Speaker Recommendations Please - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #1 of 47 Old 10-09-2019, 08:22 AM - Thread Starter
Quoted: 18 Post(s)
Liked: 3
I have the opportunity to get a Denon avrs950h receiver and I would like opinions on what center channel and L/R front bookshelf speakers to get. Exceptionally clear dialogue is important to us. I would like to keep the combined cost of the 3 speakers under $1000. Wife does not want us to have tower speakers. We listen to tv programs and movies. We don’t listen to music in that room. I figure I can use my Klipsch speakers for the rears that are hanging from the ceiling. The room is 20’ x 18’ with 12’ high ceiling.
cgmrtr is offline
post #2 of 47 Old 10-09-2019, 08:27 AM
Ryan Statz's Avatar
Quoted: 463 Post(s)
Liked: 250
Polk LSiM 703 L/R + 704C would be something to look into. They are on killer sales in a lot of places, and you could probably get all three for under $1K right now.
Edit: The only hitch off the top of my head for the LSiMs is that despite being bookshelf speakers, they are quite sizable - take note of the dimensions so that you don't get any surprises if you decide to go with them.
edwardccm and bear123 like this.
Home Theatre: Onkyo TX-NR747 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R | Elac S10EQ Subwoofer
Ryan Statz is online now
post #3 of 47 Old 10-09-2019, 09:29 AM
RayGuy's Avatar
Quoted: 2859 Post(s)
Liked: 2630
How are the speakers being placed? On bookshelves? On stands? Attached to wall? Pics would be helpful.
Requirements? Size? Aesthetics?
Have you done any listening sessions? If not, that may be the best next step, to see what speakers you like and dislike. What is it about your current speakers that needs improvement? Do your needs include a subwoofer? How far away do you sit? How loud do you typically listen?
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #4 of 47 Old 10-10-2019, 09:27 AM - Thread Starter
Quoted: 18 Post(s)
Liked: 3
I looked up those dimensions on the lsim703 and yes, they are rather sizeable. Would like to go smaller if possible. But if I can hear them and they knock my socks off, I'd get them.
cgmrtr is offline
post #5 of 47 Old 10-10-2019, 09:41 AM - Thread Starter
Quoted: 18 Post(s)
Liked: 3
Right now we have Klipsch RP250C center channel, Klipsch left/right front R-14M and a couple of smaller Klipsch hanging from the ceiling behind us. The left and right fronts are on Pangea stands. Yamaha rxv479 receiver.
Requirements? Exceptionally clear dialogue, as mentioned in op, because we don't use the room for music. Mostly tv/streaming and movies.
Size? The Polk LSiM 703 would be at the VERY upper limit.
Aesthetics? I have never seen any speakers that made me barf as far as looks go.
cgmrtr is offline
post #6 of 47 Old 10-10-2019, 09:51 AM
pase22's Avatar
Quoted: 3351 Post(s)
Liked: 2826
I'm guessing aesthetics are important. For strictly TV & movies, Klipsch RP-160's with RP-450C. Klipsch are very efficient will provide clear dialogue.
https://www.crutchfield.com/p_714RP1...60M-Ebony.html
https://www.crutchfield.com/p_714RP4...ony.html?cc=07
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #7 of 47 Old 10-10-2019, 10:36 AM
RayGuy's Avatar
Liked: 2630
Also, see the Chane "A" series for clear dialog and non-fatiguing highs. A2.4 x 3 or A2.4 + A1.5 x 2, would be a good choice.
Zorba922 likes this.
post #8 of 47 Old 10-10-2019, 11:48 AM
moodysj's Avatar
Quoted: 46 Post(s)
The BICAmerica DV62CLR center and DV62si bookshelves have great vocal clarity, and will come in around half your budget target for all 3
Sent from my SM-T817V using Tapatalk
moodysj is offline
post #9 of 47 Old 10-10-2019, 12:45 PM
Zorba922's Avatar
Quoted: 7157 Post(s)
Liked: 5467
$1K budget would actually get you a sub as well as 3 quality front speakers.
Chane A2.4 center + A1.5 L/R would run you $568 shipped.
https://www.chanemusiccinema.com/ind...undles/listing
Ascend 340SE center + 170SE L/R about $626 shipped.
http://www.ascendacoustics.com/pages...isor.mv#bottom
Leaves you with $430 to get a decent small sub like the RSL Speedwoofer 10S, or a little more to get a Hsu VTF-2 since your space sounds not-small.
