Mixing Ribbons with Dome Tweeter - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By Zorba922
  • 1 Post By Lp85253
  • 1 Post By HumbertHumbert
post #1 of 23 Old 08-24-2019, 02:07 PM - Thread Starter
Quoted: 23 Post(s)
Hi All,
The upgrade bug has hit me sooner than I expected. Few days back, I came across Quad S1 bookshelves with ribbon tweeters and I am absolutely blown away. I want to buy them desperately. I understand I would need a matching centre as well. Currently I have KEF Q600 (along with KEF Q150 and Q300). It's a decent system but KEF sound, which is extremely analytical and less hifi-ish is not for me. Feel free to throw abuses at me
I am skeptical if KEF centre with aluminium dome would timbre match with Quad S1's ribbons. Note that I am concerned only about movies because music is always 2.0 for me.
Should I go ahead with the S1?
Quad S series has a center speaker as well but it is a bit out of my budget at the moment as I am planning to buy a marantz receiver (NR 1609) to replace an entry level Yamaha. I like warm sound but the Yamaha is quite bright. I am taking a leap of faith with Marantz's reputation of having a laid back warm sound signature (based on online reviews as it's difficult for me to visit the stores and listen in person).
Even if I go ahead with the Quad centre, a grave concern would be the centre's rear ported design. While the S1s are rear ported too I have space to keep them a foot away from the rear and side walls. Unfortunately, I do not have that luxury with the centre, which has to be placed with 5-6 inches of the rear wall (sides are open though).
Please advise. Your help would be much appreciated.
Stereo listening - Quad S1 / DAC - Schiit Modi Multibit / Sennheiser HD 598
Front Speakers - KEF Q300
Rear Speakers - KEF Q100
Center - KEF Q600
Receiver - Yahama HTR 3067
HumbertHumbert is offline
post #2 of 23 Old 08-24-2019, 02:19 PM
aarons915's Avatar
Quoted: 837 Post(s)
Liked: 670
I don't think they would match well but they won't be that bad if you need to wait awhile to get the center. I had the Q150 for awhile too and thought they were too laid back, you might go try to audition the LS50 and see what you think before ditching KEF, they are much more detailed than the Q150.
aarons915 is online now
post #3 of 23 Old 08-24-2019, 02:27 PM - Thread Starter
Quoted: 23 Post(s)
Thanks for the suggestion but in my part of the world, LS50 costs $2500. At that price I would have a lot of options, not to mention it is completely out of my budget.
Center - KEF Q600
post #4 of 23 Old 08-24-2019, 02:30 PM
aarons915's Avatar
Quoted: 837 Post(s)
Liked: 670
Ouch, yeah I understand that. One option that would probably match them decently well is the Chane A2 speaker, as long as it's not too much wherever you are.
post #5 of 23 Old 08-24-2019, 02:36 PM - Thread Starter
Quoted: 23 Post(s)
Seems like a great option, but not available locally
Center - KEF Q600
post #6 of 23 Old 08-24-2019, 02:40 PM - Thread Starter
Quoted: 23 Post(s)
Would you recommend this Dayton center with AMT Tweeter?
http://www.daytonaudio.com/index.php...eter-1539.html
Center - KEF Q600
post #7 of 23 Old 08-24-2019, 03:09 PM
zieglj01's Avatar
Quoted: 3037 Post(s)
Liked: 2948
No, they are entry level speakers
Who AM I
zieglj01 is online now
post #8 of 23 Old 08-24-2019, 04:33 PM
Billy p's Avatar
Quoted: 389 Post(s)
Liked: 789
My current setup-up albeit the same manufactuer....uses dome (nrt) mains with ribbon (RAAL) centre channel....in reverse...I would not recommend based on dispersion characteristics of said tweeters.
The primary reason for my switch was based solely on intelligibility integrity of dialogue during low listening levels and/or drama flicks because of the natural presentation attributes of the ribbon tweeter.
Ascend Acoustics: Towers, STC w RAAL & 200 SE in espresso,
54" of Panny Bliss, Anthem MRX 300, Oppo 103D,
Sub: Funk Audio 18: (Santos Rosewood)
Indian proverb: We don't inherit the earth from our ancestors but we borrow it from our children!
