Av receiver for Kef q650c and kef Q100 3.0 setup - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By m001john
post #1 of 7 Old 09-17-2019, 03:56 PM - Thread Starter
Quoted: 23 Post(s)
Liked: 8
I just purchased a kef q650c as a center to go with my Kef Q150. I am currently using a basic Yamaha vx383bl 5.1 receiver. Do you think I can run the 3.0 setup with my current reciever? If not do you have any suggestions for an upgrade at a budget with a 5.1 channel? Thanks!
m001john is offline
post #2 of 7 Old 09-17-2019, 05:16 PM
Ryan Statz's Avatar
Quoted: 444 Post(s)
Liked: 242
Probably, yes, as long as you’re not intending on listening at ear-bleeding volume levels.
KEF has told me that you ideally want to be in the upper 3rd of the speaker’s amp requirements, but they also said that you can have a lower WPC amp if you’re not going to listen at very loud volume levels.
I think you’d have to crank it pretty high before it becomes a problem.
Ryan Statz is online now
post #3 of 7 Old 09-17-2019, 05:48 PM
Quoted: 2102 Post(s)
Liked: 1758
it's going to be fine .. enjoy what you have...edit , i'm running the q100's with that receiver now ... zero issues
YAMAHA TSR 5790.. front l/r emotiva b1's and /or kef q100's ..BIC v1220.....Emotiva basx10.... ascend cbm 170 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. wharfedale 10.1s... ascend cbm 170 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is offline
post #4 of 7 Old 09-18-2019, 03:28 PM - Thread Starter
Quoted: 23 Post(s)
Liked: 8
thanks ! Yeah i live in an apartment, so wont be cranking up the volume too much. Will it affect in any way if i add Q100 as surrounds?
m001john is offline
post #5 of 7 Old 09-18-2019, 03:32 PM - Thread Starter
Quoted: 23 Post(s)
Liked: 8
Awesome ! Thanks, I am plannin gto add the Q100 as surrounds.
Lp85253 likes this.
m001john is offline
post #6 of 7 Old 09-18-2019, 03:40 PM
Liked: 1758
i think that receiver will do fine in 5.1, though i run mine 3.1 in a bedroom...
Lp85253 is offline
post #7 of 7 Old 09-18-2019, 07:17 PM
Ryan Statz's Avatar
Quoted: 444 Post(s)
Liked: 242
Probably not. For the same reason. There's a math equation somewhere that tells you just how much power your AVR is consuming at specific dB levels, and most people (especially those who sit closer - I, for example, sit about 6 feet away from my speakers) don't even consume 1 watt's worth of power. I think it would still take a massive crank of your volume level before it becomes a problem even with adding a pair of Q100s.
Unfortunately, I do not know what the math is on the division of watts per channel it ends up being if you, say, run a 5.1 system on a 70wpc into 8ohms at 2ch AVR.
Home Theatre: Onkyo TX-NR747 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R | Elac S10EQ Subwoofer
Reply Speakers