1983weatherby likes this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #10 of 47 Old 10-10-2019, 01:17 PM
Quoted: 472 Post(s)
Liked: 412
Does your center speaker sound good to you now? It is the RP series so has tamed high frequencies. I'd try two RP160's as pase22 mentioned and see how they sound with your RP250C center. Then if that doesn't give you what you want go for the higher end Klipsch center RP-450C.
cocrh is offline
post #11 of 47 Old 10-11-2019, 11:29 AM - Thread Starter
Quoted: 18 Post(s)
Liked: 3
I would have to hear them - particularly since I've never heard of the brand. One reviewer said they were terrible until after the "break in" period. Unfortunately the only brick and mortar store around that I know of is Best Buy and they don't carry Chane. Crutchfield doesn't even carry them and they have a lot of brands.
cgmrtr is offline
post #12 of 47 Old 10-11-2019, 11:44 AM - Thread Starter
Quoted: 18 Post(s)
Liked: 3
I have heard of a lot of brands but unfortunately I haven't heard of "Chane", "Ascend" or "BICAmerica". I would have to hear them - particularly since I've never heard of those brands. I'm not saying they aren't good just because I haven't heard of them. But I would prefer sticking to a brand that I have heard of or can at least get from a major retailer - online or brick and mortar. Unfortunately the only brick and mortar store around that I know of is Best Buy and they don't carry Chane. Crutchfield doesn't even carry them and they have a lot of brands.
cgmrtr is offline
post #13 of 47 Old 10-11-2019, 11:44 AM - Thread Starter
Quoted: 18 Post(s)
Liked: 3
cgmrtr is offline
post #14 of 47 Old 10-11-2019, 11:46 AM
RayGuy's Avatar
Liked: 2630
Chane is internet sales only brand. You won't find them in any store. They do seem to need a break-in period, which some folks jump on as some sort of eighth deadly sin, but it's minor. Just run 'em in while you're at work for a few days.
Chane owners are very dedicated (as most owners are) to the brand, but not much in the way of professional reviews to be had. Maybe look at the Chane thread here on the site for comments/hands-on reviews.
RSL and Ascend are other brands with excellent reps that use the same on-line sales scenario. Plenty of feedback on these brands in this forum. If you are more comfortable with big-store speaker brands, then by all means stick to those brands. However, online purveyors eliminate the middleman and are perceived to deliver more speaker per $.
Lp85253, rossandwendy and yanks1 like this.
post #15 of 47 Old 10-11-2019, 12:07 PM
moodysj's Avatar
Quoted: 46 Post(s)
Must be a youngster. BIC America has been around since the early 70's. BIC was making speakers before Crutchfield was ever even an idea.
moodysj is offline
post #16 of 47 Old 10-11-2019, 12:48 PM - Thread Starter
Quoted: 18 Post(s)
Liked: 3
Thanks RayGuy. I'll look into them further.
cgmrtr is offline
post #17 of 47 Old 10-11-2019, 12:51 PM - Thread Starter
Quoted: 18 Post(s)
Liked: 3
I'm 71. And I remember having a Craig 8 track cartridge tape deck in my 1961 Chevy Impala convertible. BIC America...………. are they the same ones that make Bic pens?
cgmrtr is offline
post #18 of 47 Old 10-11-2019, 01:53 PM
Zorba922's Avatar
Liked: 5467
The ubiquity of a brand is usually a poor indicator of its actual quality, but more a reflection of the success of its marketing and distribution. You can find Budweiser in 99% of bars but anyone who knows beer knows it's mediocre at best.
Zorba922 is offline
post #19 of 47 Old 10-11-2019, 02:37 PM
gajCA's Avatar
Quoted: 9090 Post(s)
Liked: 6235
Are you located near any of these folks?
ACCESSORIES 4 LESS*** NEAR ORLANDO FLORIDA
APERION* NEAR PORTLAND OREGON
ASCEND** NEAR LOS ANGELES CALIFORNIA
CHANE TAMPA FLORIDA
CRUTCHFIELD*** CHARLOTTESVILLE VIRGINIA
DEEP SEA SOUND SUBS NEAR KNOXVILLE TENNESSEE
DIYSOUND GROUP CINCINNATI OHIO
EMOTIVA NEAR NASHVILLE TENNESSEE
HI FI HEAVEN*** GREEN BAY WISONSIN
HSU NEAR LOS ANGELES CALIFORNIA
HTD* NEAR DALLAS TEXAS
JTR NEAR MILWAUKEE WISCONSIN
MONOPRICE NEAR RIVERSIDE CALIFORNIA
MUSIC DIRECT*** CHICAGO ILLINOIS
NHT NEAR SAN FRANCISCO CALIFORNIA
OHM BROOKLYN NEW YORK
PSA NEAR YOUNGSTOWN OHIO
RBH NEAR SALT LAKE CITY UTAH
RHYTHMIK SUBS NEAR AUSTIN TEXAS
RSL* NEAR LOS ANGELES CALIFORNIA
SALK AUDIO PONTIAC MICHIGAN
SATURDAY AUDIO--- CHICAGO ILLINOIS
SEATON SOUND NEAR CHICAGO ILLINOIS
SELAH AUDIO NEAR RALEIGH NORTH CAROLINA
SVS* YOUNGSTOWN OHIO
TEKTON NEAR PROVO UTAH
TYLER ACOUSTICS NEAR LOUISVILLE KENTUCKY
WORLDWIDE STEREO*** NEAR PHILADELPHIA PENNSYLVANIA
CANADIAN MANUFACTURERS
AXIOM NEAR TORONTO CANADA
FLUANCE NEAR TORONTO CANADA
FUNK AUDIO NEAR VANCOUVER CANADA
PARADIGM NEAR TORONTO CANADA
PSB NEAR TORONTO CANADA
TOTEM NEAR MONTREAL CANADA
* free return shipping
**Ascend also carries Rhythmik subwoofers on site
***retail outlet of many brands
Geoff A. J., California
gajCA is offline
post #20 of 47 Old 10-11-2019, 03:09 PM - Thread Starter
Quoted: 18 Post(s)
Liked: 3
I agree up to a certain point. I'm not a fan of Budweiser or beer for that matter. I prefer bourbon. However, just like speakers, no one holds a gun to their head and forces them to buy it. If enough people did not like something - whether it is a beer, speakers, bourbon, a car or whatever - word would eventually get out that it was crap and people would not buy it.
