Infinity RS4001 re-foam or replace woofers? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Boombox13
  • 1 Post By jtenn
post #1 of 9 Old 08-24-2019, 03:10 PM - Thread Starter
jtenn's Avatar
Quoted: 63 Post(s)
I picked up a pair of RS4001's at a garage sale and the foam around the woofers is starting to come apart. Should I refoam the woofers or would I be better off replacing them with something different?
jtenn is offline
post #2 of 9 Old 08-25-2019, 10:12 AM
Quoted: 253 Post(s)
Liked: 86
If the foam is inexpensive.......give it a try....nothing to lose.
If it works.....winner winner chicken dinner.
sigpig likes this.
59" Samsung Series 7000 Plasma TV Samsung BD-D5500 Blu-ray player
Onkyo TX-NR609 AV Receiver
Canton TBD (Center) Canton Chrono SL 596 DC (L & R)
JBL SP6CII (Frt Height & RR Surround)
Martin Logan Dynamo 1000
Boombox13 is offline
post #3 of 9 Old 08-25-2019, 11:41 AM - Thread Starter
jtenn's Avatar
Quoted: 63 Post(s)
The foam kits are about $20. I just didn't know if replacing the woofer with something else would be an improvement over the stock(re-foamed) woofers?
jtenn is offline
post #4 of 9 Old 08-25-2019, 02:50 PM
Quoted: 830 Post(s)
Liked: 669
It's $20 to test, vs a higher amount to match the drivers, so...
sigpig is offline
post #5 of 9 Old 08-25-2019, 03:35 PM
Quoted: 253 Post(s)
Liked: 86
X2
post #6 of 9 Old 08-27-2019, 08:48 PM - Thread Starter
jtenn's Avatar
Quoted: 63 Post(s)
I ordered the kit it should be here friday. I'll post back my results.
sigpig likes this.
jtenn is offline
post #7 of 9 Old 08-28-2019, 05:02 PM
head_unit's Avatar
Quoted: 569 Post(s)
Liked: 303
Good luck! Changing the surround may change the surround somewhat. But changing the whole woofer will definitely make a change, so that is less desirable.
head_unit is offline
post #8 of 9 Old 08-28-2019, 07:42 PM
WOKNROX's Avatar
Quoted: 385 Post(s)
Liked: 323
I did "all" the woofers on the bass stacks on some IRS Bata's I had... came out great but what a job..
Take it slow and keep the cone centered and you'll be fine.
Orotund Desert Theater:14'x20'x10',100amp service, JVC RS620, 120" AT screen, Carada Masquerade Masking, OPPO-203 & Panny ub820, Anthem AVM60, Simaudio Moon Titan 7&5 channel amplifiers, ACInfinity Fans, L&R Polk SDA SRStl Fully built, CC 2 Polk RTA15tl in Custom cabinets Fully build, SS-BS DT BPXV, 4 Atmos 3 way Core5's, Subs-Rythmik FV25HP front 2 HSU VTF-MK5-HP back, 2 Rows of 3 Seatcraft Excalibur Lx Seats and more.
WOKNROX is offline
post #9 of 9 Old 09-01-2019, 05:48 PM - Thread Starter
jtenn's Avatar
Quoted: 63 Post(s)
I replaced the foam surrounds and the speakers really sound good.
jtenn is offline
Reply Speakers