Billy p is online now
post #9 of 23 Old 08-25-2019, 08:18 AM - Thread Starter
Quoted: 23 Post(s)
Just found another option: Emotiva Airmotiv C1 with folded ribbon tweeter. I'm getting a pretty good price. Please advise if I should go ahead.
Center - KEF Q600
post #10 of 23 Old 08-25-2019, 08:23 AM
callas01's Avatar
Quoted: 1398 Post(s)
Liked: 949
Personally just get the S-C and for nothing else peace of mind..... that’s my opinion
Dynaudio Contour 20, Focus 210C, DM 2/6, Hsu VTF3 MK5 HP, Oppo BDP-103, Naim Uniti Star, Marantz SR5010, 60" 4K Samsung LED LCD, XBOX ONE S
callas01 is offline
post #11 of 23 Old 08-25-2019, 08:33 AM - Thread Starter
Quoted: 23 Post(s)
But won't the rear port cause issues close to the wall?
Center - KEF Q600
post #12 of 23 Old 08-25-2019, 09:37 AM
callas01's Avatar
Liked: 949
will it be on a stand? Put it at the forward edge of the stand and it’ll be fine. If up on the wall mounted put the port plugs in it.
callas01 is offline
post #13 of 23 Old 08-25-2019, 10:08 AM - Thread Starter
Quoted: 23 Post(s)
It will be wall mounted. Will port plugs impact the sonic performance of the driver?
Center - KEF Q600
post #14 of 23 Old 08-25-2019, 11:41 AM
zieglj01's Avatar
Liked: 2948
I would keep it on a short list
Who AM I
post #15 of 23 Old 08-25-2019, 12:17 PM
Zorba922's Avatar
Quoted: 7091 Post(s)
Liked: 5398
If you found that on CL for $75 I would jump on it.
I had the C1 with Wharfedale Diamond 10.1 which uses domes and is a very mellow laid back musical speaker, zero "matching" issues---don't fall for that silly old wives' tale!
Lp85253 likes this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #16 of 23 Old 08-25-2019, 12:53 PM - Thread Starter
Quoted: 23 Post(s)
I have got a new sealed box offer for C1 priced at $300.00. I thought it was quite reasonable?
Center - KEF Q600
post #17 of 23 Old 08-25-2019, 03:16 PM
Quoted: 2066 Post(s)
Liked: 1720
no that's too much ..$200 american is more like it ... they went for $250 new i think..
YAMAHA TSR 5790.. front l/r emotiva b1's and /or kef q100's ..BIC v1220.....Emotiva basx10.... ascend cbm 170 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. wharfedale 10.1s... ascend cbm 170 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is online now
post #18 of 23 Old 08-25-2019, 05:41 PM
Zorba922's Avatar
Liked: 5398
Where are you located? If in the US, then yes that's way too much. In other parts of the world, maybe ok.
Lp85253 likes this.
Zorba922 is offline
post #19 of 23 Old 08-26-2019, 03:15 AM - Thread Starter
Quoted: 23 Post(s)
I'm located in India .. so shipping costs are too high
Center - KEF Q600
post #20 of 23 Old 08-26-2019, 05:53 AM
Zorba922's Avatar
Liked: 5398
Then $300 for the Emotiva C1 is perfectly reasonable. Regular price is $250 in the US. Totally worth it for a solid center speaker, esp. if movies are your main usage---the center does 70-90% of the output and 99% of the dialogue.
Lp85253 likes this.
Zorba922 is offline
post #21 of 23 Old 08-26-2019, 09:02 AM
Liked: 1720
+1.. that is a reasonable price when adding transport costs on a 8,000 mile trip...
Zorba922 likes this.
post #22 of 23 Old 08-26-2019, 10:02 AM - Thread Starter
Quoted: 23 Post(s)
Feeling happier
Lp85253 likes this.
Center - KEF Q600
post #23 of 23 Old 08-26-2019, 10:39 AM
Billy p's Avatar
Quoted: 389 Post(s)
Liked: 789
Feeling happier [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
Haha...I always feel good buying my stuff stateside... only lasts untill... my my visa statement comes in....lol.
I hope, it works out for you... that's what will make it worthwhile...
Reply Speakers
bookshelf speaker , dome tweeters , Kef , quad speakers , ribbon tweeter
