Quality center Vs Good center+sub to pair with bookshelf - AVS Forum | Home Theater Discussions And Reviews
 10Likes
  • 2 Post By cocrh
  • 1 Post By jmbgator
  • 2 Post By Ryan Statz
  • 1 Post By Elihawk
  • 3 Post By pase22
  • 1 Post By gajCA
post #1 of 16 Old 10-02-2019, 06:39 AM - Thread Starter
Quoted: 59 Post(s)
Liked: 2
hi
what is better in watching movies especially drama , alot of dialogues
Klipsch RP-500M + Klipsch 504 center ( 2.5-way Speaker)
or
Klipsch RP-500M + RP-500C + SVS PB1000
Ahmadss is offline
post #2 of 16 Old 10-02-2019, 07:31 AM
Quoted: 471 Post(s)
Liked: 411
A good sub is essential for movies.
Lp85253 and QuiGonJosh like this.
cocrh is online now
post #3 of 16 Old 10-02-2019, 08:17 AM
jmbgator's Avatar
Quoted: 43 Post(s)
Liked: 30
If your watching movies, a good sub is a major component. So definitely the Klipsch RP-500M + RP-500C + SVS PB1000
Lp85253 likes this.
TV: 65'' Samsung KS8000; AVR: Denon AVR X-4500H; Center Channel: Polk Signature S-35; L/R Channels: Polk Signature S-20; LFE: SVS-SB3000; UHD Blu-Ray Player: Sony UBP-X800; Gaming: PS4 Pro; Streaming Device: Apple TV 4K
IEMs: Shure 535, Shure 846; DAC/Amp: Dragonfly Cobalt
jmbgator is online now
post #4 of 16 Old 10-02-2019, 08:26 AM
Ryan Statz's Avatar
Quoted: 441 Post(s)
Liked: 240
Originally Posted by ahmadss View Post
hi
klipsch rp-500m + klipsch 504 center ( 2.5-way speaker)
or
klipsch rp-500m + rp-500c + svs pb1000
RP-500m + RP-504c + SVS pb-1000
Vikram Iyengar and Lp85253 like this.
Home Theatre: Onkyo TX-NR747 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R | Elac S10EQ Subwoofer
Ryan Statz is online now
post #5 of 16 Old 10-02-2019, 09:37 AM
Elihawk's Avatar
Quoted: 1941 Post(s)
Liked: 2085
I agree...subwoofer is a must. (assuming a fair HT usage)
Lp85253 likes this.
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is online now
post #6 of 16 Old 10-02-2019, 09:54 AM
pase22's Avatar
Quoted: 3336 Post(s)
Liked: 2803
Originally Posted by Ahmadss View Post
hi
or
For drama's with a lot of dialogue, go with the 504C + 500M. A sub is a must for HT so the PB-1000 is a good choice. If you're in the US, there are other options for speakers and sub.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #7 of 16 Old 10-02-2019, 11:46 AM
gajCA's Avatar
Quoted: 9089 Post(s)
Liked: 6232
hi
or
I doubt you'd notice much difference between the sound of those two centers to be honest.
But you WILL notice the big difference with a sub in play.
Vikram Iyengar likes this.
Geoff A. J., California
gajCA is online now
post #8 of 16 Old 10-02-2019, 12:05 PM - Thread Starter
Quoted: 59 Post(s)
Liked: 2
I quote this from klipsch thread
The 504C is known as a "2.5-way speaker", in that the inside mid-woofers play different frequencies than the outside mid-woofers. Since they have different crossovers, this helps to diminish the "comb-filtering" - a Venetian blind effect where there are drop-outs the further you move off-axis - the 504C will provide a wider listening window ie: it will cover the full length of a room instead of the person in the middle. That, plus the added cost of more speaker drivers, a larger cabinet for the speaker (including more internal bracing, a more complex crossover board, etc) will make the cost higher.
Ahmadss is offline
post #9 of 16 Old 10-02-2019, 12:09 PM - Thread Starter
Quoted: 59 Post(s)
Liked: 2
i am not from USA, i have limited options
the salesman told me to invest as much as i can in the center cause it will makes the difference in dialogues far than anything else
Ahmadss is offline
post #10 of 16 Old 10-02-2019, 12:09 PM
gajCA's Avatar
Liked: 6232
I think the whole center channel lobing which exists in theory and in measurement does not exist in actual practice to be honest.
I have MTM centers in both my systems, (albeit the tweeter in my main system is raised to minimize lobing), and moving from one side of the room to the other provides zero issues in terms of tone/intelligibility.
