KEF R11 or GoldenEar Triton One.R...? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 33 Old 09-07-2019, 10:45 PM - Thread Starter
Quoted: 2454 Post(s)
Liked: 1178
70% music, 30% movies.
Any thoughts?
Shopping List:
TV: LG C9/C10, or Samsung Q90R, or Sony ...
Blu-ray: Panasonic UB820, or Pioneer Elite LX500, or Sony X800M
AVR/Pre-pro: Marantz 8805/7705 or 8012, or Yamaha 5200 or 3080
Speakers: GE Triton One.R, or ML ElectroMotion ESL X
New24K is offline
post #2 of 33 Old 09-07-2019, 11:19 PM
Quoted: 1817 Post(s)
Liked: 1404
I personally would go with the Kef’s.
Are you using a sub?
Leave it at 8 ohms and call it a day :)
Russdawg1 is offline
post #3 of 33 Old 09-07-2019, 11:28 PM
torii's Avatar
Quoted: 3625 Post(s)
Liked: 2060
I really enjoyed some of goldenear towers, but crossed off my list due to not having flat top to put something on top of speakers...guess Im picky. havent heard kefs.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #4 of 33 Old 09-08-2019, 01:16 AM
Anygreg's Avatar
Quoted: 27 Post(s)
I agree, the new R series from KEF is almost on par with the current reference, certainly closed the gap considerably.
Anygreg is offline
post #5 of 33 Old 09-08-2019, 04:44 AM
KenM10759's Avatar
Quoted: 3454 Post(s)
Liked: 1932
Very biased opinion with me but I'll also vote R11's. When I heard them I was quite impressed that the little things I didn't like about the previous R900 (larger drivers less controlled) has been eliminated with the new series.
Plenty of bass there for 90% of the music most people listen to, but either speaker would benefit from true subwoofers to give frequencies below 25-30hz the force they should have.
KEF R500, R200C, R100, R50, SVS SB2000 sub, NAD T758v3 AVR, LG UP875 4K BlueRay, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer. Office: NAD M10, KEF LS50, KEF Kube 10b, Pro-Ject RPM1 TT w/ Ortofon 2M Red. Guest room: Hafler 300 L-R, KEF Reference Model 100 center, KEF iQ10 surrounds, modded M&K V-90 sub, Bluesound Vault 2.
KenM10759 is offline
post #6 of 33 Old 09-08-2019, 08:08 AM
mmiles's Avatar
Quoted: 1027 Post(s)
Liked: 527
Not listened to KEF in long time but I am very familiar with the GE line being a dealer.
The soundstage is amazing and you get 2 subs. Agreed to dig below 30hz at higher volume will probably require a standalone sub. This also depends on any room gain that is present.
Mike Miles
[email protected]
mmiles is offline
post #7 of 33 Old 09-08-2019, 09:59 AM
aarons915's Avatar
Quoted: 981 Post(s)
Liked: 774
The new R series is pretty good but a bit laid back, if you have Dirac live, XT32 or another way to EQ your response, that shouldn't matter but it's something to think about. At this price point you really have to at least listen to the Revel F206 or F208 and probably the Sierra towers as well to see if you might prefer a ribbon. I would probably narrow your choice down to 2 solid speakers and audition both in your own home, it's very difficult to compare speakers in showrooms, especially different ones.
aarons915 is online now
post #8 of 33 Old 09-08-2019, 10:18 AM - Thread Starter
Liked: 1178
Well, if I went with the KEF R11 - I would get a sub(s) - so the total price for the set up would be about the same.
