I want to try out a center speaker $150-$900, recommendations sought - AVS Forum | Home Theater Discussions And Reviews
 23Likes
post #1 of 57 Old 10-05-2019, 11:44 AM - Thread Starter
mtrot's Avatar
Quoted: 650 Post(s)
Liked: 277
Question I want to try out a center speaker $150-$900, recommendations sought
Yes, I know that is a big price range. This is going to be essentially an experiment to see how a center speaker will improve, or not improve over my current "phantom" setup, in terms of dialog intelligibility. The caveat is that my setup is not ideal, and the speaker will have to sit low to the floor, perhaps on a slight stand of no more than 6-8 inches of height. The speaker will have to be angled up quite a bit. Yes, I am aware of possible reflections off the floor with the speaker that low. Now, around 10-15 years ago, I tried out 3 or 4 center speakers with little success, so I went back to the phantom setup. My thought now is to spend a bit more and try out a newer and hopefully better speaker and see if I can get better results. Also, I need to be able to drive this speaker with my Denon AVR-X5200 receiver.
As to what I have been considering, I've been looking a lot at used Revel. The reason I chose the low end of my price range is that I see I can get a nice used Revel Concerta C12 for $150. Reviews indicate that it is quite a good speaker, with original price of $500. I'd like to try a Performa C208, but it looks like that will cost around $1,300 for a nice used unit.
The other brand I'm looking into is Monitor Audio. I'm thinking along the lines of a used Gold GXC 350 or the newer Gold C350, but they are hard to find used. There is also the new, 6th generation Silver series, which offers the Silver C350, which can be bought new for under $900.
Any thoughts or suggestions appreciated.
FAMILY ROOM--Legacy Signature II towers(Front L/R), PSB Image 5T towers(Surrounds), Polk LSiM706 center, Denon AVR-X5200W, Krell FPB 400cx, AR ES-1 turntable w/ Audioquest 404-B cartridge, Oppo UDP-203 UHD Blu-ray Player, RCA HD-DVD player, Sony 75" 900E.
MASTER BEDROOM--Dynaudio Audience 82 tower speakers, Outlaw LFM-1 sub, Onkyo TX-NR809, Oppo BDP-83 Universal Disc Player, Panasonic 60-ST60 plasma TV.
mtrot is offline
post #2 of 57 Old 10-05-2019, 12:02 PM
shivaji's Avatar
Quoted: 1323 Post(s)
Liked: 1350
Is this to go in between your Legacy speakers? If so, have you looked at the used market for something in the same line.
shivaji is offline
post #3 of 57 Old 10-05-2019, 12:23 PM - Thread Starter
mtrot's Avatar
Quoted: 650 Post(s)
Liked: 277
Yes, for now. But I'm looking to replace them as well before too long.
mtrot is offline
post #4 of 57 Old 10-05-2019, 12:29 PM
Quoted: 439 Post(s)
Liked: 338
If that's the case and you're generally happy with your current phantom setup, then I'd instead focus on what you want in an L/R and consider all 3 speakers as a group together rather than add a random center now and then move to a new L/R. I don't necessarily feel you 'have to' have your L/C/R exactly matching but it certainly doesn't hurt.
KSpan is online now
post #5 of 57 Old 10-05-2019, 12:32 PM
RayGuy's Avatar
Quoted: 3350 Post(s)
Liked: 3141
With that poor center positioning, you might just be better off with the phantom center option. Throwing money at it is probably not going to result in much improvement, given the poor positioning. Is there any way you can improve the center's placement? Pics of the front stage would be helpful in brainstorming options.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #6 of 57 Old 10-05-2019, 01:12 PM - Thread Starter
mtrot's Avatar
Quoted: 650 Post(s)
Liked: 277
Originally Posted by RayGuy View Post
With that poor center positioning, you might just be better off with the phantom center option. Throwing money at it is probably not going to result in much improvement, given the poor positioning. Is there any way you can improve the center's placement? pics of the front stage would be helpful in brainstorming options.
As you can see, the only place I could now place a center speaker would be below the table on which the TV sits. That is not my current TV. My current TV is a 75" Sony. My wife wants the TV mounted on the wall, but that would involve some issues.
One, I would have to buy or create a wall mount device that could straddle and not damage that picture frame paneling behind the TV, or get some sort of TV stand that would accommodate a 75" TV and have a place for a decent sized center speaker below.
Second, I like the sense of visual immersion I get with the TV in its current position, which is about three feet into the room from the wall. With a wall mount or a stand in which the TV would be pushed back a couple feet, I would be effectively reducing the screen size effect that I am now getting.
mtrot is offline
post #7 of 57 Old 10-05-2019, 02:04 PM
Quoted: 560 Post(s)
Liked: 498
I'd suggest trying to get a new TV stand.
