$2000 5.1.2 Setup Help - AVS Forum | Home Theater Discussions And Reviews
 14Likes
  • 1 Post By Zorba922
  • 1 Post By M3MPH1S
  • 3 Post By pase22
  • 1 Post By macgallant
  • 1 Post By gajCA
  • 2 Post By m0j0
  • 1 Post By BlueGhost
  • 1 Post By gajCA
  • 1 Post By M3MPH1S
  • 1 Post By gajCA
post #1 of 27 Old 10-14-2019, 04:54 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 2
Question $2000 5.1.2 Setup Help
Hi, I just recently purchased a new house and will finally get to set up a proper surround sound system. I feel like I would get more out of 5.1.2 than 7.1, but would appreciate opinions on that as well. I would say the system will get 2/3 movie use and 1/3 music use. Assuming Atmos is the way to go, here's my thoughts. I'd really like to stay around $2000 for the speakers only. I'm planning on paring the speakers with a ~$500 9 channel receiver from accessories4less to give myself some headroom to add 2 more Atmos channels. The room is 27x12x8 and is almost completely sealed aside from an entry hallway.
Ok so my initial thought was SVS Prime for all the speakers and HSU VTF-3 MK5 for the sub, but that puts me at $2320
So I cut back a bit and went HSU sub (800), SVS Prime LR (500) and Atmos (400), and then DefTech ProCenter 1000 (180) and ProMonitor 800 (240) which puts me at $2120 - would like to hear your thoughts if those cost cuts are worth it.
I was also looking at Wharfedale Diamond 11.2 (500), Focal Chorus 706 (450), and Monitor Audio Bronze 2 (500) as other options for LR.
This led me to another consideration of stepping up the LR and really cutting back on surrounds and Atmos. I would like to hear your opinions on if this would make the system too unbalanced or if the benefit would be worth it. I know that's a fairly subjective question, but here's my alternative setup:
Still have DefTech center (180) and HSU sub (800)
Then either Wharfedale Evo 4.1 (700) or KEF Q350 (700) for LR
Then either Elac Debut B5.2 (190) or Jamo S 801 (174) for surrounds
And either Elac Debut A4.2 (190) or Jamo S 8 ATM (175) for Atmos
This brings the total to $2060 with Elac or $2030 with Jamo
I see the Elac Debut has fairly decent reviews for a budget speaker, so I assume it will perform decently as a surround, but I don't know if this is correct thinking. And the Jamo I can't find much info on but it also seems to be a "decent budget speaker". One other consideration with both these surrounds is that they were designed to pair up with their Atmos speaker counterparts, with the speaker resting or locking into place on top, so there is some "harmony" to consider. No idea if that makes any difference or it's just marketing. Hopefully I didn't leave any information out. I would appreciate any and all advice and opinions - including completely different speakers.
M3MPH1S is offline
post #2 of 27 Old 10-14-2019, 08:51 PM
Zorba922's Avatar
Quoted: 7307 Post(s)
Liked: 5591
I would steer clear of speakers from SVS and Def Tech, unless you know for sure that you prefer a forward, treble-intense presentation.
Your best bet if ordering unheard is finding speakers that are known to be neutral and relatively easy to drive.
The two that would best fit that description IMO are the Ascend 340SE and Chane A2.4 ... do a forum search, there's been tons of feedback about these two brands, overwhelmingly favorable. A front stage consisting of 3 of either one would be superb. And they will easily fit into your $2K budget with plenty of room to spare.
If you want the luxury of having free return shipping just in case, there's the HTD Level 3 speakers too.
Your Atmos speakers do not need to "match" the fronts or surrounds at all; in fact that is exactly where I would economize if needed (the second most logical place to economize would be the rear surrounds) since they do a miniscule % of the actual HT output.
M3MPH1S likes this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #3 of 27 Old 10-14-2019, 09:10 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 2
Excellent suggestions, thank you very much!
Zorba922 likes this.
M3MPH1S is offline
post #4 of 27 Old 10-15-2019, 07:32 AM
pase22's Avatar
Quoted: 3421 Post(s)
Liked: 2888
Another good option would be an HSU Hybid 3-5.1 package. Add in some inexpensive in-ceiling speakers and you're off to a good start. You can always add a 2nd sub later.
http://www.hsuresearch.com/products/hybrid3hppkg.html
https://www.accessories4less.com/mak...er-pair/1.html
M3MPH1S, Ryan Statz and sigpig like this.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #5 of 27 Old 10-15-2019, 10:51 AM
Quoted: 593 Post(s)
Liked: 335
DCM speakers are on extreme liquidation on ebay right now and cannot be touched value wise
TP260 towers $320
https://www.ebay.com/sch/i.html?_fro...tp260&_sacat=0
TP160 center & bookshelf $180
https://www.ebay.com/itm/1-Pair-of-6...cAAOSw7Wxdn0~C
this would leave you $1500 for subs/atmos. You could easily go with Dual HSU VTF-3 MK5's and something like sony cores atmos.
You could also go with another pair of DCM TP160S for $100 as front heights/Atmos
M3MPH1S likes this.
