Rear surround advice (Monoprice / RSL / Canton) - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By zieglj01
  • 1 Post By smcmillan2
post #1 of 17 Old 10-16-2019, 12:36 PM - Thread Starter
ckg1999's Avatar
Quoted: 20 Post(s)
My front's are Paradigm 100's, with a cc-590. Paradigm is expensive for rears.
Looking at the following for rears (mounted BEHIND seating position - may go for 7.1.2 in the coming year or so)
Monoprice Caliber 6.5"
RSL W26
Canton 463 6.5"
ckg1999 is offline
post #2 of 17 Old 10-16-2019, 06:01 PM
afrogt's Avatar
Quoted: 2223 Post(s)
Liked: 1467
So are you mounting these in wall or in ceiling?
If you potentially plan to go 7.1.2 may I suggest 5.1.4 instead? You'd get more enveloping sound with 4 Atmos speakers vs 2.
Afro GT
afrogt is offline
post #3 of 17 Old 10-16-2019, 06:17 PM
smcmillan2's Avatar
Quoted: 987 Post(s)
Liked: 836
RSL W26
Canton 463 6.5"
Assuming you're looking for in-walls, I've been using the Monoprice Calibers (the old 5.25" model) for over 10 years in our living room and have been very happy with them. Only thing I would like is a bit more extension, which the 6.5" or 8" would provide.
You might also look at the JBL SP6II https://www.jbl.com/loudspeakers/SP6...urrent#start=1 that are often on sale for ~$80/pair IIRC.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #4 of 17 Old 10-16-2019, 06:29 PM
Quoted: 534 Post(s)
Liked: 473
The JBL SP8II are on sale for just $99 a pair!
https://www.jbl.com/loudspeakers/SP8...urrent#start=1
cocrh is offline
post #5 of 17 Old 10-16-2019, 06:31 PM
zieglj01's Avatar
Quoted: 3294 Post(s)
Liked: 3190
DCM Time Piece in-wall speakers -- Price is for 4 speakers -- on special clearance pricing -- if you only use 2, then save the other 2 for the future
https://www.ebay.com/itm/6-5-In-Wall...IAAOSwTYZdi9lP
If you only want a pair
https://www.ebay.com/itm/6-5-In-Wall...0AAOSw7OZdi9h5
Who AM I
zieglj01 is offline
post #6 of 17 Old 10-16-2019, 06:46 PM
smcmillan2's Avatar
Quoted: 987 Post(s)
Liked: 836
I'm sure you've been asked this more than a few times, as I have seen you recommend these at least a couple of times now. Are you aware of any comparisons of the DCMs to the Monoprice Calibers? Or other in-wall speakers in similar dimensions?
I've recently been looking to replace my surround/rear surround Calibers for something with a bit more extension to get a "fuller" surround experience (yes, I have subwoofers, listed in my sig) and wonder how they stack up.
Have DIYSG Volt-6 surrounds in another room and love them, but really can't place the same in the living room.
(Apologies for hijacking the thread)
post #7 of 17 Old 10-16-2019, 06:49 PM
smcmillan2's Avatar
Quoted: 987 Post(s)
Liked: 836
Any experience with them? They look good on paper, I just haven't seen owner reviews comparing them with anything else.
post #8 of 17 Old 10-16-2019, 07:46 PM
zieglj01's Avatar
Liked: 3190
Just their bookshelf speakers -- they are voiced to timbre/tone mach their Time-Piece speakers which I like -- the kevlar cone has good extension and takes some power ... they also have a Front Mounted Tweeter Level Control and Front Mounted Boundary Equalization Control ... and crossover looks to be 12 db octave for woofer and tweeter. ... the last street price was $179 each
smcmillan2 likes this.
Who AM I
zieglj01 is offline
post #9 of 17 Old 10-16-2019, 08:01 PM
smcmillan2's Avatar
Quoted: 987 Post(s)
Liked: 836
Appreciate the info!
zieglj01 likes this.
post #10 of 17 Old 10-16-2019, 08:49 PM
Quoted: 534 Post(s)
Liked: 473
For the price I'd get the DCM's. The JBL is about at the Arena level so not high end like the Studio series.
cocrh is offline
post #11 of 17 Old 10-17-2019, 07:34 AM - Thread Starter
ckg1999's Avatar
Quoted: 20 Post(s)
These will be in-wall. Instead of 4 ceiling atmos, could a front height speaker work plus 2 in-ceiling atmos?
ckg1999 is offline
post #12 of 17 Old 10-17-2019, 07:37 AM - Thread Starter
ckg1999's Avatar
Quoted: 20 Post(s)
Haven't used DCM or heard of them before. Are they fairly neutral in sound?
ckg1999 is offline
post #13 of 17 Old 10-17-2019, 09:08 AM
zieglj01's Avatar
Liked: 3190
Yes
Who AM I
zieglj01 is offline
post #14 of 17 Old 10-17-2019, 10:29 AM
afrogt's Avatar
Liked: 1467
Yes, you can use 2 front height and 2 ceiling mounted speakers as 4 Atmos speakers.
I take it then that your rear in wall speakers are really surrounds in a 5.1 setup?
What receiver do you have by the way?
Afro GT
afrogt is offline
post #15 of 17 Old 10-17-2019, 11:48 AM - Thread Starter
ckg1999's Avatar
Quoted: 20 Post(s)
Yes - they are surrounds, while I also have options for atmos (cable pulled by builder).
Using Denon 4311
ckg1999 is offline
post #16 of 17 Old 10-17-2019, 01:34 PM
afrogt's Avatar
Liked: 1467
I think the 4311 can handle Dolby Atmos now. Not sure about DTS:X.
what the 4311 cannot do is pass a 4K HDCP 2.2 signal. The 4311 only has HDMI 1.4a and you need HDMI 2.0 or higher.
Afro GT
afrogt is offline
post #17 of 17 Old 10-17-2019, 02:26 PM - Thread Starter
ckg1999's Avatar
Quoted: 20 Post(s)
I plan to upgrade to a 4k receiver when I upgrade projector from the 1080p epson. Looks like the 4311 doesn't have atmos :-(
ckg1999 is offline
Reply Speakers
