Speaker Setup Advice - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By gajCA
post #1 of 12 Old 09-14-2019, 10:06 AM - Thread Starter
kevdon15's Avatar
Speaker Setup Advice (In-Walls)
I am currently doing some remodeling in my basement, and I would like to upgrade my speakers. I current have Polk In-walls (RT Series). They've been serviceable, but I would like to step it up.
I'm just thinking about replacing the LCR speakers for now. Due to WAF, kids, and the desire to maximize floor space, I can't have the speakers in the room. I do have a utility area behind my screen about 4' deep. Would floor standing speakers be OK? I know I would have to make bigger holes and get some custom grill material to mount to the wall. But is it OK to put them in that space? Or am I stuck going with enclosed In-wall speakers? Thanks for your help.
ID:	2615040   Click image for larger version
kevdon15 is offline
post #2 of 12 Old 09-14-2019, 10:32 AM
hodgjy's Avatar
Quoted: 47 Post(s)
Liked: 66
You are stuck with in-wall speakers if you want to maximize their sound. Speakers are designed with their cabinets in mind, and they need to be out in the open. Placing them in the wall will alter their sound and will resonate in the wall. In-wall speakers are designed with this in mind and sound better than other alternatives.
hodgjy is offline
post #3 of 12 Old 09-15-2019, 03:35 AM - Thread Starter
kevdon15's Avatar
Thanks! Guess I'll stick with in-walls.
kevdon15 is offline
post #4 of 12 Old 09-15-2019, 03:50 AM
PlanetAVS's Avatar
Quoted: 2038 Post(s)
Liked: 1914
Would on wall be an option? They don't have to be wall mounted bookshelf speakers, you can get streamlined wallmounts that have a similar profile to a soundbar. Might not be kidproof though.
PlanetAVS is online now
post #5 of 12 Old 09-15-2019, 05:27 AM
Dawn Gordon's Avatar
Quoted: 422 Post(s)
Liked: 254
The right InWall speaker is a bit close to the right corner. This creates boundary reinforcement issues, whereby the right speaker will appear to have more bass than the left speaker. You would most likely have the same problems with a floor standing speaker as well.
________________________________________
[email protected]
Dawn Gordon is offline
post #6 of 12 Old 09-15-2019, 12:24 PM
gajCA's Avatar
Quoted: 9087 Post(s)
Liked: 6229
Take a look at Revel.
A receiver with good EQ should help with the boundary reinforcement issue as will using a 100hz crossover to a subwoofer.
https://www.crutchfield.com/fg_12600...-Speakers.html
Ryan Statz likes this.
Geoff A. J., California
gajCA is online now
post #7 of 12 Old 09-15-2019, 05:16 PM - Thread Starter
kevdon15's Avatar
Thanks, I'll check them out.
Thanks for the tip. I'm re-positioning the screen as well, any rule of thumb for how far I should be from the wall?
On-Wall would work. Is that a better way to go, acoustically speaking, all else being equal? Or is that a tough question to answer. Assume a budget of <$1000 / speaker.
kevdon15 is offline
post #8 of 12 Old 09-15-2019, 05:32 PM
PlanetAVS's Avatar
Liked: 1914
https://www.crutchfield.com/speakercompare/
https://novo.press/totem-acoustic-in...sound-to-look/
https://www.crutchfield.com/g_230150...&price=70-1000
Generally speaking on wall will allow you to get closer to traditional speaker performance. And it is less intrusive than in wall, it'll be more comparable to wall mounting a TV. And you'll be able to take the speakers with you or have more flexibility to change the speakers in the future.
I'll defer to others regarding how a particular model compares to your inwall Polks. Crutchfield has some KEF, Martin Logans and Revels on wall that look interesting. They also have a virtualized headphone speaker comparison tool, not sure how well it works.
post #9 of 12 Old 09-16-2019, 10:21 AM
gajCA's Avatar
Liked: 6229
At that price point I think you get better bang for buck with in wall vs on wall.
Just compare the driver size and pricing of Revel on walls vs in walls; no contest.
I believe there are some acoustical advantages as well to quality in walls installed correctly.
The disadvantage, of course, is if you move it's sometimes cheaper just to leave them behind.
gajCA is online now
post #10 of 12 Old 09-21-2019, 01:17 PM - Thread Starter
kevdon15's Avatar
So, I've done some research, and based on my budget I'm looking at the following:
Definitive Technology RLS II
Axiom M5HP
PSB W-LCR2
Anyone have any feedback on these models? I know the best thing to do is demo them, but I don't think that's realistic for me. So if anyone has experience with any of these speakers that they could share, it would be much appreciated.
kevdon15 is offline
post #11 of 12 Old 09-22-2019, 11:14 AM
gajCA's Avatar
Liked: 6229
Axiom M5HP
PSB W-LCR2
Rare to find pro reviews of in walls but I did find this effusive one by a guy who, evidently, has much much more expensive in walls in his actual home.
https://hometheaterreview.com/defini...kers-reviewed/
And lo and behold a review on the PSBs.
https://hometheaterreview.com/psb-c-...aker-reviewed/
gajCA is online now
post #12 of 12 Old 09-22-2019, 11:24 AM
lemonslush's Avatar
Quoted: 926 Post(s)
Liked: 456
Revel makes some of the best and accurate speakers around. I would say go with Revel in walls. Get the nices ones you can afford and you will be a happy camper. Even the entry level revels will make you existing speakers sound horrible.
You could also go with some larger in walls. Something like a Paradigm THX line would work well and get you decent output. Klipsch also has some higher end stuff with good SPL. Really depends on budget and how nice/loud you need them to be. Honestly if you just upgrade your sub/s instead of new speakers youll see a huge improvement.
If it was my setup I would do all revel in walls and 4 subs. If you can do for do as many as you can. If you need small subs SVS makes some nice small sealed ones. For nice small subs on a budget check out RSL's they can come with wireless receivers in them so need need to run RCAs. Two is like $800 or less if you don use the wireless ones and they have an in home trial.
RSL also makes a very affordable in ceiling speaker for atmos $125 each. I cant vouch for them personally but lots people like them.
"we need more power" - My Wife.
Theater Build Thread - Wartooth
lemonslush is offline
Reply Speakers
