Placement of center speaker - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By RayGuy
post #1 of 8 Old 08-25-2019, 12:49 PM - Thread Starter
Quoted: 23 Post(s)
Let my start by giving you an overview of my listening position in my new house. I have a PC in front of me (at one foot distance) and the front speakers on either side of the monitor. There is no space to place a center here. However, I do need it as dialogues are not clear for movies encoded in multi channel audio. My question is can I place the center speaker behind the single seater couch? I have a shelf there on which I can keep the center at ear level. The shelf is about 3 feet from the couch. Will that position affect the intelligibility of dialogues?
Stereo listening - Quad S1 / DAC - Schiit Modi Multibit / Sennheiser HD 598
Front Speakers - KEF Q300
Rear Speakers - KEF Q100
Center - KEF Q600
Receiver - Yahama HTR 3067
HumbertHumbert is offline
post #2 of 8 Old 08-26-2019, 01:53 AM
Ryan Statz's Avatar
Quoted: 328 Post(s)
Liked: 137
It might be weird having the centre channel behind you. Have you considered just putting the monitor on top of the centre channel speaker? Or on a shelf above the monitor?
Home Theatre: Onkyo TX-NR747 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A4 Centre | Polk Audio RTi A1 Surround L/R | Elac S10EQ Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 x 2 (upcoming) | Subwoofer TBD
Ryan Statz is online now
post #3 of 8 Old 08-26-2019, 03:18 AM - Thread Starter
Quoted: 23 Post(s)
If I put the monitor above the center speaker, it will be too high and uncomfortable to look at from a close position. There are windows behind the monitor, so no space for a shelf I am afraid.
Center - KEF Q600
post #4 of 8 Old 08-26-2019, 11:02 AM
Quoted: 98 Post(s)
Mount the center speaker above the screen and angle it down towards your head/ear level.
Patrick Flaherty is offline
post #5 of 8 Old 08-26-2019, 11:14 AM
Ryan Statz's Avatar
Quoted: 328 Post(s)
Liked: 137
He has a window there, so he might not be able to mount it - unless there is room above the window? If he can, that'd be another option instead of putting it behind him.
post #6 of 8 Old 08-26-2019, 11:24 AM - Thread Starter
Quoted: 23 Post(s)
There is room above the window but over 7.5/8 feet from the surface. Won't it be too high? I had KEF Q600 which I had previously put on a display unit that was 6 feet high. Half the sound was lost. The unit was right in front of me albeit the centre wasn't angled towards me.
Center - KEF Q600
post #7 of 8 Old 08-26-2019, 11:27 AM
Muphasta's Avatar
Quoted: 248 Post(s)
Liked: 211
headphones. Center behind you may give you more dialog clarity, but it is less than ideal.
Can you rearrange your room to accommodate better listening?
Vinyl, tape, digital... I don't care as long as I can listen to my music...
Muphasta is offline
post #8 of 8 Old 08-26-2019, 12:46 PM
RayGuy's Avatar
Quoted: 2802 Post(s)
Liked: 2571
Just get one of these, problem solved:
https://www.amazon.com/Mount-Plus-MP...ssories&sr=1-5
Adamg (Ret-Navy) likes this.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
Reply Speakers
