Bipolar Surround Placement Advice - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By manhattan24
post #1 of 5 Old 10-21-2019, 07:35 AM - Thread Starter
Quoted: 38 Post(s)
Liked: 1
Hi,
I have just bought some new bipolar surrounds (Klipsch RP-402S) for my set-up, however as the room shape is not ideal and a bit cramped, I would appreciate some advice on the best placement. I've attached an image and diagram to give an idea of the current layout.
If stands are the best option, could someone please recommend something suitable? I had a quick look on Amazon and found Nordell' Premium Floor Speaker Stands, perhaps they would do the job?
Also, would it be beter to put the right speaker at the end of the row of seats or next to the sofa as most viewing is done mainly from the left chair and sofa.
Any advice would be appreciated.
ID:	2630106   Click image for larger version
manhattan24 is offline
post #2 of 5 Old 10-21-2019, 02:30 PM
Alan P's Avatar
Quoted: 6588 Post(s)
Liked: 5992
I would mount them high on the rear wall (~6" from ceiling), basically in line with the front L/R speakers...maybe a bit wider. This will provide the most diffuse soundfield for all seating IMO.
Alan P is offline
post #3 of 5 Old 10-21-2019, 07:12 PM - Thread Starter
Quoted: 38 Post(s)
Liked: 1
Thanks for the reply.
So would that be a better option than bringing the seating away from the wall and putting the speakers at either end of the seats aligned with the ears and 2 ft above on stands? The main listening location is the sofa and left chair facing the screen.
post #4 of 5 Old 10-22-2019, 09:36 AM
Alan P's Avatar
Liked: 5992
In my opinion, it would be the better option.
If you were to place the speakers to the sides, the seating closest to the speakers (left chair and right seat of couch) would be blasted, the only good seat would be the left side/center of the couch. With them mounted up high and pointing forward (actually, angled since they are bipole), all seats would get a better, more diffuse surround experience. The far left and right chairs are going to be compromised no matter what since they are so far off-axis...the far left chair in particular since it is in a corner, the bass is going to be quite boomy in that location.
With the surrounds mounted higher on the wall and relatively close together, the surround "bubble" will be able to cover a wider area, such as your seating.
Alan P is offline
post #5 of 5 Old 10-22-2019, 02:00 PM - Thread Starter
Quoted: 38 Post(s)
Liked: 1
Great, will do what you suggested.
Thanks alot.
Alan P likes this.
Reply Speakers
