Choosing in-walls - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Gamecock24
post #1 of 11 Old 10-17-2019, 02:02 PM - Thread Starter
DANMAN421's Avatar
Quoted: 17 Post(s)
Choosing in-walls
I've been racking my brain about this and hoping for some suggestions. I am changing my system around and going in-wall. I was running DefTech Mythos with a Klipsch 10" ported sub and a Marantz SR7010. It's not a bad setup but im upgrading everything but the receiver for now. Going Sony 950G 75" and 2x RSL Speedwoofers. The system will only be 5.2 and just really a mixed-use TV room with music sometimes too - say 25%?
I had my heart set on DefTech UIW RLS II as L/R and RLS III as my center due to space. Then UIW RSS III as 2 surrounds. Well, its a lot of money to just go on a whim and its hard to listen to speakers given im not in a large city.
I'm going to get flack for this I know but I did use the Crutchfield Virtual Listening deal and kept coming back to the Focal 100. They seemed to have the most full sound for me. Their 300 IW6 LCR is a bit out of my range for speakers and no Virtual Listening option.
I like the idea of a longer skinnier speaker. What else should I consider? I would prefer to match brands and keep the front 3 as similar as possible. I really dont want to branch out to some of the more random brands (like Axiom). Too much risk for me. KEF is something I think I will like but their 4100 is too small (the room is about 7000 sq ft - large vaulted) and the larger speakers are too much.
DANMAN421 is offline
post #2 of 11 Old 10-17-2019, 02:11 PM
Gamecock24's Avatar
Quoted: 380 Post(s)
Liked: 160
Monitor Audio makes some in wall speakers that are of the long skinny variety. I’m about to install their 8” IDC in wall speakers which are a 3 way speaker. MA says they are timber matched to the MA towers and center channel I currently have. That will complete a 7.1.4 system for me.
Check them out maybe you’ll see something you like.
DANMAN421 likes this.
Gamecock24 is offline
post #3 of 11 Old 10-17-2019, 02:33 PM
Zorba922's Avatar
Quoted: 7474 Post(s)
Liked: 5702
The thing about in-walls is that you can't really know how they'll sound until you have them installed, and once you have them installed it's a huge PITA to switch them out if you aren't 100% happy with their sound. That's one of several reasons I usually tell people to do in-walls only for surrounds, and for fronts only as an absolute last resort.
In your case I'd suggest trying an inexpensive on-wall option that has free return shipping in case you don't like them:
https://www.htd.com/VERSA-HTS1
You are overspending on the speakers and seriously under-spending on the more critical subwoofer(s) in my opinion...especially in your previous setup. RSL Speedwoofers are nice but they really don't go low enough for 75% HT use...instead of 2 of them I'd get a single Hsu VTF-3 or VTF-15H.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #4 of 11 Old 10-17-2019, 04:14 PM
Quoted: 575 Post(s)
Liked: 299
check out the axiom audio M22 or M5HP in walls. they come with an integrated back box. You could hang them on the wall to see how you like them within the return period.
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #5 of 11 Old 10-17-2019, 08:18 PM - Thread Starter
DANMAN421's Avatar
Quoted: 17 Post(s)
Thanks for the suggestions. I should clarify, my 75% usage is news, sports, TV shows. Not HT. We have 2 small kids and don't really have time for movies right now. I may upgrade the subs later but I do like the RSLs for now.
Sent from my Pixel 3 using Tapatalk
post #6 of 11 Old 10-17-2019, 08:19 PM - Thread Starter
DANMAN421's Avatar
Quoted: 17 Post(s)
I've heard of them just a little apprehensive to branch out of the norm. I'll try and keep an open mind.
post #7 of 11 Old 10-17-2019, 08:37 PM
Zorba922's Avatar
Liked: 5702
Ok, I guess I understand why you'd want in-walls then. This is one in-wall I'd consider:
https://www.nhthifi.com/products/107...-nht-architect
If you want the ultimate in childproofing, a downfiring sub like this might also be worth looking at:
http://www.outlawaudio.com/products/ultra.html
Zorba922 is offline
post #8 of 11 Old 10-18-2019, 03:51 AM - Thread Starter
DANMAN421's Avatar
Quoted: 17 Post(s)
Let's keep them coming! Any Klipsch I should be looking at?
post #9 of 11 Old 10-18-2019, 08:17 AM - Thread Starter
DANMAN421's Avatar
Quoted: 17 Post(s)
Any thoughts on KEF Ci4100QL as LCR?
post #10 of 11 Old 10-18-2019, 09:37 AM
Zorba922's Avatar
Liked: 5702
If you're interested in a horn tweeter, I'd look at Hsu instead:
http://www.hsuresearch.com/products/hiw-1.html
Same drivers as this well-regarded speaker:
http://www.hsuresearch.com/products/hb-1.html
Zorba922 is offline
post #11 of 11 Old 10-18-2019, 10:07 AM
zieglj01's Avatar
Quoted: 3294 Post(s)
Liked: 3190
zieglj01 is offline
Reply Speakers
