bookshelf speakers - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 1 Post By zieglj01
  • 1 Post By Zorba922
  • 2 Post By pase22
  • 1 Post By pase22
post #1 of 22 Old 10-23-2019, 09:03 AM - Thread Starter
Quoted: 17 Post(s)
Liked: 0
bookshelf speakers
Hi,
Would like your expert advise on purchasing bookshelf speakers for surround system. Any suggestion or advise would be highly appreciated. My current setup includes Yamaha V-2600 receiver. P.A Rti A9s, JBL Northbridge N-36II, Rhythmic FX 15HP. My budget is $500. Thanks in advance.
[email protected] is offline
post #2 of 22 Old 10-23-2019, 09:14 AM
pase22's Avatar
Quoted: 3415 Post(s)
Liked: 2883
Originally Posted by [email protected] View Post
Hi,
Are you just looking for surround speakers? Are you setting up a different system? Upgrading from current?
Your setup looks very respectable!
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #3 of 22 Old 10-23-2019, 09:23 AM
Ryan Statz's Avatar
Quoted: 550 Post(s)
Liked: 319
Hi,
If you're keen on the Polk RTiA9s, then perhaps the A3s or A1s?
Home Theatre: Onkyo TX-NR747 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R | Elac S10EQ Subwoofer
Ryan Statz is offline
post #4 of 22 Old 10-23-2019, 10:32 AM
Quoted: 494 Post(s)
Liked: 438
The Polk LSiM 703 bookshelf speakers are on sale for a really good price at Adorama. $449 a pair
Black
https://www.adorama.com/pklsim703b2....ce=rflaid62905
Cherry
https://www.adorama.com/pklsm703mvc2...ce=rflaid62905
cocrh is offline
post #5 of 22 Old 10-23-2019, 11:10 AM
pase22's Avatar
Liked: 2883
Hi,
A better center like this matching CSi A6 would provide a more cohesive soundstage. For surround, a pair of inexpensive RTI-A1's would do the trick. Getting Both would be within budget.
https://www.crutchfield.com/p_107CSI...-A6-Black.html
https://www.crutchfield.com/p_107RTI...-A1-Black.html
Both available in cherry as well.
pase22 is offline
post #6 of 22 Old 10-23-2019, 11:25 AM
zieglj01's Avatar
Quoted: 3214 Post(s)
Liked: 3114
Based on the pass, it looks like you want surround speakers -- this will work and save you some money -- and will have some really good sound, and good off-axis response
DCM TFE60 -- be careful, because you could really end up liking them ... with the exception of the bass in the Polk towers, I like them better than both the Polk and JBL
https://www.ebay.com/itm/2-DCM-by-MT...B/193087808575
Lp85253 likes this.
Who AM I
zieglj01 is offline
post #7 of 22 Old 10-23-2019, 02:39 PM - Thread Starter
Quoted: 17 Post(s)
Liked: 0
Thank you all, 1 more concern that I have is the Rti A9's I feel i'm not getting a 100% from them, am I doing something different.
post #8 of 22 Old 10-23-2019, 02:44 PM
Ryan Statz's Avatar
Quoted: 550 Post(s)
Liked: 319
How are your speakers set up?
post #9 of 22 Old 10-23-2019, 02:45 PM - Thread Starter
Quoted: 17 Post(s)
Liked: 0
my setup is the same just need to add the surround speakers to my current setup. thanks
post #10 of 22 Old 10-23-2019, 02:47 PM
Ryan Statz's Avatar
Quoted: 550 Post(s)
Liked: 319
My apologies, I mean what settings do you have for the A9s if you don't think you're getting 100% out of them?
post #11 of 22 Old 10-23-2019, 02:50 PM - Thread Starter
Quoted: 17 Post(s)
Liked: 0
the A9's are setup front left and right and the JBL's are setup on the rear right and left.
post #12 of 22 Old 10-23-2019, 02:52 PM
Ryan Statz's Avatar
Quoted: 550 Post(s)
Liked: 319
Are they set to large/full band? small? crossover settings?
