5.1 speakers upgradd - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By edylie
  • 1 Post By edylie
post #1 of 21 Old 08-23-2019, 09:31 PM - Thread Starter
edylie's Avatar
I have a marantz nr1608 amp and looking to buy 5.1 speakers with sub with budget of 3000 usd.
Looking for wall mount small form factor speakers. Any recommendation?
50% music 50% netflix/tv
edylie is offline
post #2 of 21 Old 08-23-2019, 09:48 PM
PlanetAVS's Avatar
Quoted: 1968 Post(s)
Liked: 1836
Size of room? Do you need the sub(s) to be small form factor as well?
Here's a preliminary recommendation, assuming you can use two subs and they need to be smallish.
Q Acoustics 3090Ci center channel (190)
Q Acoustics 3020i bookshelfs x 4 (600)
HSU ULS-15 sealed subwoofer x 2 (1700)
PlanetAVS is offline
post #3 of 21 Old 08-24-2019, 08:21 AM
pase22's Avatar
Quoted: 3289 Post(s)
Liked: 2735
When you say small form factor, what are your size limits? H/W/D?
What's your budget?
How big is the room including open areas?
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #4 of 21 Old 08-24-2019, 09:52 AM
Quoted: 534 Post(s)
Liked: 278
Both of these have 1/4" screw mounts
NHT super zero x 5
or
Ascend acoustics HTM 200 x 5
sub(s) ULS -15 is excellent, but might be overkill in a small room.
more spendy, but higher performance: 5 x ascend acoustics Sierra luna + a single 400 sub ( Hsu VTF 1 mk 3) .... slightly over budget
refurb KEF LS 50's... no screw mounts... + sub could come in around target budget
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is online now
post #5 of 21 Old 08-24-2019, 12:08 PM
RayGuy's Avatar
Quoted: 2790 Post(s)
Liked: 2558
RSL speakers will wall mount well and have good output ...
https://rslspeakers.com/cg3-overview/
Paradigm has a small speaker that outperforms it's size:
https://www.paradigm.com/en/systems/...aone-50-system
Monitor Audio has been very well reviewed:
https://www.monitoraudio.com/en/prod.../apex-a10av12/
Wall mounting severely limits your options, as most speakers with any bass output will sound boomy. Thus, only small form factor speakers are listed.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #6 of 21 Old 08-25-2019, 10:56 AM
gajCA's Avatar
Quoted: 8958 Post(s)
Liked: 6125
In Singapore look into the Focal Sib Evo 5.1.2 system.
https://www.absolutesound.com.sg/hom...-packages#dome
Geoff A. J., California
gajCA is offline
post #7 of 21 Old 08-25-2019, 09:15 PM - Thread Starter
edylie's Avatar
Size of the room is about 500 sqft
sub woofer size height widht and depth ideally 30cm
front right and left speakers lenght 25cm (height no problem)
center speaker height 25cm (lenght no problem)
back left and right speakers lenght 25cm (height no problem)
Thank you for the recommendation.
edylie is offline
post #8 of 21 Old 08-25-2019, 09:17 PM - Thread Starter
edylie's Avatar
What's your budget?
Hi Pase22
my budget i can stretch to 3000 USD
edylie is offline
post #9 of 21 Old 08-25-2019, 09:18 PM - Thread Starter
edylie's Avatar
NHT super zero x 5
or
Thank you for the recommendation. I will check if there is a local reseller on these.
edylie is offline
post #10 of 21 Old 08-25-2019, 09:18 PM - Thread Starter
edylie's Avatar
edylie is offline
post #11 of 21 Old 08-25-2019, 09:19 PM - Thread Starter
edylie's Avatar
Ok. I will got an audition
edylie is offline
post #12 of 21 Old 08-25-2019, 09:20 PM - Thread Starter
edylie's Avatar
I am thinking to go for this https://www.bowerswilkins.com/mini-theater/mt-60d but some said it is very old set... what is your opinion?
Also I am going to replace my old speaker cables for this 5.1 setup. Any recommendation? The cables would be concealed.
edylie is offline
post #13 of 21 Old 08-25-2019, 09:24 PM
RayGuy's Avatar
Liked: 2558
Expensive! As to cables, if they are hidden, then use CL2 rated (in-wall) cable.
RayGuy is offline
post #14 of 21 Old 08-26-2019, 05:09 AM - Thread Starter
edylie's Avatar
did an audition today on mt-60d
Not overly impressive by it and considering it is pretty old model and heavy price tag ...
I am going to check out some other models mentioned on this thread on local audio shop ...
if you have any good recommendation please kindly share it here.
Thanks much
edylie is offline
post #15 of 21 Old 08-26-2019, 08:59 AM
gajCA's Avatar
Liked: 6125
That should be a nice setup, and if used, not that old at all.
All the B&W speakers I bought in the 80s, (7 of them), are in daily use today by family, friends and myself.
gajCA is offline
post #16 of 21 Old 08-26-2019, 09:13 AM
zieglj01's Avatar
Quoted: 3031 Post(s)
Liked: 2943
If your not really impressed, then yes check the other options ... it comes down to your ears and what will float your boat
Who AM I
zieglj01 is offline
post #17 of 21 Old 08-27-2019, 03:10 AM - Thread Starter
edylie's Avatar
Guys I ended up with Focal Dome Flax 5.1.2 with sub air and 2 atmos ceiling speakers.
They are coming to install tomorrow! ... cant wait
RayGuy and sigpig like this.
edylie is offline
post #18 of 21 Old 08-27-2019, 01:51 PM
gajCA's Avatar
Liked: 6125
Very nice.
Let us know your thoughts.
gajCA is offline
post #19 of 21 Old 08-27-2019, 02:32 PM
zieglj01's Avatar
Liked: 2943
Good call
Who AM I
zieglj01 is offline
post #20 of 21 Old 08-28-2019, 05:57 PM - Thread Starter
edylie's Avatar
the 2 x atmos speakers were unable to install as we were unable to run the cable nicely behind the tv console.
So far I love this set of Focal dome flax 5.1!
Btw the sub air always has a white led light on ... is that on permanently?
smithsabom likes this.
edylie is offline
post #21 of 21 Old 08-29-2019, 09:41 AM
gajCA's Avatar
Liked: 6125
Your manual says "yes" so you may want to turn the sub so is not pointing at you or simply cover the light with some black electrical tape.
https://pdf.crutchfieldonline.com/Im...091SUBAIRW.PDF
gajCA is offline
Reply Speakers
