so basically the dialogue adjuster is the same as turning up the trim level for center channel.
tested it out at that’s exactly what it seems like, not specific frequency’s from what i can tell.
only the the much higher end denon increase the frequency for voice only
post #19 of 23 Old 09-19-2019, 08:06 AM
m0j0's Avatar
Quoted: 584 Post(s)
Liked: 559
Yes, that is my understanding as well.
m0j0 is offline
post #20 of 23 Old 09-19-2019, 08:09 AM
Pete7874's Avatar
Quoted: 297 Post(s)
Liked: 180
What would be the point of it if it was the same?
post #21 of 23 Old 09-19-2019, 08:22 AM
rbfastback's Avatar
Quoted: 66 Post(s)
Liked: 29
possibly simplicity for ppl that don’t individually adjust each speaker trim,
it’s easier.
also on the droid and apple applications the only option is the dialogue adjust, can’t do the levels under test tone from the apps.
just like how there are 2 subwoofer adjusters too (the one next to dialogue or the trim level one)
and on the more expensive x6500 people say it actually does different things
(only increases certain sound frequencies that affect voices)
post #22 of 23 Old 09-19-2019, 08:26 AM
MUDCAT45's Avatar
Quoted: 595 Post(s)
Liked: 405
Dialog on TV and in movies is soooooo inconsistent. Commercials are almost always crystal clear. I blame the mixing engineers for poor dialog more than any speaker that I have used.
MUDCAT45 is offline
post #23 of 23 Old 09-19-2019, 08:37 AM
Quoted: 279 Post(s)
Liked: 3
I had the same issue earlier and this ^ is what helped as well as setting center to +3dB.
Vikram Iyengar is offline
Reply Speakers