What settings do you have for your subwoofer as well?
post #13 of 22 Old 10-23-2019, 02:52 PM - Thread Starter
Quoted: 17 Post(s)
Liked: 0
I went to bestbuy with the concern I have with the A9's, the representative told me that I need to change my current receiver (Yamaha v-2600) as its old.
post #14 of 22 Old 10-23-2019, 02:53 PM - Thread Starter
Quoted: 17 Post(s)
Liked: 0
not too sure about the settings for the receiver or subwoofer as i'm not that techy. if anyone of u could provide me the recommended setup and I will follow that. thanks
post #15 of 22 Old 10-23-2019, 02:55 PM
Ryan Statz's Avatar
Quoted: 550 Post(s)
Liked: 319
That receiver should be fine as long as you're not listening at ear-bleeding volume levels.
post #16 of 22 Old 10-23-2019, 03:00 PM
Zorba922's Avatar
Quoted: 7286 Post(s)
Liked: 5582
Typical Best Buy sleazebag who's just chasing a sales commission!
There's nothing wrong with the 2600, that's one of Yamaha's upper tier receivers. IF it really is not just a matter of changing your settings (you should make sure the Front L/R Polks are set on "small" since you already have a very good sub doing the low end, this will greatly reduce the amount of power they need from your receiver), then all you need to do is add an inexpensive external amp to your 2600 to power them. I am pretty sure the 2600 has pre-outs.
Something like this:
https://www.amazon.com/Crown-XLi800-...dp/B00AR0A3V4/
Lp85253 likes this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #17 of 22 Old 10-23-2019, 03:21 PM
Ryan Statz's Avatar
Quoted: 550 Post(s)
Liked: 319
Not sure of the settings menu in that particular AVR, but settings you can start with (and it may take some rummaging around the settings menu on your part to find):
First, set your speakers to "Small"
Once you've done that, the set-it-and-forget-it crossover settings for your A9s could be 80Hz, but you can probably go as low as 60Hz. Your centre speaker (if you have one?) is typically set 80-100Hz, surrounds are typically set 100-120Hz.
The subwoofer LFE/LPF setting in the AVR is typically set to 120Hz. On the subwoofer itself, turn the Frequency knob all the way to the max. Phase is fine to keep at 0 or 180 degrees if you have the one sub. There's probably a bunch of other things on the back of the Rythmik sub I am not familiar with, so if you had a list of those options, that'd be helpful.
If that AVR has some kind of room calibration, run that as well.
post #18 of 22 Old 10-23-2019, 03:34 PM
zieglj01's Avatar
Liked: 3114
That receiver has some good power
Ryan Statz likes this.
Who AM I
zieglj01 is offline
post #19 of 22 Old 10-24-2019, 11:38 AM - Thread Starter
Quoted: 17 Post(s)
Liked: 0
thanks everybody for ur input, what do u mean by setting the speakers to small and how do I do it. secondly I am getting to buy B&W DM 601 S2. BookShelf Speakers used but in a very good condition, are these good to use for surround, if yes how much should I be paying for it considering its used. thanks in advance
post #20 of 22 Old 10-24-2019, 11:47 AM
Ryan Statz's Avatar
Quoted: 550 Post(s)
Liked: 319
Without knowing how to navigate the menu, I can't tell you. It's somewhere in the settings menu is about all I can say, which I know isn't very useful.
That AVR also has YPAO, so run the calibration software. It should have come with a mic, which you place at ear level in the main listening position.
post #21 of 22 Old 10-24-2019, 12:01 PM
pase22's Avatar
Liked: 2883
It could be an easy to correct placement/setup issue. A few pictures of the room and how the speakers are configured would be extremely helpful for us. We could make suggestions for improvement if necessary once we know what you've got going on.
Lp85253 and Ryan Statz like this.
pase22 is offline
post #22 of 22 Old 10-24-2019, 12:56 PM
pase22's Avatar
Liked: 2883
Someone that owns a Yamaha will chime in to give you more specific instructions, but you'll typically find that in the speakers menu under configuration.
Surround speakers mostly provide ambient sounds and background music. That's the perfect place to save money by getting used speakers for $20-30 from the pawn shop or even Craigslist/ebay.
pase22 is offline
Reply Speakers