Or put a big center under the TV stand so the TV sits on the speaker. A center such as the PowerSoundAudio 210C could take the load of you TV if you slipped it underneath. Would also sound very good.
https://www.powersoundaudio.com/coll...ducts/mtm-210c
Although not sure that table could hold you 85lb TV and a 55lb center
bear123 and Muphasta like this.
cocrh is offline
post #8 of 57 Old 10-05-2019, 02:19 PM
bear123's Avatar
Quoted: 3274 Post(s)
Liked: 4923
I like the above suggestion. Just get a new TV stand instead of a coffee table or whatever, put the PSA MTM210C on top of it, and put the TV on top of the center channel if the stand will work. Center channels are for movies and you won't find a better one under $1k than the PSA.
rhelliott2 likes this.
bear123 is online now
post #9 of 57 Old 10-05-2019, 02:50 PM - Thread Starter
mtrot's Avatar
Quoted: 650 Post(s)
Liked: 277
Thanks, that table is strong as all get out! It would probably hold several hundred pounds.
mtrot is offline
post #10 of 57 Old 10-05-2019, 02:52 PM
zieglj01's Avatar
Quoted: 3384 Post(s)
Liked: 3286
I would look at PSA and Revel -- and yes try a new TV stand, maybe search some thrift shops for something better to put the TV on.
Who AM I
zieglj01 is offline
post #11 of 57 Old 10-05-2019, 03:00 PM
RayGuy's Avatar
Liked: 3141
Get a riser for the TV, so you can place the center channel in front of it. The center should be at the very front of the table, slightly overhanging it's front edge. Your TV is best positioned at 1/3 below eye level and 2/3 above (or 1/2 below and 1/2 above), and you clearly have plenty of room to raise the TV and still stay within those parameters.
Choose the center channel you want, and let it's height choose your riser height. Purchase or make ... whatever floats your boat.
Perhaps something like this:
https://www.amazon.com/WALI-Universa...VMJ9U9&sr=8-18
RayGuy is offline
post #12 of 57 Old 10-05-2019, 03:28 PM
capo4u's Avatar
Quoted: 158 Post(s)
Liked: 119
It's a lot less expensive than the PSA, and, I believe a lot less powerful, but I've liked the dialog intelligibility than I get from my Chane 2.4.
If you want to continue using the existing table, you could get a stand mount like this to elevate the TV without having to have it on the wall:
https://www.amazon.com/FITUEYES-Univ...-garden&sr=1-9
leecreek and RayGuy like this.
Receiver: Pioneer VSX-1022-K
Sub: SVS SB12-NSD
Fronts: Pioneer SP-BS22-LR
Center: Chane A2.4
Surrounds: Polk R15
capo4u is offline
post #13 of 57 Old 10-05-2019, 03:44 PM - Thread Starter
mtrot's Avatar
Quoted: 650 Post(s)
Liked: 277
Thanks, all. Great recommendations.
As this is in the family room, aesthetics and WAF are important. I found this and it seems to look quite nice. It's supposed to hold up to a 80" TV, and it will tilt downwards, which is important because the TV will end up quite a bit higher than now. And it looks like I could place the center speaker on it's top shelf, which is even better. It does look like I could use just about any size center speaker because that top shelf is 20" deep.
https://www.amazon.com/TransDeco-TD6...14067&sr=8-225
cocrh, shivaji, RayGuy and 2 others like this.
mtrot is offline
post #14 of 57 Old 10-05-2019, 04:26 PM
torii's Avatar
Quoted: 4133 Post(s)
Liked: 2420
I might try a polk https://www.adorama.com/pkalsim706cc.html
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is offline
post #15 of 57 Old 10-05-2019, 05:13 PM
Quoted: 560 Post(s)
Liked: 498
They have sale going on now and torii maybe wanted to paste that link.
https://www.adorama.com/pkalsim706cc...ce=rflaid62905
https://www.adorama.com/pklsim706cb....ce=rflaid62905
shivaji likes this.
cocrh is offline
post #16 of 57 Old 10-05-2019, 05:41 PM - Thread Starter
mtrot's Avatar
Quoted: 650 Post(s)
Liked: 277
Yes, I saw that sale. Looks very interesting. I've never owned any Polk speakers, but have read good things about the LSi series.
mtrot is offline
post #17 of 57 Old 10-05-2019, 05:45 PM - Thread Starter
mtrot's Avatar
Quoted: 650 Post(s)
Liked: 277
I realized that this unit is not going to work, because the TV is going to end up too far behind the plane of my front L/R speakers. I cannot move that right front speaker back because it would then end up too far behind the equipment rack. I don't want to move the equipment rack back any farther because then I could not get behind it to make any connections.
mtrot is offline
post #18 of 57 Old 10-05-2019, 06:18 PM - Thread Starter
mtrot's Avatar
Quoted: 650 Post(s)
Liked: 277
Thanks much, I think this is going to be the best solution, because this stand can be placed just far enough back on the coffee table to accommodate whatever center speaker I end up with.
mtrot is offline
post #19 of 57 Old 10-06-2019, 12:40 PM
Bill-99's Avatar
Quoted: 1024 Post(s)
Liked: 659
Not sure if you've considered a Revel C205 b-stock. It's normally a $1k speaker but b-stock puts it well within your price range.
mtrot likes this.
