AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Speakers (https://www.avsforum.com/forum/89-speakers/)
-   -   Guitar amp speaker replacement (https://www.avsforum.com/forum/89-speakers/3089546-guitar-amp-speaker-replacement.html)
paboucher 09-08-2019 11:15 AM
Hi
I have an old VT guitar amp with a 6 x 10 inches speakers cabinet. One of them is torn up so I have to replace it. But I can't find the exact same speaker anywhere. There are not much info on it: DWJ6 VT80005. The cabinet is a 6G10H from VT (Vibration Technologies from Canada) and is rated 8 Ohms and 140 Watts. I have checked the resistance on the unplugged torn speaker and got 5.0 Ohms. I have also checked the total resistance of the group of 5 speakers together (with the 6th unplugged) and got in the low 20s (was slowly going down). This makes me think that the speakers are 4 Oms each; am I right? Can I simply divide the 140 watts by 6 to get the minimum speaker wattage that I need?
Another question: what frequency response should I look for? Would 35 - 5700 be enough to cover all the sounds and harmonics a guitar can produce?
Wayne A. Pflughaupt 09-09-2019 04:29 PM
Can’t help you on finding a replacement for the strange speaker (never heard of a 6” x 10” speaker), but 35-5700 Hz is fine for a guitar.
Wayne A. Pflughaupt
paboucher 09-10-2019 02:55 PM
Not a 6" x 10" speaker!
Thanks for replying.
However, I am not talking about the speaker when I say «6 x 10 inches speaker cabinet». It's about the cabinet which has 6 speakers of 10" and one of them is torn.
Should be easier now!
DigsMovies 09-10-2019 03:14 PM
If the speaker is simply "torn", it can be easily repaired- either professionally, or via DIY repair kits.
Otherwise- there is a long list of good new replacement speakers, but they will be more expensive, and not tonally match the current speakers if that is important. Since the speakers are old, don't be surprised if others fail too.
Wayne A. Pflughaupt 09-10-2019 03:54 PM
Not sure how they managed to fit six speakers in a 6” x 10” cabinet, but:
https://duckduckgo.com/?q=10-inch+gu...t=brave&ia=web
Wayne A. Pflughaupt
DaleNixon 09-10-2019 04:38 PM
As long as the ohms match, guitar speakers don't necessarily have to match. Also guitar speakers typically reach down to 70-80hz.
Rex Anderson 09-10-2019 05:05 PM
Originally Posted by paboucher (Post 58529940)
Hi
Go to The Gear Page, find the appropriate thread and post there. https://www.thegearpage.net/board/index.php
Pretty sure someone on that forum will be able to help you.
DonH50 09-10-2019 05:12 PM
Wayne A. Pflughaupt
Six, 10" diameter speakers, in one cabinet.
Wayne A. Pflughaupt 09-11-2019 06:26 PM
Wow, how embarrassing that I couldn’t figure that out. I hope no one tries to repossess my Musician’s Card...
Wayne A. Pflughaupt
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
