Upgrading Speakers for around ~$650 Need advice - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Russdawg1
  • 1 Post By zieglj01
  • 1 Post By jvorn33
post #1 of 12 Old 09-22-2019, 09:02 PM - Thread Starter
Quoted: 22 Post(s)
Liked: 2
I’m planning on upgrading my current speakers and leave the AV receiver and subwoofer. My room dimensions are 17x10. I mostly use my speakers for movies and TV shows. I’m located in California and open for pre-owned or open box items.
Current system:
AV receiver: Pioneer 1123K
Subwoofer: SW-8MK2
L/R: pioneer SP-BS22
Center: SP-C22
My budget is $650 I can go up if it’s worth it. After doing some research I narrowed the speakers down to:
Chane A1.5 L/R, A2.4 center $588
Emotiva B1 L/R, C1 center $475
Ascend CBM 170L/R, 340 center $596
HSU HB-1 MK2 L/R, HC-1 center $519
These are the lowest I’ve seen them priced. If they’re listed for less somewhere else or there are discounts please lmk. If there are any other speakers I should look at please lmk I want to hear your recommendations!
soundmyman is offline
post #2 of 12 Old 09-22-2019, 09:09 PM
Quoted: 1745 Post(s)
Liked: 1342
The Ascends will play the loudest and with the most neutral sound.
It’s a toss up for personal sound preference though.
Lp85253 likes this.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #3 of 12 Old 09-22-2019, 09:55 PM
zieglj01's Avatar
Quoted: 3138 Post(s)
Liked: 3052
I would look at Ascend and Chane
Lp85253 likes this.
Who AM I
zieglj01 is online now
post #4 of 12 Old 09-23-2019, 01:50 AM - Thread Starter
Quoted: 22 Post(s)
Liked: 2
Ascend seems to be getting a lot of praise. Can’t lie I’m leaning towards them more now
post #5 of 12 Old 09-23-2019, 06:41 AM
Quoted: 37 Post(s)
Liked: 9
If its just the L/C/R for $650 I'd throw in the RSL CG3 line:
Either:
2x RSL CG3 @ $135 (https://rslspeakers.com/products/cg3-bookshelf-speaker/)
1x RSL CG23 @ $200 (https://rslspeakers.com/products/new...enter-channel/)
Total: $470
Or
3x RSL CG23 (they work horizontally or vertically) @ $200 (https://rslspeakers.com/products/new...enter-channel/)
Total: $600
I agree with the other posters that Ascend and Chane are also great options!
Lp85253 likes this.
jvorn33 is offline
post #6 of 12 Old 09-23-2019, 11:45 AM
gajCA's Avatar
Quoted: 9090 Post(s)
Liked: 6235
Current system:
Subwoofer: SW-8MK2
Center: SP-C22
If you are in the LA area you can go listen to the HSU and Ascend's and decide.
Geoff A. J., California
gajCA is offline
post #7 of 12 Old 09-23-2019, 12:13 PM
djp2k7's Avatar
Quoted: 359 Post(s)
Liked: 297
The Chane A1.5's took over the Emotiva as the budget speaker I'm most excited about. But I haven't heard either
djp2k7 is offline
post #8 of 12 Old 09-23-2019, 12:20 PM
Squirrel!'s Avatar
Quoted: 821 Post(s)
Liked: 511
The Chanes are in a separate class, much higher than they are priced. But, sound is subjective. I like planar tweeters sound. YMMV
Main: Mitsubishi 73736|OTA|fireTV|Sony BDP-S1100|Denon AVR4311CI|MartinLogan Preface|Phantom|MartinLogan Encore TF|1-1000watt & 1-500watt DIY 12" Subs|2 Bass Shaker|APC H15 Power Conditioner|Harmony Hub|Sennheiser RS 160|SMSL B1 BT Rx|Linksys SE2500
MBR: Vizio VF550M|OTA|fireTV3|Sony BDP-S1100|Denon AVR-X1000|Chane A1rx-c|Dayton SAT-BK|MartinLogan Dynamo 300|Belkin PF30|Harmony 550
Squirrel! is offline
post #9 of 12 Old 09-23-2019, 12:32 PM - Thread Starter
Quoted: 22 Post(s)
Liked: 2
I noticed the Kef Q150 going for $330 which is a great deal. If paired with Q600C, Q200C or another Q150 as a center channel, how would it compare to the Ascend or Chane front package?
post #10 of 12 Old 09-23-2019, 01:43 PM
stereojunkie's Avatar
Quoted: 76 Post(s)
Liked: 57
where are you seeing the Q150 for $330? I did not know it was back on sale?
stereojunkie is offline
post #11 of 12 Old 09-23-2019, 01:52 PM
Ryan Statz's Avatar
Quoted: 473 Post(s)
Liked: 257
I don't think it ever really went off sale. I ordered a pair back at the end of August, and it had been on sale for a while before I pulled the trigger. It might have gone back to regular price for a day or so before going back on sale.
Home Theatre: Onkyo TX-NR747 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R | Elac S10EQ Subwoofer
Ryan Statz is offline
post #12 of 12 Old 09-23-2019, 05:34 PM - Thread Starter
Quoted: 22 Post(s)
Liked: 2
accessories4less has the white ones for $330
Reply Speakers
