Recommended ceiling speakers - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By pbz06
post #1 of 8 Old 09-14-2019, 12:18 PM - Thread Starter
ldbarchee's Avatar
Liked: 0
Question Recommended ceiling speakers
Hello AVS Forum!! This is my first post on here and I hope my question hasn’t been asked a thousand times before. I am looking to add 4 ceiling speakers to my living/home theater room to make my system a 5.2.4. I am running a Marantz SR7011 receiver with Polk Audio RTI A9 fronts, CSI A6 center, and RTI A3 for the rear with dual SVS PB 2000 subwoofers. What would be the best ceiling speakers to use that would match well with the rest of my system? My room is approximately 17x26 if that makes any difference.
ldbarchee is offline
post #2 of 8 Old 09-14-2019, 12:35 PM
355F1's Avatar
Quoted: 176 Post(s)
Liked: 42
Originally Posted by ldbarchee View Post
Hello AVS Forum!! [IMG class=inlineimg]/forum/images/smilies/biggrin.gif[/IMG][IMG class=inlineimg]/forum/images/smilies/biggrin.gif[/IMG] This is my first post on here and I hope my question hasn’️t been asked a thousand times before. I am looking to add 4 ceiling speakers to my living/home theater room to make my system a 5.2.4. I am running a Marantz SR7011 receiver with Polk Audio RTI A9 fronts, CSI A6 center, and RTI A3 for the rear with dual SVS PB 2000 subwoofers. What would be the best ceiling speakers to use that would match well with the rest of my system? My room is approximately 17x26 if that makes any difference.
Most forum members will recommend RSL Speakers C34E.
Check out their website.
😎It's just life, dude. We are all gonna die sometime--Might as well try and have a kickass time while we're still here.😜
355F1 is offline
post #3 of 8 Old 09-14-2019, 03:15 PM
m0j0's Avatar
Quoted: 607 Post(s)
Liked: 610
I have Polk LSiMs all around but use Focal Sibs for atmos, which I am pretty happy with. You may also want to check out Svs prime elevations.
m0j0 is online now
post #4 of 8 Old 09-14-2019, 04:15 PM
sdg4vfx's Avatar
Quoted: 243 Post(s)
Liked: 201
In-ceiling speakers or On-ceiling speakers?
My neighbors all listen to great music. Whether they like it or not.
sdg4vfx is offline
post #5 of 8 Old 09-14-2019, 07:20 PM - Thread Starter
ldbarchee's Avatar
Liked: 0
I haven’t heard of the rsl speakers before. Still pretty new in the HT world. I’ll give them a look. I have looked at the prime upfiring speakers but would rather go in ceiling. Also haven’t seen any of the on ceiling speakers. Any plus side to on over in ceiling speakers?
post #6 of 8 Old 09-15-2019, 09:58 AM
pbz06's Avatar
Quoted: 1090 Post(s)
Liked: 904
When I had polk audio, my ceiling speakers for Atmos were the RC80i's. They matched well with my RTi's.
yanks1 likes this.
Sony XBR-77A9G / Panasonic DP-UB9000 / Marantz SR7011 / Def Tech 9060 Series
pbz06 is online now
post #7 of 8 Old 09-15-2019, 10:57 AM
Quoted: 1034 Post(s)
Liked: 820
I have pair of Polk RC80i ceiling with my LSiM 703 fronts. And my primary Revel speakers set-up I use 4 RSL c34e speakers
Primary set-up 5.1.4; Yamaha A2050, Paired w/Parasound P5 & ATI 522NC 2 channel amp
Revel F206 fronts & Revel M16 rears; Outlaw X12 Sub & 4 RSL C34e in-ceilings
Secondary 5.1: Denon S900W, Polk LSiM703/704C, Polk RC80i in-ceiling rears, RSL Speedwoofer 10s
yanks1 is online now
post #8 of 8 Old 09-15-2019, 11:46 AM
RayGuy's Avatar
Quoted: 2867 Post(s)
Liked: 2633
Seems like Polk would be the most appropriate set, as they should have the same house sound as the mains. That said, much depends on your layout. How wide and deep is the area you have to cover? How far away will the in-ceiling speakers be from the seating? Have you consulted the Dolby site for specifications for speaker placement in a 5.x.4 set-up?
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
Reply Speakers
