Help with speaker choice! - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Zorba922
post #1 of 13 Old Today, 05:47 PM - Thread Starter
Quoted: 34 Post(s)
Liked: 33
Hi,
I wish to upgrade my speaker set, in particular my front stage. Right now I have a setup that goes like this:
Equipment
Front right and left: Polk R150s (on speaker stands)
Center and surrounds: Polk RM8
Presence (front height): Polk OWM3 (top of the wall)
Sub: Yamaha YST-SW012
AVR: Yamaha RX-V675 (7.1)
TV: LG OLED B7 55 in
Room
Room is 13 x 14 feet, see attached diagram for layout. If you are confused by the two positions for the TV and fronts, it's normal: given the fact that this is our main living room, the TV stand normally sits in the room corner, but I've installed wheels on it so that I simply roll it to face the couch when I watch a movie. Very handy.
Walls are 9 ft high.
Long-term goal: I eventually want to have a 5.1.4 Atmos setup, but that will wait until I get a new receiver and figure a way to install front ceiling speakers (upfiring is not a viable option due to popcorn ceilings)
Short-term goal: I want to start upgrade my front stage (the Polk R150s and the center RM8)
Budget for left and right front speakers: $300-$500 for the pair, plus $300 max for center (could wait a little for that one).
I am no audiophile and have limited experience with speakers. I have done quite a bit of research but given the ridiculous number of options in that price range, I am lost. Let me list a few comments that may be useful:
- Usage is 95% movies
- I do not care much about bass (I have a sub for that anyway), but I tend to really like detail in speakers, particularly when it comes to watching movies
- I probably will eventually upgrade the surround speakers, but that can wait
- I want bookshelf speakers that are not to heavy or large, as I need to move them every time I change the position of the TV and front speakers (see diagram)
- I am very limited in what I can do for the center speaker: given the TV stand I have and I need (corner shaped), I do not see how I can fit a large speaker in the cabinet in addition to the AVR, Blu-Ray player and PS4. Right now the center speaker (very small) sits on top of the Blu-Ray. Also, unless I find a way to lift the TV, I cannot fit it on top of the stand.
Looking around these forums and others, I came up with a few options. The only one I have actually tested is the first option (hard to find places to test speakers around here), but that was in a noisy environment, so honestly we can probably discount it.
KEF Q150: can get them right now for 400 CAD (about 300 USD), but I'm really worried about my center option: the Q250C is really expensive and big. Other option of finding a single Q150 would also imply having a large center.
ELAC DEBUT B6.2
Jamo S803
Ascend CMB-170 SE
Q Acoustics 3020i
MTX TP160 (on clearance these days)
Other options that I should be seriously considering?
Basically if KEF had a more compact (less than 5" high) and more affordable center, I would probably just go for the Q150s. But because of that limitation, I'm considering other options, since I don't want to get a center from another brand due to timbre matching.
Another option would be not to have a center speaker at least for now, and instead to run a phantom center. Are the Q150s decent off axis? Is this an option you would recommend?
Any help would be very highly appreciated, the more I search the more I feel lost!
Name:	diagram - living room.png
Turpentine22 is online now
post #2 of 13 Old Today, 07:09 PM
Quoted: 560 Post(s)
Liked: 293
check out the RSL CG3 or CG23
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is online now
post #3 of 13 Old Today, 07:14 PM
zieglj01's Avatar
Quoted: 3120 Post(s)
Liked: 3043
You are restricted to 5 inches high on the center?
Who AM I
zieglj01 is online now
post #4 of 13 Old Today, 07:27 PM
Zorba922's Avatar
Quoted: 7152 Post(s)
Liked: 5461
Since you're in Canada, this is the best bang for your buck by far...just buy 3 of them for $390 CAD and you're done. In the US those same speakers would cost $525 (700CAD). They are quite good by all accounts, especially for HT...very detailed and lively. Being a sealed (no ports) design, they are quite compact and can sit inside a cabinet easily.
https://www.amazon.ca/NHT-Audio-Supe...dp/B00LJX4HCY/
In fact, at those prices you could even upgrade your rears with their little brother for $88 CAD apiece:
https://www.amazon.ca/NHT-Audio-Supe...dp/B00CKNOYWK/
What sub do you have? You wrote "Yamaha HS8" but google tells me that's a studio monitor.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #5 of 13 Old Today, 07:43 PM - Thread Starter
Quoted: 34 Post(s)
Liked: 33
Oh, I saw the NHT SuperOnes show up in threads but never actually looked into them (so many options...), I will now!