If you live in the States order both of those centers from Crutchfield and see for yourself with a total cost of $10 to return the loser.
gajCA is online now
post #11 of 16 Old 10-02-2019, 12:51 PM
pase22's Avatar
Liked: 2803
If your MLP is centered and don't have frequent listeners in different areas of the room, the 500C will likely get the job done.
post #12 of 16 Old 10-02-2019, 01:05 PM
gajCA's Avatar
Liked: 6232
While I listen in the center MLP 15 feet from the center my wife's chair is 4 feet in front of me and 5 feet to the left just outboard of the front left speaker which is about 8 feet from her.
2 way center with raised tweeter is under the TV aimed up at my ear level on the couch.
Center of TV is at eye level when seated.
She must be almost 45 degrees off axis.
Sounds just fine at her seat and the identical off axis seat on the other side of the room.
Here's measurements for an "ideal" three way center, and it looks horrible but the review notes it sound just fine.
"Though this is a three-way speaker, the physical law here is the same that causes midrange dips in the response of all the two-way (woofer-tweeter-woofer) horizontal center channel speakers we have tested over the years.
The only difference is the frequency involved.
For three people on a couch at 10' or so from the speakers, however, it shouldn't be a significant problem."
Read more at https://www.soundandvision.com/conte...b4oJMKIEraF.99
NHT Classic Three C, pseudo-anechoic response off the horizontal axis at 45° (red) and 60° (blue).
gajCA is online now
post #13 of 16 Old 10-02-2019, 02:35 PM
craig john's Avatar
Quoted: 1339 Post(s)
Liked: 1576
The article describes the sound:
Curiously, despite the 6.5" midbass and the generous 2" aluminum dome midrange drivers, I found the Classic system's overall sound somewhat withdrawn in the upper midbass/lower midrange region and cool sounding in the midrange; a combo that no amount of subwoofer fiddling could ameliorate. While it was possible to thicken and fatten the bottom end using the X2's controls, there was no warming up the midrange. Thus the system's ability to produce tactile, well-textured, harmonically complete and delicate images was somewhat restricted compared to some other (more expensive) speakers I've auditioned, including the less-than-stellar measuring Sonus Faber Domus system.
The measurement seems to verify the listening impressions. I'm very surprised you can't hear that, especially in off-axis LP's. (Disclaimer: I've never heard these speakers myself, so no first-hand experience.)
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #14 of 16 Old 10-02-2019, 02:47 PM
gajCA's Avatar
Liked: 6232
No, sorry, I don't own that particular speaker but was interested in that they said the mid range dip off axis for horizontal centers was common in their experience with both 2 and 3 way designs.
Personally with my Usher V603 center in my main HT room and the tiny Martin Logan Motion 8 in my secondary room I don't notice severe off axis dropoff but perhaps I'm not at 45 degrees at my most extreme seating positions.
Maybe because the Usher has a large 1.25" dome center that is raised or that the Motion 8 is acutally a curved design with the outboard midbass drivers being gently angled off center?
Measurements show that horizontal centers are a compromise design and an identical speaker to the left/right makes the ideal center oriented in the same manner but my compromised centers do the job for me which seems to be the consensus for most on AVS.
gajCA is online now
post #15 of 16 Old 10-03-2019, 05:33 AM
QuiGonJosh's Avatar
Quoted: 271 Post(s)
Liked: 117
It definitely will! I have owned mine for about a year and it's absolutely a wonderful center!
I would definitely go with the Klipsch RP-500M + RP-500C + SVS PB1000 option.
QuiGonJosh is offline
post #16 of 16 Old 10-03-2019, 09:31 AM
craig john's Avatar
Liked: 1576
Yeah, most on AVS are only concerned with one seat... the sweet spot, which is "their" chair. Most any horizontal CC will be fine directly on-axis, and even slightly off-axis. Most non-AVS'rs sitting off to the side are likely not concerned about sound quality, (SO's, kids, parents, friends, etc.) In that situation, a horizontal MTM, (or even a W(TM)W), that exhibits lobing and comb filtering won't be a concern for those listeners either. They likely don't care and/or don't know what to listen for anyway. Mostly, they'll be so overwhelmed by what they're hearing that they'll be impressed no matter what.
When I have people over, I always give up the sweet spot to my guests. If I have more than one person over who is interested in sound quality, (like an AVS GTG), I cycle each listener through the sweet spot. It's not just about the center channel speaker. It's also about imaging, soundstage, spaciousness, 3D immersion, optimized bass response, etc. All of those things come together most optimally in the sweet spot.
Craig
Lombardi said it:
My System
Reply Speakers