Speakers: KEF Q100, Q300, Q750, Q650C / Fluance Signature Series, SX6, XL5F/ Mirage M-190 / DCM TP160S-CH Subwoofers: Outlaw Ultra X12 (x2) / BIC H100-II
Receiver: Denon AVR-X4500H, AVR-X1400H Integrated Amplifier: Yamaha A-S501/ Fosi Audio TPA3116 mini amp Extras: MiniDSP Umik-1 Amplifier: Emotiva BasX-A300
macgallant is online now
post #6 of 27 Old 10-15-2019, 11:48 AM
gajCA's Avatar
Quoted: 9263 Post(s)
Liked: 6368
It seems you might be in Memphis.
Do you ever go to Nashville?
If so, Emotiva is located there.
Excellent speakers but I'd buy a subwoofer from HSU.
Ryan Statz likes this.
Geoff A. J., California
gajCA is offline
post #7 of 27 Old 10-15-2019, 12:03 PM
m0j0's Avatar
Quoted: 680 Post(s)
Liked: 700
Might also be worth considering Polk LSiM's since they have come out with a new line and the previous line is getting cleared out. I bought a pair of LSiM 705 towers, a 704c center and a pair of 703 bookshelf surrounds without hearing them in person and have been very happy with them. I agree with others recommendations as well in regards to Ascends, Chanes and Emotiva's, and potentially DCM's (though I haven't got any experience with them, they do seem to be a great value). All really good options.
M3MPH1S and Ryan Statz like this.
m0j0 is online now
post #8 of 27 Old 10-15-2019, 01:09 PM
Quoted: 16 Post(s)
Liked: 8
Check slickdeals.net for the Polk LSiM links.
You could get a pair of the 703’s for $450 and the matching center for $350. Add a decent sub from SVS for about $450.
That leaves plenty leftover for the surrounds and atmos. You can go cheaper on those IMO. I also see the Pioneer BS22 bookshelf speakers on slickdeals for only $48.
You could even upgrade to the 707’s and stay right at $2k.
Polk 707’s — $1100
SVS sub — $450
Polk 706 center — $350
Pioneer surrounds — $50
Micca in-ceiling atmos speakers — $80
soundsdivine is offline
post #9 of 27 Old 10-15-2019, 01:13 PM
Quoted: 593 Post(s)
Liked: 335
The DCM TP series is a noticeable improvement over the Polk RTiA series at half the cost. I compared the DCM TP160S vs the RTiA3's at my friends house recently
The tweeter / resolution / imaging / soundstage / midrange is entirely in a different league.
The only edge the RTiA3's had over the DCM was slightly better bass extension.
post #10 of 27 Old 10-15-2019, 01:13 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 2
Didn't even think to look at HSU for speakers! Thanks
M3MPH1S is offline
post #11 of 27 Old 10-15-2019, 01:16 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 2
TP260 towers $320
Haven't ever heard of DCM, will do some research, thanks!
M3MPH1S is offline
post #12 of 27 Old 10-15-2019, 01:17 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 2
Polk 707’s — $1100
SVS sub — $450
Appreciate the suggestions, but definitely don't want to compromise on the sub. I've heard the SVS sb1000 and it doesn't really do it for me.
M3MPH1S is offline
post #13 of 27 Old 10-15-2019, 01:25 PM
zieglj01's Avatar
Quoted: 3221 Post(s)
Liked: 3121
I own some DCM speakers and they are for real -- the TP series is really nice -- but the TFE series is even better ....but the TP series is no slouch -- the prices are crazy good. I would check them out and put them on a short list ... one thing to note about the TFE center, is that the tweeter is positioned above the center line which is beneficial.
Who AM I
zieglj01 is online now
post #14 of 27 Old 10-15-2019, 01:30 PM
Quoted: 593 Post(s)
Liked: 335
A few members here have discovered these New old stock jem being liquidated on ebay.
IMO Going with the DCM 's and Dual HSU VTF3 MK5's would give you the best HT experience without question. all for under $2000 .
*Dual subs is a game changer. Being able to fit Dual subs in your budget would take your system to the next level.
check this thread https://www.avsforum.com/forum/89-sp...er-choice.html
lots of feedback on DCM speakers
post #15 of 27 Old 10-15-2019, 01:34 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 2
Actually I'm in Atlanta, username is just a throwback. I'll keep it in mind the next time I'm in Nashville though!
M3MPH1S is offline
post #16 of 27 Old 10-15-2019, 01:38 PM
zieglj01's Avatar
Liked: 3121
I own some DCM speakers, and they are for real ... the TP speakers are really nice for the price .... but the TFE series are better ... the prices are crazy good for both series. You get a more dimensional and realistic soundstage and better definition and punch with the TFE series ... but with all that said, the TP series is no slouch or wimp.
I pretty much agree with macgallant about the DCM speakers ... and I have owned speakers like the Polk RTi speakers and HTD Level Three, Definitive Tech, etc:
Who AM I
post #17 of 27 Old 10-15-2019, 02:29 PM
BlueGhost's Avatar
Quoted: 39 Post(s)
Liked: 27
For $420 you could run the DCM TFE series up front and DCM TP series for surrounds.
