hook to rotate the speaker Atmos ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-28-2019, 05:53 AM - Thread Starter
Quoted: 90 Post(s)
Liked: 1
I have to install the speaker on the wall and rotate the speaker to the left or right?
Do these speakers have a hook to rotate the speaker?
for
ELAC Debut 2.0 A4.2 Dolby Atmos
or
Klipsch RP-500SA
la1vi9872 is offline
post #2 of 2 Old 09-28-2019, 06:02 AM
m0j0's Avatar
Quoted: 589 Post(s)
Liked: 574
The Elac you mentioned seems to be upfiring kind and not meant to mount on walls. The Klipsch can be wall mounted but cannot be rotated.
Maybe check these out, as they have some flexibility in terms of angling / rotating:
https://www.amazon.com/Polk-Audio-Wa...YG7KY9GWS3CDE8
https://www.amazon.com/Focal-SIB-Spe.../dp/B07DK2QZ4K
m0j0 is offline
Reply Speakers
