Needs help to buy 3.0 speakers - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By cocrh
  • 1 Post By Zorba922
  • 1 Post By capo4u
post #1 of 12 Old 10-08-2019, 04:54 AM - Thread Starter
Quoted: 59 Post(s)
Liked: 2
Hi
I am seeking advice here, i need bookshelf speakers + center channel ( i dont need rear or side speakers) no sub no floorstand speakers
I have a yamaha receiver
I watch drama alot not into action movies at all
So dialogues is my main concern
Budget is USD 2000
Room 16X22 ft
Ahmadss is offline
post #2 of 12 Old 10-08-2019, 06:43 AM
Quoted: 472 Post(s)
Liked: 412
The Polk LSiM 703 bookself and 706C center are on sale at Adorama. Nice center as it is 3 way. Should give you great dialog. The center is large so check measurements.
703 Cherry or Black - $449 a pair
https://www.adorama.com/pklsm703mvc2...ce=rflaid62905
https://www.adorama.com/pklsim703b2....ce=rflaid62905
706C center - Cherry only it seems - $349 - They may be out of stock for black.
https://www.adorama.com/pkalsim706cc...ce=rflaid62905
Also check Emotiva B1+ and C2 center. Also a very nice sounding setup. Again the center is large so check measurements.
https://emotiva.com/collections/loudspeakers
Ryan Statz likes this.
cocrh is offline
post #3 of 12 Old 10-08-2019, 07:40 AM
pase22's Avatar
Quoted: 3350 Post(s)
Liked: 2824
Originally Posted by Ahmadss View Post
Hi
Budget is USD 2000
Room 16X22 ft
Chane A2.4 across the front.
https://www.chanemusiccinema.com/A2.4
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #4 of 12 Old 10-08-2019, 07:57 AM
Quoted: 560 Post(s)
Liked: 294
Anything by Ascend Acoustics is going to be very nice:
$: CMT-340 (~800 for LCR)
$$: Sierra 1 ( ~ 1150 LCR)
$$$: Sierra 2 (1448 LR) Sierra Horizon center ( 1k -1.1k)
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #5 of 12 Old 10-08-2019, 01:31 PM
gajCA's Avatar
Quoted: 9090 Post(s)
Liked: 6235
$10/box returns within 60 days if not happy.
Available in three finishes.
https://www.crutchfield.com/p_336EVO...ck.html?tp=186
https://www.crutchfield.com/S-AfhtaQ...hoCg0wQAvD_BwE
The AMTs in my Martin Logans are far smaller and they are crystal clear with dialog.
This 3 way design looks to be a big step up from that.
Geoff A. J., California
gajCA is offline
post #6 of 12 Old 10-08-2019, 08:47 PM
capo4u's Avatar
Quoted: 153 Post(s)
Liked: 108
Linking to the bundle options:
3 A2.4's ($80 off)
1 A2.4, 2 A1.5's ($60 off)
https://www.chanemusiccinema.com/ind...undles/listing
Also, the individual product pages indicate that the A2.4 and A1.5 are shipping free this month. Not sure if that also applies to the bundles.
To OP: you may be able to get away with the smaller A1.5 bookshelf speakers as the left and right options instead of the larger A2.4.
Receiver: Pioneer VSX-1022-K
Sub: SVS SB12-NSD
Fronts: Pioneer SP-BS22-LR
Center: Chane A2.4
Surrounds: Polk R15
capo4u is online now
post #7 of 12 Old 10-08-2019, 10:34 PM
Zorba922's Avatar
Quoted: 7156 Post(s)
Liked: 5466
My tastes & priorities exactly.
Emotiva C2 plus B1 would work perfectly, $630 shipped.
Throw in a Hsu VTF-2 for a little low end if you want, another $600 and you'll be set, plus $800 under budget.
Lp85253 likes this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #8 of 12 Old 10-08-2019, 11:13 PM
capo4u's Avatar
Quoted: 153 Post(s)
Liked: 108
Would the Emotiva setup be superior to the Chane A2.4 + A1.5's for $568 (possibly including shipping)?
Sub: SVS SB12-NSD
Center: Chane A2.4
Surrounds: Polk R15
post #9 of 12 Old 10-09-2019, 08:11 AM
Zorba922's Avatar
Liked: 5466
The A1.5 would be equal if not slightly better than the B1, but I would expect the C2 to be better than the A2.4 ... I suppose the ideal combo then might be the A1.5 with the C2 if one is not susceptible to the "timbre matching" superstition.
Lp85253 likes this.
Zorba922 is offline
post #10 of 12 Old 10-09-2019, 09:42 AM
capo4u's Avatar
Quoted: 153 Post(s)
Liked: 108
I don't remember noticing any timbre matching issues on any of the systems I've heard. I'm probably just not a very discerning listener.
Sub: SVS SB12-NSD
Center: Chane A2.4
Surrounds: Polk R15
post #11 of 12 Old 10-09-2019, 11:55 AM
Jon Lane's Avatar
Quoted: 331 Post(s)
Liked: 1092
Cap, I see the A2.4 in your signature - the A1.5 was designed to compliment it in a number of ways. It's a third larger in internal volume than a small 5" speaker, it's tuned about a third lower in frequency, and it uses the same SplitGap woofer, giving it substantially more dynamic reserve than usual. It's quite different; a true stand monitor and not a plus-sub shelf speaker. That said, stopping the rear port and converting it to sealed mode makes it compatible with subs.
Chane Music & Cinema
Need advice? Avoid speculation; for solid referrals seek out real users.
Jon Lane is offline
post #12 of 12 Old 10-09-2019, 12:01 PM
capo4u's Avatar
Quoted: 153 Post(s)
Liked: 108
Thanks. I've actually got the stopper in the A2.4 as well since it's kind of close to the back wall. It's crossed over to the sub at 80 Hz. I sent a private message to Zorba earlier today that I've been intending to pick up a pair of A1.5's to use as the fronts (moving existing fronts to surround and existing surrounds to garage).
Jon Lane likes this.
Sub: SVS SB12-NSD
Center: Chane A2.4
Surrounds: Polk R15
Reply Speakers