Shopping List:
New24K is offline
post #9 of 33 Old 09-08-2019, 10:31 AM
Liked: 1404
Then yeah, the bass will outperform the goldenears, but even regardless I’d prefer the Kef’s because I like the looks and there’s something about the UniQ tech I just like.
post #10 of 33 Old 09-08-2019, 12:15 PM
gajCA's Avatar
Quoted: 9259 Post(s)
Liked: 6365
Top is listening window for the KEF's, bottom is the Golden Ears.
https://www.soundstagenetwork.com/in...=16&Itemid=140
Geoff A. J., California
gajCA is offline
post #11 of 33 Old 09-08-2019, 04:32 PM
KenM10759's Avatar
Liked: 1932
It should be noted that the method of measurement used doesn't take into consideration the contribution of the ports on the R11, and that's typically what fills in that dip you see. Also, if you go to the actual reviews there's some good info on manipulating the R11's response with the port plugs, with very positive results for the reviewer. When I heard them, they were driven by mid-level Naim gear and that drive the bass with very effective power and speed.
https://www.soundstagehifi.com/index...1-loudspeakers
post #12 of 33 Old 09-08-2019, 08:19 PM - Thread Starter
Liked: 1178
Have to admit, am a little surprised that everyone who gave an opinion on the two stated the KEF R11 - and not one GE One.R.
Shopping List:
New24K is offline
post #13 of 33 Old 09-08-2019, 08:38 PM
aarons915's Avatar
Quoted: 981 Post(s)
Liked: 774
You should really audition both and not rely on opinions on the internet. Comparing the listening window, for example, is a very amateurish way of deciding, considering most people listen to speakers a bit off-axis. The overall measurements of both are very good and you should really listen to both and see how you feel. The good news is you'll probably be happy with both speakers.
Lp85253 likes this.
post #14 of 33 Old 09-09-2019, 01:18 PM
gajCA's Avatar
Liked: 6365
"Amateurish?"
Listening window
20Hz - 20kHz (measured @ 2m, plotted @ 1m)
Response curve is an average of five measurements: on-axis, 15 degrees left and right off-axis, 15 degrees up and down off-axis
Complete off axis measurements were provided in the link.
All show a stark difference above 5khz and you know very well that the flatter the response the higher the preference.
gajCA is offline
post #15 of 33 Old 09-09-2019, 01:49 PM
aarons915's Avatar
Quoted: 981 Post(s)
Liked: 774
Originally Posted by gajCA View Post
"Amateurish?"
Listening window
Sorry I wasn't meaning to direct that toward you even though I can see why you would think so. I just meant that since most people don't listen directly on-axis, the listening window isn't necessarily a great measurement to rely on. In Harman's model, if you take out the bass extension (this is assuming that you're using subs of course), the on-axis accounts for 40% of the preference and off-axis is about 60%. So not only is it more important but I also believe that because of the way the testing is done, which is a single speaker directly on-axis in front of the listener, it might make the on-axis measurements seem more important than they really are since most of us don't point our speakers directly toward our ears. One of these days I'll get around to posing that question in the Science thread.
Either way, I think the OP has found a few really good speakers and he should probably audition them at this point.
post #16 of 33 Old 09-09-2019, 04:47 PM
gajCA's Avatar
Liked: 6365
I toe in my two sets of speakers so they aim at the main listening position; the cone and domes in my main HT and the AMTs in my secondary room.
But even at other seating positions I don't notice any "bad" effects.
My cone and domes measure well, my AMTs not so much; like them both!
gajCA is offline
post #17 of 33 Old 09-09-2019, 04:51 PM
torii's Avatar
Liked: 2060
you need to listen to em. here are some crappy measurements and I assure you they the most raved about speakers of the year. amazing....
https://www.stereophile.com/content/...r-measurements
torii is offline
post #18 of 33 Old 09-09-2019, 09:44 PM
Steve Dodds's Avatar
Quoted: 78 Post(s)
Liked: 48
As a long term owner of dipoles and an objectivist, I can assure you that all dipole speakers will exhibit similar behaviour when measured near-field. To get flat bass at the listening position requires a 6dB octave boost due to dipole cancellation.
Steve Dodds is offline
post #19 of 33 Old 09-09-2019, 09:52 PM
torii's Avatar
Liked: 2060
I have subs with mine and I boost 6-12db....but I boost my focals also. in my setup I can eq flat response on focals and its not what I want....and they measure pretty flat anyways....the maggies dont measure flat and I dont eq them to and they sound great.
torii is offline
post #20 of 33 Old 09-10-2019, 09:55 AM - Thread Starter
Liked: 1178
You should really audition both...
