Placement of rear ported speakers - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By head_unit
post #1 of 7 Old 08-25-2019, 01:46 AM - Thread Starter
Jim McC's Avatar
Quoted: 337 Post(s)
Liked: 107
How many inches does a rear ported speaker need to be from the wall behind it ? I've been reading conflicting things. I'm considering the Sony Core SS-CS5 bookshelf speaker. It would sit on a 1X12 shelf, so it would probably have 3-4 inches between the rear of speaker and the wall.
Jim McC is offline
post #2 of 7 Old 08-25-2019, 07:58 AM
Jonas2's Avatar
Quoted: 2825 Post(s)
Liked: 1786
Check the user info for the speaker - Sony might provide a recommendation on this. It does depend somewhat on the speaker design, but 3-4 inches in my opinion is pretty close. But if you don't have a choice, you don't have a choice. You could always look for a front-ported design.
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #3 of 7 Old 08-25-2019, 09:12 AM
Quoted: 534 Post(s)
Liked: 278
you may be able to place a "bung": a foam plug, into the port. many rear ported speakers come with this option... you may be able to make one as well.
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is online now
post #4 of 7 Old 08-25-2019, 09:39 AM - Thread Starter
Jim McC's Avatar
Quoted: 337 Post(s)
Liked: 107
Thanks. Would this affect this sound ?
Jim McC is offline
post #5 of 7 Old 08-25-2019, 02:53 PM
Ryan Statz's Avatar
Quoted: 296 Post(s)
Liked: 118
I think it would sound like a bit of a decrease in bass output, afaik (less "boomy"), but it might also result in tighter-sounding bass?
Home Theatre: Onkyo TX-NR747 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A4 Centre | Polk Audio RTi A1 Surround L/R | Elac S10EQ Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 x 2 (upcoming) | Subwoofer TBD
Ryan Statz is online now
post #6 of 7 Old 08-25-2019, 04:54 PM
Quoted: 534 Post(s)
Liked: 278
I may make the output more sealed(speaker)-like. due to its commonality, it appears to be a reasonable trade-off.
post #7 of 7 Old 08-25-2019, 09:11 PM
head_unit's Avatar
Quoted: 569 Post(s)
Liked: 303
Yes, better time response. Now, it might have more or less distortion at various frequencies, depending on the power level. But if used with a sub, I'd sure be trying this.
Anyway, I'd place a lot more importance on getting the best sound overall up into midbass, midrange, treble. The "blocking" of the port by a rear wall should not be a huge factor if crossed over to a sub. I'd also put some kind of a little pointed cone on the wall behind as a diffusor, kinda like Polk's Power Port.
Ryan Statz likes this.
head_unit is offline
Reply Speakers