cgmrtr is offline
post #21 of 47 Old 10-11-2019, 03:11 PM - Thread Starter
Quoted: 18 Post(s)
Liked: 3
CHANE TAMPA FLORIDA
No. Michigan.
cgmrtr is offline
post #22 of 47 Old 10-11-2019, 04:54 PM
Zorba922's Avatar
Liked: 5467
Not if those people have never bothered to try anything that wasn't constantly shoved down their throats by all the TV advertising that only the beer mega-corporations can afford to do. They have nothing to compare it against.
In the bourbon world, Jack Daniel's Black Label is the equivalent of Budweiser. Everybody's heard of JD, all over the world. It's THE brand that defines "bourbon" (or for the less literate, "whiskey") in the popular psyche. And yet there are plenty of small obscure bourbons like Four Roses Small Batch which cost about the same or less, which taste far far better. (Not to mention the similarly obscure Evan Williams bourbon that costs half as much as JD which many people find to be equal if not a lot better tasting.)
In the audio world, Bose is Jack Daniel's. Followed by most of the stuff sold at Best Buy---BB picks whatever products is best for Best Buy, because they know full well that the vast majority of the gullible/low-information public will blindly buy it.
Zorba922 is offline
post #23 of 47 Old 10-11-2019, 05:09 PM
bear123's Avatar
Quoted: 2656 Post(s)
Liked: 4152
I would second the suggestion for Ascend. Luckily, you don't have to audition speakers in person to know if your getting a good speaker....the right measurements are a better way to know for sure what your getting. Take a look at Ascends website...they have pretty good measurements on their speakers, and they have a pair or two that was independently tested at soundstagenetwork. A trio of Ascend 340's with a decent sub will be better than any LCR without a sub within any reasonable price similarity...even double.
However, I would also give a strong vote for the Polk LsiM at closeout pricing. These are also excellent quality speakers with superb measured performance. You could get by without a sub temporarily at moderate listening levels...but still strongly recommend a sub or two for movie use.
ID speakers from the right companies will get you better speakers at a better price than most retail unless you get a crazy closeout bargain on something like the Polk Lsim's.
bear123 is offline
post #24 of 47 Old 10-11-2019, 05:18 PM
bear123's Avatar
Liked: 4152
Klipsch are not "very efficient". Its true they have this reputation due to false advertising, but their actual sensitivity is typically slightly better than average. The RP-160M is 89-90 dB sensitive at best..again, maybe a little better than average.
Anyways, lying about the sensitivity does not make them *actually* highly sensitive, but it does a great job of getting lots of people to believe it.
Lp85253 and Zorba922 like this.
bear123 is offline
post #25 of 47 Old 10-11-2019, 06:45 PM
gajCA's Avatar
Liked: 6235
No. Michigan.
Then your best bet is to order two pairs of bookshelves from Crutchfield with their flat $10/box within 60 days return policy for bookshelves.
PSB, Martin Logan, Wharfedale, Klipsch RP, Elac, Focal are all within budget once you add a center.
If you buy two pairs and keep the winner the free shipping comes out of reward points for the loser so essentially free to return a pair if you keep a pair.
gajCA is offline
post #26 of 47 Old 10-12-2019, 07:16 AM - Thread Starter
Quoted: 18 Post(s)
Liked: 3
Interesting idea. Thank you.
cgmrtr is offline
post #27 of 47 Old 10-12-2019, 08:51 AM
RayGuy's Avatar
Liked: 2630
I'd make it three pairs. That way you have a real selection! Worth it's weight in gold for the peace of mind, let alone a measly $20/lost reward points. Given that you can probably find ML and Elac at your local BB (go listen!), try three of the other options.
post #28 of 47 Old 10-12-2019, 09:16 AM
gajCA's Avatar
Liked: 6235
Should be able to listen to the Klipsch RP there as well.
gajCA is offline
post #29 of 47 Old 10-12-2019, 09:27 AM
RayGuy's Avatar
Liked: 2630
Good point! Order 3, listen to 3, no guessing and no doubt about the final selection.
post #30 of 47 Old 10-12-2019, 09:33 AM
gajCA's Avatar
Liked: 6235
Well worth the potential $60 investment IMHO.
gajCA is offline
Reply Speakers
