New Side Mounted LCR Speakers advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-12-2019, 08:05 AM - Thread Starter
janitor53's Avatar
Hello - I'm on the hunt for some good quality side mounted TV speakers to pair with my E9 OLED. I had a Pioneer Kuro with the side mounted speakers for a long time, so I got spoiled with real decent TV sound. Was wondering what I should be looking for? My budget for this would be roughly $2500. Leon? Artisan? James? Paradigm? What's really good in this space for this price? Thanks for your help.
janitor53 is offline
post #2 of 10 Old 09-12-2019, 08:18 AM
Quoted: 1025 Post(s)
Liked: 559
Not sure what you mean by "side mounted" I assume you mean speakers on either side of the TV. Are you just looking for the LCR or do you want 5.1 also do you have/want a sub?
liffie420 is offline
post #3 of 10 Old 09-12-2019, 08:20 AM
Quoted: 1709 Post(s)
Liked: 1294
Artisan I think has the best one, James has a good one.
Both have different applications.
Both work with you to make a custom fit for your TV which is cool.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #4 of 10 Old 09-12-2019, 08:24 AM
zieglj01's Avatar
Quoted: 3038 Post(s)
Liked: 2948
As stated Artisan or James
Who AM I
zieglj01 is offline
post #5 of 10 Old 09-12-2019, 08:38 AM - Thread Starter
janitor53's Avatar
Yes, ones that mount to the tv sides. I don't have a sub yet, maybe/maybe not? This is a living room application, I have a home theater with a projector in the basement that's a more extreme setup. My wife doesn't like a heavy sub sound in her TV morning news watching! HA!
post #6 of 10 Old 09-12-2019, 08:47 AM - Thread Starter
janitor53's Avatar
are Artisan even shoppable? Or are those a product you have to get from an integrator/audio specialist?
post #7 of 10 Old 09-12-2019, 09:01 AM
zieglj01's Avatar
Liked: 2948
I think they may be discontinued ... also look at Leon speakers
https://www.leonspeakers.com/profile/pr33/
Also look at this speaker adapter ..... and then something like the Atlantic tech speakers
https://www.adorama.com/chpaclr2.htm...urce=adl-gbase
Who AM I
zieglj01 is offline
post #8 of 10 Old 09-12-2019, 09:01 AM
Liked: 1294
You’d need an integrator/audio specialist.
post #9 of 10 Old 09-12-2019, 09:04 AM
zieglj01's Avatar
Liked: 2948
Contact Savant
https://store.savant.com/DefaultStor...g000000KykxEAC
Who AM I
zieglj01 is offline
post #10 of 10 Old 09-12-2019, 01:13 PM
gajCA's Avatar
Quoted: 8967 Post(s)
Liked: 6134
Does the TV remain in place or do you pull the wall mount out and angle it as I assume you are talking about a wall mounted TV.
If the TV simply stays static you have a lot more choice for tall wall mount speakers that can be placed flush to the side of the TV.
Geoff A. J., California
gajCA is offline
Reply Speakers