M3MPH1S likes this.
BlueGhost is offline
post #18 of 27 Old 10-15-2019, 03:38 PM
zieglj01's Avatar
Liked: 3121
Bingo!
Who AM I
post #19 of 27 Old 10-16-2019, 07:14 AM
Quoted: 593 Post(s)
Liked: 335
I like the TFE Towers/Bookshelf my only concern is with the TFE center channel front baffle. I don't know how much that would hurt off axis response (if it would at all) it's impossible to know without taking measurements.
post #20 of 27 Old 10-16-2019, 08:36 AM
zieglj01's Avatar
Liked: 3121
Emotiva is in Franklin, TN
Who AM I
post #21 of 27 Old 10-16-2019, 08:44 AM
zieglj01's Avatar
Liked: 3121
For me I would use 1 of the TP160S bookshelf speakers for the center channel with the TFE front channel speakers
Who AM I
post #22 of 27 Old 10-16-2019, 02:29 PM
gajCA's Avatar
Liked: 6368
Sorry, near Nashville, 22 miles South on 440.
gajCA is offline
post #23 of 27 Old 10-16-2019, 02:32 PM
gajCA's Avatar
Liked: 6368
I would recommend ordering the speakers you want from Crutchfield as you mentioned several brands they carry.
Order two pairs and send the loser home within 60 days for total cost to return of just $10/box; some come 2/box some come 1/box but Crutchfield takes the shipping charge out of the rewards points for the pair you keep so if that is what happens the return shipping is essentially free.
Nice thing about that is that your own ears can decide vs someone else's.
M3MPH1S likes this.
gajCA is offline
post #24 of 27 Old 10-16-2019, 02:36 PM
zieglj01's Avatar
Liked: 3121
You were close ---- they are about 3 hrs from me
Who AM I
post #25 of 27 Old 10-16-2019, 05:15 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 2
Oh nice, I didn't know about their return policy. Very good idea. I've been looking at people's suggestions and reformulating my original ones and here's some that I came up with:
All setups will use Jamo for surround and atmos, and dual HSU VTF-2, and then an Onkyo receiver (so my budget target is $2500 including receiver)
Jamo S 801
Jamo S 8 ATM
HSU VTF-2 (x2)
Onkyo TX-NR787
============ $1710 (140+140+1030+400)
Then for LCR my main contenders are:
DCM TFE60
DCM TFE60C
============ $2020
Wharfedale Diamond 11.C
============ $2510 (crutchfield)
Focal Chorus 706
Focal Chorus CC 700
============ $2560 (crutchfield)
Monitor Audio Bronze Center
Ascend CMT-340
Ascend CMT-340 Center
============ $2510
HTD Level 3
HTD Level 3 Center
============ $2290
So I've got 3 options that let me go the Crutchfield route, and I'm hoping I'll get better performance out of the dual HSU VTF-2 rather than a single VTF-3 since the room is fairly large. Obviously the DCM is an ebay deal type thing so not a direct comparison, and I'm all for not spending money if I don't have to, but I'm pretty comfortable skirting the $2500 total budget to get the best sound possible. Like you said, I may just have to do some experimenting and take advantage of the cheap return costs.
gajCA likes this.
M3MPH1S is offline
post #26 of 27 Old 10-16-2019, 05:28 PM
Quoted: 593 Post(s)
Liked: 335
Jamo S 801
Jamo S 8 ATM
HSU VTF-2 (x2)
Onkyo TX-NR787
DCM TFE60
DCM TFE60C
============ $2020
Focal Chorus 706
Focal Chorus CC 700
Ascend CMT-340
============ $2510
HTD Level 3
HTD Level 3 Center
============ $2290
If you want with DCM you could fit dual HSU VTF3 MK5 in your budget which would make a substantial difference
sigpig likes this.
post #27 of 27 Old 10-17-2019, 09:09 AM
gajCA's Avatar
Liked: 6368
Jamo S 801
Jamo S 8 ATM
HSU VTF-2 (x2)
Onkyo TX-NR787
DCM TFE60
DCM TFE60C
============ $2020
Focal Chorus 706
Focal Chorus CC 700
Ascend CMT-340
============ $2510
HTD Level 3
HTD Level 3 Center
============ $2290
I'd start with the Crutchfield and HTD brands first as they offer minimal financial risk, (or none in the case of HTD); just order the bookshelves, and not the centers to see which you prefer and to minimize return costs.
If one of those 4 doesn't "do it" for you then you can contemplate the other two brands with new knowledge of what you do or don't like.
I'd go for two smaller quality vs one larger one all day long.
Adding a second sub adds +6db or so to headroom so if comparing specs on the HSU site add 6db to see that dual VTF2s have the same volume potential as a single VTF3 and will provide a better spread of bass across multiple seating positions.
M3MPH1S likes this.
gajCA is offline
Reply Speakers
atmos , elac , Jamo , Svs , wharfedale