Yikes, sorry, it's actually a Yamaha YST-SW012.
post #6 of 13 Old Today, 07:44 PM - Thread Starter
Quoted: 34 Post(s)
Liked: 33
Maybe more like 6 in if I squeeze it in. Unless I put it on a shelf resting on top of the TV. Not a very popular option in the household though...
post #7 of 13 Old Today, 07:45 PM - Thread Starter
Quoted: 34 Post(s)
Liked: 33
Thanks, never came across that model, will look into them.
post #8 of 13 Old Today, 07:56 PM
Zorba922's Avatar
Liked: 5461
Since you'd be saving a boatload of money going with NHT, this would be well worth it:
https://www.electronicsforless.ca/sv...ofer-3884.html
Only $15 more than US retail pricing...most American speakers/subs cost an arm and a leg in Canada. I would hold off on upgrading the rear speakers if that would give you more budget to get the SVS sub. For HT it *will* make a huge difference over that Yamaha, unless you never watch big budget action/thriller flicks.
Zorba922 is offline
post #9 of 13 Old Today, 08:07 PM - Thread Starter
Quoted: 34 Post(s)
Liked: 33
I see that the NHT Super Centre 2.1 is 166 CAD. Would it be a better/worse option than a third SuperOne? The reason this is an interesting option for me is because the center is only 5.5 in high, vs 7.25 in for a SuperOne on its side (would not fit in my cabinet).
Thanks a lot for your help.
post #10 of 13 Old Today, 08:13 PM
zieglj01's Avatar
Liked: 3043
A stand to put on your stand to raise the TV
https://www.amazon.com/PERLESMITH-Un...NsaWNrPXRydWU=
Who AM I
post #11 of 13 Old Today, 08:31 PM
Zorba922's Avatar
Liked: 5461
I have not heard great things about the Super Center, so my first recommendation is just order two SuperOnes and see if you're ok WITHOUT a physical center speaker. This is called a "phantom center" and some people actually prefer it.
If you are really unsatisfied with the "phantom center," then I would get the SuperCenter if there is absolutely no way around it---but first I would do my damndest to avoid it by raising the TV, or using a single speaker stand (https://www.amazon.ca/Monolith-Inch-.../dp/B076HX81WZ) or improvising with a step stool, milk crate, plant stand, media cart...pretty much anything to let you use a 3rd SuperOne standing up (ideally with the tweeter lined up with the L/R speakers' tweeter).
Turpentine22 likes this.
Zorba922 is offline
post #12 of 13 Old Today, 08:56 PM - Thread Starter
Quoted: 34 Post(s)
Liked: 33
Leaving aside the fact that the Q150 and ELAC pairs would be more expensive (400 and 340 CAD vs 260 for the NHT), should I expect a significant difference in quality or sounds profile relative the NHT? I'm not thinking of upgrading again for a while, so hoping to have a decent upgrade over my Polk R150!
post #13 of 13 Old Today, 09:06 PM
mtrot's Avatar
Quoted: 572 Post(s)
Liked: 240
You might also want to consider the Dali Oberon 1 for your front L/R if you can stretch to $550. I have heard Oberon at audio shows and they are the real deal. Now, the Oberon Vokal center is a bit pricey, but also very good. If you want to run with a phantom center, you could go with the larger Oberon 3 and its 7 inch woofer.
https://www.dali-speakers.com/loudsp...eron/oberon-1/
https://www.dali-speakers.com/loudsp...eron/oberon-3/
FAMILY ROOM--Legacy Signature II tower speakers(Front L/R), PSB Image 5T tower speakers(Surrounds), Denon AVR-X5200W, Krell FPB 400cx, AR ES-1 turntable w/ Audioquest 404-B cartridge, Oppo UDP-203 UHD Blu-ray Player, RCA HD-DVD player, Samsung HL67A 750A TV
MASTER BEDROOM--Dynaudio Audience 82 tower speakers, Outlaw LFM-1 sub, Yamaha RX-V1800 receiver, Sherbourn 5/1500A 5-channel amp, Oppo BDP-83 Universal Disc Player, Panasonic 60-ST60 plasma TV.
mtrot is online now
Reply Speakers