I have (well the R11 and the Triton One - not One.R) - but at different times and different places.
I listened to the R11 yesterday and to me it sounded quite "laid back" - as another commenter noted.
Now I am not sure if it was just because the music the guy was playing was in Tidal or...
Shopping List:
New24K is offline
post #21 of 33 Old 09-10-2019, 10:07 AM
tonygeno's Avatar
Quoted: 415 Post(s)
Liked: 152
Tidal should have zero to do with it.
Tony
In search of the Holy Grail.
tonygeno is offline
post #22 of 33 Old 09-10-2019, 11:36 AM
aarons915's Avatar
Quoted: 981 Post(s)
Liked: 774
The whole new R series is voiced that way, I'm really not sure why they choose to do that but they did. The good news is because the on and off-axis is so well behaved, they could easily be EQ'd to sound more neutral. If you don't have Dirac live or XT32 and don't want to mess with EQ, I would choose another speaker. I still think it's a good idea to audition the Revel F206/F208 but the Goldenears appear to be very good as well.
post #23 of 33 Old 09-10-2019, 04:27 PM
KenM10759's Avatar
Liked: 1932
I for one do not feel that they are laid-back. If you are accustomed to speakers with bright tweeters or ones with higher volume output of upper treble, perhaps you feel that way but I think they're already neutral.
post #24 of 33 Old 09-10-2019, 05:07 PM - Thread Starter
Liked: 1178
I guess I like a more "forward" sounding speaker vs. "laid back"...
I like to hear the singer singing "right in front" of me so to speak - and not back by the actual speakers...
Does that make sense?
Shopping List:
New24K is offline
post #25 of 33 Old 09-10-2019, 05:35 PM
KenM10759's Avatar
Liked: 1932
That's not a function of forward or laid-back, that's a function of how a speaker presents the soundstage. I get the feeling the R11's you heard were NOT set up right because they are one of the best speakers I've ever heard in that price range for creating a well-defined soundstage which had the ability to put a singer out front, the piano player stage right, the drummer behind the front of the speakers, a guitarist stage left, etc.
post #26 of 33 Old 09-10-2019, 06:00 PM
torii's Avatar
Liked: 2060
that type of soundstage with singer out front I have heard with focal sopras in small space and speakers close to walls. also had simaudio electronics. the catch however is I have only heard that type of stage with that particular room setup and electronics. so might of been a fluke. maybe you can experiment with your current gear and positioning to see if can replicate. most speakers designed to have image/stage behind the speakers.
torii is offline
post #27 of 33 Old 09-11-2019, 12:25 PM
Quoted: 837 Post(s)
Liked: 674
I auditioned the R900 vs the Paradigm Prestige 85F with the same electronics, same positioning, and same music. Both my wife and I didn't like the Kefs as they sounded congested(?), too laid back, and with poor bass punch compared to the Paradigms. This was shocking, since the two sets of speakers were approx the same price.
sigpig is offline
post #28 of 33 Old 09-11-2019, 12:26 PM
Liked: 1404
I think the R11 and R900 are quite different.
I wonder how you’d rate them if you did the same comparison with the Paradigms.
post #29 of 33 Old 09-11-2019, 02:37 PM - Thread Starter
Liked: 1178
This is exactly how I felt while auditioning the R11...
Shopping List:
New24K is offline
post #30 of 33 Old 09-11-2019, 07:38 PM
PhilH930's Avatar
Quoted: 64 Post(s)
Liked: 24
I can only speak to the KEFs vs. comparable models from B&W and ML, but to me the KEFs were superior in every way. I will say the amp/receiver made a big difference. I'm sure all testing is on high end equipment, but with any Denon (up to 8500) the KEFs did sound flat, slightly boring and dead. They really opened up with Marantz, more lively and energetic, and Arcam took them to a whole other level (I know Denon and Marantz are the same parent company and share 99.9% of parts, but everyone that heard the audition agreed). This was based on an R11.
I ended up ordering R7s as they fit my room better, coupled with some subs. Good luck - all wonderful speakers.
PhilH930 is offline
Reply Speakers
