New To the Forums - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #31 of 45 Old 10-22-2019, 11:15 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 5
Originally Posted by Zorba922 View Post
Sony region free BR is $150 on Amazon.
https://www.amazon.com/Sony-Region-P.../dp/B00M0U7AGK
Be sure to get all your cables, wire, b-plugs, etc. from Monoprice or Mediabridge via Amazon, don't get snookered by Monster Cable crap or the like.
Going with Mediabridge on my subwoofer cable and speaker wire and then Monoprice on the banana plugs.
Comes up to $2779 all together with the different blu ray player. Thank you!
danielgatelyjr is offline
post #32 of 45 Old 10-22-2019, 11:21 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 5
Would you recommend going with the Airmotiv A1 Atmos speakers? I have about 100 bucks left over.
post #33 of 45 Old 10-22-2019, 11:28 PM
Zorba922's Avatar
Quoted: 7302 Post(s)
Liked: 5587
If the visual uniformity with the T-Zeros is important to you...otherwise, am not sure you'd be able to HEAR a big difference over the Sonys. Extra money would be best spent on the next level up sub...btw, how big is your space? (Include all adjacent open areas not just the listening area.)
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #34 of 45 Old 10-22-2019, 11:34 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 5
I would like to have the visual uniformity and it seems like the sub you suggested will work out just fine.
The living room/theater room is 18 feet from tv wall to back wall and 13.5 feet side to side. There is a partitioned wall that separates the living room from the dining room (which would be to the listener's left) that is about 3.5 feet away from the tv wall and 7 feet long by 6.5 feet tall and the living room is also carpeted. The ceiling is approximately 8 feet tall.
post #35 of 45 Old 10-22-2019, 11:41 PM
Zorba922's Avatar
Liked: 5587
The living room/theater room is 18 feet from tv wall to back wall and 13.5 feet side to side. There is a partitioned wall that separates the living room from the dining room and the living room is carpeted.
If the "partitioned wall" completely seals off the 18 x 13.5' room from the dining room then yes I'd agree the PB1000 is enough. If it's one of those partition walls that leaves any open gaps between the two rooms, then the sub will interact with the combined rooms, i.e. you have to treat both rooms as one and therefore would likely need a stronger sub if you want to properly pressurize the space.
Zorba922 is offline
post #36 of 45 Old 10-22-2019, 11:45 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 5
Here are some pics to give you a better idea.
ID:	2630928   Click image for larger version
ID:	2630930   Click image for larger version
post #37 of 45 Old 10-22-2019, 11:50 PM
Zorba922's Avatar
Liked: 5587
Oh jeez, that is literally ONE big continuous room then. I would move up to the VTF-2 in that case, $577 shipped...hold off on the Atmos speakers if you have to.
http://www.hsuresearch.com/products/vtf-2mk5.html
Zorba922 is offline
post #38 of 45 Old 10-22-2019, 11:58 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 5
Alright. I'll go ahead and go with that then. I'll drop the A1's and get the Sony Atmos speakers instead. Still comes under $2900.
Zorba922 likes this.
post #39 of 45 Old 10-23-2019, 12:04 AM - Thread Starter
Quoted: 21 Post(s)
Liked: 5
Alright! Here we go again haha.
Receiver - Pioneer VSX-LX303
Fronts - Emotiva Airmotiv T-Zero
Center - Emotiva Airmotiv C1
Surrounds - Dayton Audio B652
Heights - Sony SCCSE
Subwoofer - HSU Research VTF-2 MK5
Zorba922 and Lp85253 like this.
post #40 of 45 Old 10-23-2019, 12:15 AM
Zorba922's Avatar
Liked: 5587
Much better! Post some pics and how you like it when everything's set up...enjoy!
danielgatelyjr likes this.
Zorba922 is offline
post #41 of 45 Old 10-23-2019, 12:47 AM
RayGuy's Avatar
Quoted: 2921 Post(s)
Liked: 2697
Be sure to consult the Dolby site for speaker placement recommendations for your chosen set-up. Then, have fun!
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #42 of 45 Old 10-23-2019, 08:46 AM - Thread Starter
Quoted: 21 Post(s)
Liked: 5
I will do that. Thanks for all of your help.
post #43 of 45 Old 10-23-2019, 09:18 AM
zieglj01's Avatar
Quoted: 3218 Post(s)
Liked: 3118
Yes -- that would work for you
Who AM I
zieglj01 is online now
post #44 of 45 Old 10-23-2019, 09:57 AM
Quoted: 2131 Post(s)
Liked: 1801
I am indeed a gamer as well.
Alright, here's what I got:
Airmotiv T-Zero fronts
Airmotiv C1 Center
Dayton Audio B652 surrounds x4
Sony SSCSE Atmos speakers
SVS PB-1000 sub
I'm getting all new speaker wire to match my walls as well as the Sony region-free blu ray player and the PS4 Pro. Also getting all of the banana plugs and subwoofer cable as well as a handful of 4k blu rays.
The grand total comes up to $2932 approximately.
that's a good system...
YAMAHA TSR 5790.. front l/r emotiva b1's and /or kef q100's ..BIC v1220.....Emotiva basx10.... ascend cbm 170 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. wharfedale 10.1s... ascend cbm 170 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is online now
post #45 of 45 Old 10-23-2019, 09:58 AM
Liked: 1801
that's a better system...
Reply Speakers