5.1.4 System: Anthem AVM 60 | Anthem Statement A5 | ATI AT526NC | Revel F208, C208, M106, C763L | Velodyne FSR-12 | Samsung UN65KS800DF | Oppo UDP-203 | Roku Premiere+ | DIY HTPC | Logitech Harmony Companion | Amazon Echo Dot
Bill-99 is offline
post #20 of 57 Old 10-06-2019, 03:05 PM
bear123's Avatar
Liked: 4923
Why does that matter?
Muphasta likes this.
post #21 of 57 Old 10-06-2019, 03:42 PM
Ryan Statz's Avatar
Quoted: 942 Post(s)
Liked: 624
That doesn't matter. It's the plane of the centre and LR speakers that matters.
Home Theatre: Marantz SR6014 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S | Nintendo Switch
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R
Ryan Statz is offline
post #22 of 57 Old 10-06-2019, 05:08 PM - Thread Starter
mtrot's Avatar
Quoted: 650 Post(s)
Liked: 277
Because, as I stated above, this is a family room A/V system and the L-shaped sofa extends to and then continues along the left wall. Check out my picture above. We often have viewers sitting on the sofa on the left side wall. If I move the TV back very far from its current position, the left front speaker will block them from seeing the TV. I may be able to get away with moving the TV back a foot, but not two feet.
mtrot is offline
post #23 of 57 Old 10-06-2019, 06:04 PM
Location: Geraldton - 250miles from Perth Western Australia
Quoted: 385 Post(s)
Liked: 166
If you have tried different centres before and they didn't work then your intelligibility issue is not due to the speaker and a better speaker probably won't solve your issue.
It is either room acoustics or speaker positioning that is the likely problem.
I have run phantom centres before and the only issue arises as you move further from the centre seating positioning, as the sound tends to follow you and comes more from your side.
Depending on how wide your seats are I would tend to stay with a phantom unless you can address the acoustics or positioning issues.
niterida is online now
post #24 of 57 Old 10-06-2019, 06:56 PM
Zorba922's Avatar
Quoted: 8326 Post(s)
Liked: 6369
Since this is an EXPERIMENT, why not take advantage of the free return shipping center speakers across various price points?
  • HTD Level 3 center, around $230 shipped
  • RSL CG25 center, $500 shipped
  • SVS Ultra center, $700 shipped
And with $10 flat rate return shipping:
  • Martin Logan 50XT, $900 shipped from crutchfield.com
Now that your center speaker placement issues seem to have been resolved, the above may produce some surprising results.
mtrot likes this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #25 of 57 Old 10-06-2019, 07:31 PM - Thread Starter
mtrot's Avatar
Quoted: 650 Post(s)
Liked: 277
Thanks. Good point, will check them out.
mtrot is offline
post #26 of 57 Old 10-06-2019, 09:17 PM
bobknavs's Avatar
Quoted: 2693 Post(s)
Liked: 1932
That's a better motivation than "I like the sense of visual immersion I get with the TV in its current position".
It also explains why you may be unhappy with a phantom center.
I second the use of a third-party stand that uses the VESA mounting points. That is what I'm using to clear a center that needs about 10" between the bottom of the screen and the table.
A riser is also a good idea, and may be cheaper. Ideally, it'd be custom made. Are you up for a little carpentry?
bobknavs is offline
post #27 of 57 Old 10-06-2019, 10:40 PM
The Village Idiot
Knucklehead90's Avatar
Quoted: 848 Post(s)
Liked: 786
Originally Posted by torii View Post
Excellent suggestion, especially at this price. I've had one in the house for about 2 weeks now. Very clear dialog.
I can't imagine that a phantom center would be even close to a good center speaker.
For the record, I swapped out a very nice Selah Audio custom one-off center speaker for the 706c. They are very similar in sound quality, IMO. The Selah center sold originally for $1199, so it should be an equal swap, and IMO, it is.
I've been more than mildly surprised at how good the Polk Audio LSiM series speakers are. The LSiM705's beat out a pair of Salk Song Towers. The bass is deep, and very detailed.
Yamaha A-S1000 - Salk Song Towers - HTPC (Linux) - Oppo 103 - Marantz TT42 (WWG1WGA) --- Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #28 of 57 Old 10-20-2019, 08:18 PM - Thread Starter
mtrot's Avatar
Quoted: 650 Post(s)
Liked: 277
Thanks again, everybody. I just pulled the trigger on a Polk LSiM706 from Adorama for $349, will try it out in my bedroom and family room systems. I can actually try it out in the bedroom system before I purchase or build a riser for the TV in the family room system. I figured since this is an experiment I could not justify spending any more for now and it looks to be a pretty good quality speaker.
Vikram Iyengar and Zorba922 like this.
mtrot is offline
post #29 of 57 Old 10-23-2019, 12:44 PM - Thread Starter
mtrot's Avatar
Quoted: 650 Post(s)
Liked: 277
Yes, I built a very rudimentary riser, on which I can set the TV. I will test out the new Polk inside the cavity of the riser.
mtrot is offline
post #30 of 57 Old 10-23-2019, 01:38 PM
Quoted: 935 Post(s)
Liked: 209
I love my Polk s30 and I'm sure you'll be very happy
Vikram Iyengar is offline
Reply Speakers
