5.1 Small Speaker Replacement.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-22-2019, 04:36 PM - Thread Starter
jwharan's Avatar
New 5.1 Surround for an existing theatre room
Hi all,
I just moved into a new house with theatre room. Current Receiver is a Denon 7.2 AVR-X4100W, and a Bose Acoustimass 15 which sucks! Its actually dying, if it hasnt already. I have attached a diagram of the theatre room. I need to replace the bose. I dont really have a set budget..however Im not looking for something exotic. I havent bought anything...ever.. so I dont know if I am looking at 500 or 5000? I would like to keep to a reasonable size, as they will be wall mounted, but they can be slightly bigger than the bose cubes. Room is 20x17. What would you recommend? I also have a newer yamaha 5.1 receiver (RX-A670BL), so I am open to using either receiver. Just want something from a speaker standpoint thats gonna have the wow factor, with a fairly easy setup. The dotted line on the diagram is a bulkhead which the front channels are mounted too. Center channel is under TV.
ID:	2630786   Click image for larger version
ID:	2630828   Click image for larger version
jwharan is offline
post #2 of 10 Old 10-24-2019, 06:32 AM - Thread Starter
jwharan's Avatar
I need to replace my Bose Acoustimass System that came with the house, and I am looking for suggestions. Ideally need to keep small speakers, but you can judge from the pictures. Thanks in advance.
ID:	2631424   Click image for larger version
jwharan is offline
post #3 of 10 Old 10-24-2019, 08:45 AM
Liked: 6
You can look for DefTech Promonitor 800 or 600.
I have a pair of 800 and use them as surround and they are impressive. Great sound quality and output.
Denon X-2400H | DefTech PC2000 | PM1000(lr) 800(sr) | Polk RC60i(atmos)
SVS PB-1000 | Sony XBR-65X855D | nVidia ShieldTV
kelm is offline
post #4 of 10 Old 10-24-2019, 01:05 PM
gajCA's Avatar
Quoted: 9219 Post(s)
Liked: 6331
Originally Posted by jwharan View Post
Hi all,
Slightly bigger than a Bose double cube seems a bit small for that room but I would take a look at these Martin Logan speakers with easy returns at Best Buy.
I have the slightly larger LX16 which have the same tweeter and they are excellent.
4 corner speakers.
https://www.bestbuy.com/site/martinl...B&gclsrc=aw.ds
Center speaker.
One of these subwoofers.
PORTED SUBWOOFERS $600 AND BELOW, DELIVERED
NOTE:
*THE LARGER PORTED SUBS DELIVER AT LEAST 40% MORE SOUND PRESSURE LEVEL
THAN THE SAME BRAND'S SEALED VERSION WITH SAME SIZE WOOFER AND AMP
*IF LOOKING AT LARGER/MORE EXPENSIVE SUBWOOFERS ADD PSA TO THE LIST OF BRANDS
*IF YOU ARE NOT AN ACTION MOVIE FAN A SUBWOOFER WITH 22-30HZ EXTENSION WOULD BE FINE
*FOR MUSIC A 30HZ SUB IS A FINE CHOICE
*BEFORE BUYING MAKE A CARDBOARD CUTOUT OF THE SIZE OF THE SUB TO MAKE SURE IT IS NOT TOO LARGE FOR YOU
Specs are from the manufacturer unless noted otherwise.
Warranty
for AMP
1 year 150watts =24w7h12d= 25 lbs 8" [23hz] $250 EARTHQUAKE LOW PROFILE CP8 (Amazon price)
3 years 120watts =13w15h16d= 29 lbs 10" [29hz] $250 MARTIN LOGAN DYNAMO 500, limited time offer
2 years 350watts =15w16h17d= 40 lbs 10" [30hz] $399 RSL SPEEDWOOFER 10S, (extension from Sound & Vision review)
2 years 250watts =15w19h17d= 42 lbs 10" [25hz] $455 HSU VTF 1 MK3 (extension from Audioholics review)
5 years 300watts =15w19h20d= 46 lbs 10" [18hz] $499 SVS PB1000, (extension from Sound & Vision Review)
5 years 500watts =15w19h20d= 72 lbs 10" [20hz] $500 MONOPRICE MONOLITH THX 10"
3 years 300watts =16w22h21d= 69 lbs* 12" [19hz] $569 RHYTHMIK LV12F
2 years 350watts =15w21h22d= 62 lbs 12" [18hz] $607 HSU VTF2 MK5, (extension from Audioholics review)
* = shipping weight
Alternately this 5.1 system. Free returns if not happy.
https://rslspeakers.com/products/cg3...heater-system/
Geoff A. J., California
gajCA is online now
post #5 of 10 Old 10-24-2019, 04:15 PM
gajCA's Avatar
Liked: 6331
I already responded in your other thread but this came up if you are willing to settle for something far better than Bose but similar in footprint.
While not as capable as the Martin Logan setup or RSL setup I posted in the other thread it will be better than the Bose.
https://www.crutchfield.com/S-G52OET...hoCOmYQAvD_BwE
This splits the difference between the Focal and what I recommended earlier.
gajCA is online now
post #6 of 10 Old 10-24-2019, 06:24 PM
BlueGhost's Avatar
Quoted: 39 Post(s)
Liked: 27
Small speakers are a compromise, especially for what looks like a great theater space. If you play with the positioning on that TV, move it up and center it in the opening, you might be able to squeeze in a good center channel and some bookshelf speakers around it.
BlueGhost is online now
post #7 of 10 Old 10-24-2019, 11:20 PM
RayGuy's Avatar
Quoted: 2909 Post(s)
Liked: 2679
$? What does it need to buy?
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #8 of 10 Old 10-25-2019, 02:55 PM
Kini62's Avatar
Quoted: 2742 Post(s)
Liked: 2566
Nice room. Can't believe the previous owner built that room and put a Bose system in there.
Depending on budget the smallest you should go with would the RSL CG3s and a pair of good subs.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is online now
post #9 of 10 Old 10-25-2019, 03:10 PM
edwardccm's Avatar
Quoted: 84 Post(s)
Liked: 46
small speakers wont do that room justice.
edwardccm is offline
post #10 of 10 Old 10-25-2019, 04:16 PM - Thread Starter
jwharan's Avatar
I am going to try the Martin Logans, and I also ordered a pair of the HSU VTF-2 MK5. I can only fit a 15" wide sub on each side of the cabinet unfortunately. Any tips for the sub setup would be great.
jwharan is offline
Reply Speakers
